Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 14, 2011 at 4:44 PM
    #3381
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    brian... it's southern california
    so cal is more mexico than it is united states...lol
  2. Jun 14, 2011 at 7:39 PM
    #3382
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Full droop/bump shot
  3. Jun 14, 2011 at 7:42 PM
    #3383
    rcfreak201
    rcfreak201 Well-Known Member
    oh damn, for the longest time i thought you two were the same person when i saw pics hahah nice trucks guys!
  4. Jun 14, 2011 at 7:45 PM
    #3384
    Cr250jumper
    The moon
    50 shades of tan©
    ^ I know I told him before they are twins.
    Zach read my sig below. Pretty much 33's
  5. Jun 14, 2011 at 7:49 PM
    #3385
    Cr250jumper
    The moon
    50 shades of tan©
    No thats jacked up in the air on the limit straps full droop. Not at ride height
    Edit: By the way my coilovers are about 2 turns from full loose at all the other ride height pics I have
  6. Jun 14, 2011 at 7:53 PM
    #3386
    Cr250jumper
    The moon
    50 shades of tan©
    No not until I get the rear done and the front gusseted
  7. Jun 14, 2011 at 7:55 PM
    #3387
    rcfreak201
    http://www.dmzfab.com/sam.html
    i thought this truck was pretty sweet, never seen it before, it was shipped to romania, never heard of LT trucks over there
  8. Jun 14, 2011 at 7:55 PM
    #3388
    Cr250jumper
    The moon
    50 shades of tan©
    By the way Im pulling just over 13.5". I dont have bump stops yet so this is where the shock bottoms out without a spring so Ill bump it at 13.5 max
    Full bump
    Full droop
  9. Jun 14, 2011 at 9:14 PM
    #3389
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    4" spindles?
  10. Jun 14, 2011 at 10:21 PM
    #3390
    Cr250jumper
    The moon
    50 shades of tan©
    No its on a jack. You can see the handle sticking out. Its fully drooped. Stock spindles
  11. Jun 15, 2011 at 7:01 PM
    #3391
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    Im gonna ask a quick question! Let's say I have a 4x4 manual taco. And let's say I wanted the camburg race kit ;) how would I go about making it 2 wheel drive? Just remove front diff and the front drive shaft? Or do they make an extension shaft for the manual to remove the transfer case?
  12. Jun 15, 2011 at 8:02 PM
    #3392
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    When cycling the suspension remember to keep the bottom spring holder. Dont know the correct term for it but it will limit your travel.
  13. Jun 15, 2011 at 8:50 PM
    #3393
    Cr250jumper
    The moon
    50 shades of tan©
    Well your on the right path but first step would be to give all the 4wd parts to me :D
    Yeah the lower spring cup or whatever. I know what you mean. My shock actually bottoms internally about 2mm from the spring cup. Which is why I need bumpstops even more.
    Which brings a question. How much shock shaft from full bottom should be out when I set the bumps to bottom? I would think you want a little cushion from being right on the edge
  14. Jun 16, 2011 at 10:41 AM
    #3394
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    anyone in Socal know where to pick up teflon spray locally?
  15. Jun 16, 2011 at 10:43 AM
    #3395
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    try a bicycle shop. the two that i work at carry both wet and dry teflon lubes, both in a spray or drop bottle. you should be able to call and ask so you don't have to makie the drive.
  16. Jun 16, 2011 at 11:17 AM
    #3396
    Cr250jumper
    The moon
    50 shades of tan©
    I get Dupont dry teflon spray at Lowes
  17. Jun 16, 2011 at 11:21 AM
    #3397
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    There's a bike shop by me that sells triflow.
  18. Jun 16, 2011 at 11:29 AM
    #3398
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yep, that's the stuff. all will have a wed lube and most will also have the dry. all good shops at least.
  19. Jun 16, 2011 at 11:39 AM
    #3399
    blackhawke88
    SGV, CA
    07 TRD Offroad
  20. Jun 16, 2011 at 12:29 PM
    #3400
    Cr250jumper
    The moon
    50 shades of tan©
