Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 30, 2013 at 1:11 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Damn I hat to say but I don't think they will stay there, its probably going to slide up
  2. May 30, 2013 at 1:15 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    sleeve a piece of tubing over it
  3. May 30, 2013 at 1:29 PM
    FBGW01
    FBGW01 Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    idk, its pretty dammm snug! like when i welded it, it got a lot tighter so the bump squeezed in there barely. had to use a rubber mallet, and i torqued the bolts down pretty snug.. I'll see how it does today and if it moves, ill prob do what he said vvv
    :thumbsup: see this is why i need tacomaworld! thanks man
  4. May 30, 2013 at 1:33 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    X2 on the sleeve, ive seen too many bump stops fly out *cough cough, Anthony*
  5. May 30, 2013 at 1:34 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Ive also seen my buddy's bump stop get stuck halfway because he tightened it too tight, which was weird. When he loosened up the bolts on the can, it worked fine.
  6. May 30, 2013 at 1:40 PM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    It also looks like you might want it up there anyways.
    That bump is damn near in "play" already...you're gonna feel that bumpstop on every little bump you hit. Might consider shortening the stroke on that too.
  7. May 30, 2013 at 1:40 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    :eek:
  8. May 30, 2013 at 1:44 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  9. May 30, 2013 at 1:45 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    its a 2.5 inch stroke, and the angle of the pic makes it look close, but it has quite a bit of clearance before hitting the strike pad. im not worried, i think i can push it up like another .5 inch and it will still stop my shock from bottoming out.
  10. May 30, 2013 at 1:59 PM
    Cr250jumper
    The moon
    50 shades of tan©
    I was going to say this. If its tight enough to hold in place without the sleeve it can squeeze the body of the bump and bind the piston inside. If you have the bump slid up all the way the piston will not travel down to the bottom bolt anyway though, your friend may have just needed to loosen the upper pinch bolt a little
    ^Best solution
  11. May 30, 2013 at 3:21 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  12. May 31, 2013 at 12:33 AM
    brokeandstuck
    brokeandstuck Well-Known Member
    ed
    valley center
    stuck
    after looking at this pic i went to look at my truck and i just noticed i have the same problem. Guess its back to the shop.
  13. May 31, 2013 at 9:35 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Did you cycle it ?
  14. May 31, 2013 at 11:33 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  15. May 31, 2013 at 11:37 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Robby qualifying photo, I havent seen a rear end with the driveshaft that far off center before ??
  16. May 31, 2013 at 11:38 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    :drool::drool::drool:
  17. May 31, 2013 at 11:42 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    i think that truck may be 4x4, so the tranny is off set so the transfer case and front drive shaft can be center with the center mounted front diff. Same with pro4 trucks, i believe.
  18. May 31, 2013 at 11:43 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Interesting... and bad ass
  19. May 31, 2013 at 11:45 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I'm guessing it has something to do with a mid engine/tranny set up and geometry on the rear suspension.
  20. May 31, 2013 at 11:50 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    That's normal for the IFS KOH rigs
