Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 27, 2013 at 10:32 AM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    wat.
    the tires hit the bypass tubes on the upstroke too early?
  2. Apr 27, 2013 at 10:34 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I guess i worded that wrong lol the bypass tubes arent correct in the shocks stroke if your running 16's, 14's are perfect for the kit.
  3. Apr 27, 2013 at 10:36 AM
    6spd
    san diego
    2023 4x4
    in terms of location on the body? as in, they would be better located in the front or rear, versus on the outer edge of the shock body? :confused:
    I'm learning here, no LT, yet...
  4. Apr 27, 2013 at 10:38 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    What he is trying to say is the Defined kit was designed for 14" bypasses. With 16" bypasses you are riding around in the middle of the compression tube.
  5. Apr 27, 2013 at 10:38 AM
    PLC721
    Patrick
    Chandler, Az
    Nothing to do with where the shock is located.
    The defined kit cycles 14" of wheel travel at the most. When the kit is cycling wheel travel, and you have 16" shocks.... the stroke of the shock isnt hitting the bypasses(internally) where it should. Thus not giving the "best" offroad ride through whoops etc.
  6. Apr 27, 2013 at 10:42 AM
    6spd
    san diego
    2023 4x4
    so getting 16" bypasses would be a waste with the defined kit, correct?
  7. Apr 27, 2013 at 11:27 AM
    PLC721
    Patrick
    Chandler, Az
  8. Apr 27, 2013 at 1:19 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    how does this look for placement of the bumps? this is the best place i could come up with where it still clears the coil. also how do you make sure that the bump does not come into contact with the coil? like if it clears at ride hieght and droop is it good at bump?
  9. Apr 27, 2013 at 2:23 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    I hope that bumpstop is shortened up to a 2"....
  10. Apr 27, 2013 at 2:48 PM
    santabarbarataco
    jordan
    santa barbara
    Thanks man for the expert advice. Way to be a douche. All I'm asking for is a simple answer. Its obviously a shortened. I would never run 4" bumps on the font. Thanks, next person have any better advice?
  11. Apr 27, 2013 at 2:50 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    :ohsnap::rofl:
  12. Apr 27, 2013 at 2:55 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  13. Apr 27, 2013 at 2:59 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    How many of you guys (2nd gen) have issues with your back tires rubbing your bypass shocks?
    If you do, please post what sort of set up you are running and at what point the tires are rubbing during articulation.
  14. Apr 27, 2013 at 2:59 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  15. Apr 27, 2013 at 3:03 PM
    M C M
    Matthew
    Sin City, Nevada
    Wow, you considered that being a douche. How is it obviously shortened? My x ray vision supposed to see through the body. Put the spring retainer on and see if it hits.....
  16. Apr 27, 2013 at 3:05 PM
    Mxpatriot
    First world problems, I guess...
  17. Apr 27, 2013 at 3:08 PM
    SoCaltaco65
    Wait, soooo you don't have X-ray vision? :eek:
  18. Apr 27, 2013 at 3:16 PM
    santabarbarataco
    jordan
    santa barbara
    Thank you. That's all I was looking for... Sorry for coming off harsh :cool:
  19. Apr 27, 2013 at 4:17 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    Used to, with extreme articulation.
    Engage Rear LT setup with 315s on 17"x8"s with 4"bs now with 1.5" spidertrax spacers. The spacers seem to have solved my issue.
  20. Apr 27, 2013 at 5:32 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
