Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 20, 2013 at 8:52 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    hahahaha its so stupid, my friends f150 sounds like its going to fall apart the cage carries sound sooo bad. I guess filling tube with spray foam helps but ehhhh
  2. Jun 20, 2013 at 10:59 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    my cage is surprisingly quiet..hardly any squeaks or creaks..mostly just noise resonating through the tubes. My rear bypasses do click a lot and it always sounds like something is loose
  3. Jun 21, 2013 at 3:39 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
  4. Jun 21, 2013 at 6:52 AM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    The bushings on your shock will be either 1.25" or 1.5". You'll have to measure your own shocks, and see which width they are.
    As for mounting radius, I'm not sure
  5. Jun 21, 2013 at 7:57 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Can you use the 3" radius ones for the lower mounts on the axle?
  6. Jun 21, 2013 at 9:45 AM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    The thing I didn't like about 5 points in a DD is you don't realize how often you lean forward at intersections to look around corners or to check in your blind spots when lane changing. Reaching for you glove compartment or something you dropped on the floor, drive-thru's, toll booths... you gotta loosen and tighten your top straps every time... whaaa
    That and little trips around town, kinda a pain to strap in every time. Feels safe though.
    For the ladies I only see it as a positive, cause you get to strap them in.
  7. Jun 21, 2013 at 9:53 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Heheh count me in :D
    well...wife...but it still counts!
  8. Jun 21, 2013 at 10:12 AM
    BradyT88
    BradyT88 Well-Known Member
    Could you leave the original seatbelts in for DD and have the 5 points for offroading? Might look tacky, but would be handy. haha
  9. Jun 21, 2013 at 10:13 AM
    VolcomTacoma
    Jeff
    NorCal
    I don't see why not...
  10. Jun 21, 2013 at 10:15 AM
    BradyT88
    That's what I figured. Maybe find some way to tie the 5 point harnesses back for DD'ing so it doesn't look so tacky and that aren't as in the way.
  11. Jun 21, 2013 at 10:57 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    If you have full race seats they are too deep for the lap belt to go over the top and be effective. The only way is to feed the stock belt through the belt slots, and if you do that one of the belts is going to interfere with the other. I agree with not realizing how much you have to lean forward in daily driving, its kind of a pain sometimes. But the way I look at it is if you don't want to deal with the harnesses then don't cage your DD. But in fairness I still get a huge grin every time I strap on the harnesses, so maybe I'm just not sick of it yet :D
  12. Jun 21, 2013 at 11:06 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    No it refers to the width of the misalignment spacers at the top of your shock. My SAWs & foxes used 1.25" width but the FOAs are 1.5" think king is the same. Go for 1.5 if your not sure cause you can always just get wider spacers
  13. Jun 21, 2013 at 11:10 AM
    Cr250jumper
    The moon
    50 shades of tan©
    If your putting on the rear I would go 1.5" like DTF said and add spacers if needed, it will give more room for gnarticulation
    The mounting "radius" is actually the diameter of the tube you are installing the part on. 1.75" would be for 1.75 tubing and 3" would be for the axle
    Edit: BTW Ruffstuff has more options on sizes and shapes
    http://www.ruffstuffspecialties.com/catalog/shockbracketstabs.html
  14. Jun 21, 2013 at 11:15 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  15. Jun 21, 2013 at 11:19 AM
    BradyT88
  16. Jun 21, 2013 at 11:20 AM
    nfs257
    DFW
    She gone
    Those are for us that dont have cages... They go in the stock spot and are retractable. Then you can lock it out tight on you when you are wheeling...
  17. Jun 21, 2013 at 12:49 PM
    Mxpatriot
  18. Jun 21, 2013 at 1:41 PM
    rondog
    Ronnie
    Escondido/San Diego
  19. Jun 21, 2013 at 1:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  20. Jun 21, 2013 at 3:39 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    x2 on the 3", I just got new u-bolts from them (ruffstuff). 5/8th ubolts FTW!
