Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 9, 2013 at 8:53 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I'm leaning toward the hex head also. I'm not seeing the socket for the tri-groove but I'll call them and see whats up. I considered just tacking the end of the bolt but I just want to pull the bolt and not crack out the grinder every time.
  2. May 9, 2013 at 9:00 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    How often are you pulling your bypasses on your DD.
  3. May 9, 2013 at 9:07 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Water jetted top pieces? Look crisp as fuck yo. What program did you use to draw them up ?
  4. May 9, 2013 at 9:27 AM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    I keep :drool::drool::eek::drool: over that truck. I might be getting a silverado next, I would love something like that. But I do like having the 4wd.
  5. May 9, 2013 at 9:30 AM
    esbyota
    B-Rad
    AZ
    05 4x4 Taco
    Plasma cam
  6. May 9, 2013 at 10:24 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    With FOAs prob twice a day to replace seals hahaha
  7. May 9, 2013 at 6:02 PM
    jeffz0rz
    san diego
    soo, that hoop isnt relying on the inner fender for stability right ? that tube go through the wheel tub and to the frame ?
  8. May 9, 2013 at 6:44 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    hahaha! :rolleyes:
    I'm running the same set up just to a tube continuing down into the frame rail.
    Almost looks like a same sandwich plate but mine is from AA mfg
  9. May 10, 2013 at 7:37 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Anyone running a double bypass upfront as a secondary instead of a triple? Any major pro's or con's I should be aware of. I understand the difference between the double and triple. Just curious of anyone with experience with running it.
    Triples are coming in around $400 more for the pair and I'm trying to save a little.
  10. May 10, 2013 at 7:42 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    i know rj is running doubles up front, as far as triples i dont know. you could almost have the second tube on your triple(if you decide to go with them) be your bump zone if you wanted.
    edit: second compression tube*
  11. May 10, 2013 at 7:42 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dew it. Go triples or go home.
  12. May 10, 2013 at 7:58 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Didn't realize RJ had doubles. Correct, on a triple you can use the last tube as a transition to the bumpzone. Which would be nice, but I'm really looking for the extra dampening. I can always get a hydro bump in the future, and my wheelers bumps feel nice for now.
  13. May 10, 2013 at 8:02 AM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Either one will be a noticeable improvement if valved correctly. Run what you can find and be happy
  14. May 10, 2013 at 8:18 AM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    yeah i really like the wheelers bumps as well. its up to you on doubles or triples. if i were you id just get the triples and tune from there. then there wont be the "i wish i got..."
  15. May 10, 2013 at 8:35 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Under most circumstances I would say you are 100% correct. It's just that all the major spending I'm going to be able to do on the truck for a pretty long time is going to end in the next few months.
    Gotta pay for a wedding in September, honeymoon shortly after, and need to make myself be more serious about my house fund.
    If it wasn't for those things I would have already had the triples lol. I was given authorization for one last major purchase lol
  16. May 10, 2013 at 9:09 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Matt you will be just fine with doubles. After I played with the tubes in Barstow that one time and got it where I wanted it.. My front end is tiiits.
  17. May 10, 2013 at 10:05 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    :thumbsup:
    I assumed as much, even with the doubles they are over my budget for the few things I'm doing so I'm walking a tight line.
  18. May 10, 2013 at 10:11 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    The only thing a tripple does is allow you to soften your bump zone, who wants to to do that?:rolleyes:
    With a double or tripple, you're still going to have a bump zone, one might just be more noticeable them the other, haha
  19. May 10, 2013 at 1:03 PM
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
  20. May 10, 2013 at 2:12 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
