Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 30, 2011 at 10:54 AM
    #3561
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    didnt know there was that big of a difference with a tagged cage from a normal cage besides gussets?
    i have dont alot of research, so sorry about that
  2. Jun 30, 2011 at 10:56 AM
    #3562
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    all good man, i'm by no means an expert. i just spend way too much time reading threads on DR and RDC while i'm at school and should be paying attention...like right now :D
  3. Jun 30, 2011 at 10:58 AM
    #3563
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  4. Jun 30, 2011 at 11:01 AM
    #3564
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    wow that's bad ass
  5. Jun 30, 2011 at 11:17 AM
    #3565
    97yota4wd
    Eric
    Mesa, AZ
    yeah dude it sure is!!
    is it really necassary to cut off the roof of a truck to cage it?
  6. Jun 30, 2011 at 11:19 AM
    #3566
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Kyle Green did Wang's without cutting the cab. It makes it easier to weld 360 on the top bars but if you build it in the right steps its not needed
  7. Jun 30, 2011 at 11:23 AM
    #3567
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    like JD said, it makes it a whole hell of a lot easier to weld everything up and allows for a better job... but it's not 100% necessary
    alot of people do cut the top off though...
  8. Jun 30, 2011 at 11:26 AM
    #3568
    97yota4wd
    Eric
    Mesa, AZ
    yeah im not cutting the roof off my truck haha.
    if you do score tag your truck i heard either you have to cut off the roof of your truck or drill holes in the roof for them to inspect the welds 360 degrees.
    jd are you cutting off your roof?
  9. Jun 30, 2011 at 11:27 AM
    #3569
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    this dude just cut his roof off...
  10. Jun 30, 2011 at 11:29 AM
    #3570
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    absolutely!!
    that is pure insanity unless its made of gold...
    it is necessary to cut the roof off to fully weld the tubes...you can do small squares above the weld as well....a score legal cage has to be 100% welded
  11. Jun 30, 2011 at 11:31 AM
    #3571
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    then you are not hardcore enough...:D
  12. Jun 30, 2011 at 11:32 AM
    #3572
    dirty dangler
    adam
    simi valley,ca
    putting the roof back is as simple as placing sawzall blades to create a gap and welding it up. some grinding and sanding and you never know it came off
  13. Jun 30, 2011 at 11:35 AM
    #3573
    dirty dangler
    adam
    simi valley,ca
    last place to skimp and not fully weld tubes is the cab cage.... its meant to save your life during a high speed roll......suck to die from a un-welded tube impaling you
  14. Jun 30, 2011 at 11:36 AM
    #3574
    Cr250jumper
    The moon
    50 shades of tan©
    No my plan is to keep it on. I wont ever get mine tagged but I want it as close to score rules and specs as possible. Not to bag on any people but you have to be carfeul what kind of cage you copy. A lot of them are not following some of the major points score outlines. But like Matt said they arent race trucks they are weekend bashers
  15. Jun 30, 2011 at 11:39 AM
    #3575
    Cr250jumper
    The moon
    50 shades of tan©
    This cage is 360 welded and never cut off the roof
  16. Jun 30, 2011 at 11:41 AM
    #3576
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Material costs are a big factor. 2" .120 wall seamless chromoly tube isn't cheap. It's possible to do a race-legal cage with 1.75" but the truck has to be lightened up substantially as the tube diameter requirements are based on vehicle weight.
    Smaller diameter tube is easier to fit in the truck, so fabrication becomes less complicated and thus less expensive if you go that route.
  17. Jun 30, 2011 at 11:42 AM
    #3577
    Cr250jumper
    The moon
    50 shades of tan©
    He also has a 1st gen though compared to your 2nd gen pig :p Plus he wouldnt be full race ready so a lot less weight
  18. Jun 30, 2011 at 11:47 AM
    #3578
    mjp2
    NJ
    Hell yeah my truck tips the scales. The driveshaft skid alone is around 150lbs.
  19. Jun 30, 2011 at 11:50 AM
    #3579
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    oh god haha. do you know your current total weight when the truck's race ready?
  20. Jun 30, 2011 at 11:53 AM
    #3580
    dirty dangler
    adam
    simi valley,ca
    it can definitely be done. its just a matter of building everything then sliding it up into place. either way is time consuming lol
