Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 17, 2013 at 7:26 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    :popcorn:
  2. Jul 17, 2013 at 7:55 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
  3. Jul 17, 2013 at 8:34 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ya sick truck! I've been following his ig too. So badass having a prerunner in Japan. His friend has a way badass in tundra too.
  4. Jul 17, 2013 at 8:48 AM
    05tundra13
    05tundra13 Well-Known Member
    Devin
    Simi Valley
    05 tundra doublecab
    how much would new bfgs be then? less then that? every place ive talked to has outrageous prices. trying to find some used for under 2k for sure.
  5. Jul 17, 2013 at 9:29 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    what kind of bfgs?
  6. Jul 17, 2013 at 9:48 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    the baja, the race version. 37x12.5x17
    i found a guy who is selling them NEW for 550 a tire. which i think is still way too much.
    wish i just had a nice friend who would hook it up with a deal.
  7. Jul 17, 2013 at 9:49 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Like mentioned before if you want the baja T/A's check out RDC or DR for used ones with most their tread for cheap.
  8. Jul 17, 2013 at 9:53 AM
    TC yota
    Tyler
    Escondido
    Ha
  9. Jul 17, 2013 at 9:56 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    ive heard good and bad about them on the street. obviously they are not for the street but i guess it all depends. i saw that post already, just waiting for a response from him. either i get theses or generals..or pro comp a/t's again....the other options are cheaper thats for sure, but I just wanted to see if I can find a better tire out there.
  10. Jul 17, 2013 at 10:01 AM
    TC yota
    Tyler
    Escondido
    Ha
    Cons-they are stupid heavy
    they have shitty traction
    very stiff side wall so airing down doesn't help, also harsher ride because of that
    more stress on drivetrain from weight
    more stress on hubs
    suck in the sand
    Pros- they don't get flats
    They look super sweet trophy truck status
  11. Jul 17, 2013 at 10:02 AM
    Easy rider
    Easy rider Well-Known Member
    Cali
    18' T4R 4x4 LT TC 3.5 over
    My truck goes into Solo on the 11th for the build (spring under bypasses/ 19" kit)...so now I would just be showing u a stock truck & parts. I left the desert in 2008/09 when I sold my last truck to help with the down payment on my house. Now i had the itch again so decided to go with a built Tacoma vs a stock Raptor ( I couldn't believe the premium companies are up charging for parts) I'll hold you over with pictures of my first truck. http://www.dezertrangers.com/vb/ranger/171115.htm ...Its the first truck in the post.
  12. Jul 17, 2013 at 10:03 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    so pretty much a waste if your not a trophy truck then...
  13. Jul 17, 2013 at 10:13 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    the grabbers are heavy if you are thinking of those...
    im running 315-75-16 and i can feel the difference...
    like Tyler said, the BFGs look pimp status, but personally, unless you are logging in a lot of dirt miles, they may not be the best option unless you got some deep pockets...
  14. Jul 17, 2013 at 10:16 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    im really just trying to get away from the pro comps if possible, they are great tires but id like to try something different. ya they look pimp for sure...but for as much as im able to get out and use my truck it almost not worth getting the bfg's but...for the times when i do..hah.
  15. Jul 17, 2013 at 10:22 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, don't skimp on tires if you can help it... cuz the times that you do hit dirt, you don't want to be kicking yourself for cutting corners...
  16. Jul 17, 2013 at 10:30 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    If You've got the money, and you want to look baller status...then by all means, go spend 2g's on tires that you'll use one a month as they are intended for!
  17. Jul 17, 2013 at 10:31 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    i found a deal for 35's for 1500 and thats for 4 tires. brand new pretty much.
  18. Jul 17, 2013 at 10:33 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    what rim size?
  19. Jul 17, 2013 at 10:33 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    17
  20. Jul 17, 2013 at 10:36 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
