Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 13, 2011 at 10:07 PM
    #3801
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    amaes, does it bother you that ur front and rear shocks are different brands? idk if its better to stick to one brand or if its ok
  2. Jul 13, 2011 at 10:31 PM
    #3802
    amaes
    amaes [OP] Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    No not really. If I could find someone to switch me I'd trade my Kings for Foxs. King parts are harder to find at normal shops and they cost a lot. you can get every Shim made for foxes for $200 but King charges $20+ per stack. King heat treats their shims (Not needed at all. I have been told this but multiple race teams) and they use a weird size shaft. THe only shims that can but used in Kings are SAW because they both have the same size shaft. Other then that King and Foxs are pretty much the same. They have same basic design and both use eibach springs. (Yes King springs are made by eibach). Fox has a little better customer service IMO. King is a pretty small company so you can't complain too much.
    For me other then color I don't notice much lol I'm actually going to rebuild my kings here in a few weeks. they could use a rebuild and for sure need new valving.
    The only shocks I have seen have lots of issues are FOAs and SAWs. FOA has really good service from what I hear but their product sucks for the most part. Metal shavings in the shocks are a common thing. and the c/o have weird spring threads. And SAW tends to have bad customer service. Also on the 1450 truck that used to race with us (upgraded to a trophy lite) always seemed to have at least one shock leaking.
  3. Jul 13, 2011 at 10:35 PM
    #3803
    Marioso
    Marioso Risueno
    San diego Ca
    i plan to get fox CO's up front 4wheel parts quoted me 1092 for the pair and he'll waive the taxes too. i got rear piggy backs which i was ok w until i saw lembowski get some non stock replacement fox shocks in the rear for cheaper.
  4. Jul 13, 2011 at 11:01 PM
    #3804
    Marioso
    Marioso Risueno
    San diego Ca
  5. Jul 13, 2011 at 11:50 PM
    #3805
    JoeTacoma02
    JoeTacoma02 Well-Known Member
  6. Jul 13, 2011 at 11:53 PM
    #3806
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    crappy, no... old school, yes. ibeams are from the early 90s
  7. Jul 13, 2011 at 11:57 PM
    #3807
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    Hi nate! :wave: haha
  8. Jul 14, 2011 at 12:00 AM
    #3808
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
    Isn't easier to get longer travel and keep it strong? :confused:
  9. Jul 14, 2011 at 12:02 AM
    #3809
    JoeTacoma02
    Ahh gotcha. Was just curious. Thanks :)
  10. Jul 14, 2011 at 12:13 AM
    #3810
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  11. Jul 14, 2011 at 7:49 AM
    #3811
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    oh yeah, i've melted my fair share of parts welding with them still on the truck. the arms will deffinately be off. while i'm at it, i think i'm going take off both sides to beef up the arms a little (skids on the leading edge of the arms) and add my limit strap mounts
  12. Jul 14, 2011 at 8:00 AM
    #3812
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  13. Jul 14, 2011 at 8:04 AM
    #3813
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    that ranger hits those woops so smooth!
    the toyota needs some lift spindles, bigger tires, and bigger fiberglass in the front. dont ya think?
  14. Jul 14, 2011 at 8:07 AM
    #3814
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    so what's the disadvantage to them that keeps the big name TTs from using them?
    only two things i could think of are strength (no idea if they're stronger of weaker), and handling (since the camber changes so drastically with the articulation)
  15. Jul 14, 2011 at 8:12 AM
    #3815
    97yota4wd
    Eric
    Mesa, AZ
    the clearance on beams is the only big issue with them that i know of
  16. Jul 14, 2011 at 8:15 AM
    #3816
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    this past january i wheelied with a guy who had an older f250 with 4x4 beams. thing was nuts. he had more clearance than us, but that's because he had 37s. on a similar sized tire though, he would have more clearance than a solid axle, but just a little less than us IFS trucks
    i'd imagine they are hard to protect without the ability to run a full skid right down the center.
  17. Jul 14, 2011 at 8:19 AM
    #3817
    97yota4wd
    Eric
    Mesa, AZ
    well right by the tires they kind of angle down, then straight...
    theres less clearance in the middle where it angles.
  18. Jul 14, 2011 at 8:27 AM
    #3818
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    all suspension systems will have about the same clearance where the hub is (with the exception of lift spindles and portals), it's that middle that varies. with all of the different beam trucks i've seen both in person and from pictures, it seems like their clearance greatly varies based on ride height.
    is there such a thing as a lift spindle equivelant for beam trucks? i gues it would be an extended steering knuckle?
  19. Jul 14, 2011 at 10:07 AM
    #3819
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Beams (aka dirty hooker travel) are an old school way of doing things.
    The reasons why TTs don't run them are:
    They tend to have really bad camber through the travel cycle. Unlike Center mounted a-arms like used on TTs
    Another thing is that you leave all of your steering exposed upfront.
    Also they tend to be a lot heavier then what a-arms are
  20. Jul 14, 2011 at 10:09 AM
    #3820
    97yota4wd
    Eric
    Mesa, AZ
    didnt think of the steering. dam good point!
