Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 18, 2013 at 11:21 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  2. Oct 18, 2013 at 9:20 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    hey guys, I just installed a rear brake line and when I bleed it no air came out. I bled it a shit load and no air came out once..
    My brakes are squishy too, but I remember last time I drove it it was real squishy too, thoughts?
  3. Oct 18, 2013 at 9:31 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Or MCM?
  4. Oct 18, 2013 at 9:42 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Bleed it at the master cylinder. The air went up the lines.
  5. Oct 19, 2013 at 6:25 AM
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    I would buy the older models like the 08-09 and save some money to dedicate to the LT build. Are you doing the install/Fab work? Front and rear, Parts and Labor i would figure on spending over $10,000 closer to $15,000
  6. Oct 19, 2013 at 7:34 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    ^^^^^^^ This! ! Got my plates in Wednesday. Thanks matt .
  7. Oct 19, 2013 at 7:50 AM
    M C M
    Matthew
    Sin City, Nevada
    They gonna work?
  8. Oct 19, 2013 at 8:35 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    So true. Suspension, body work, interior pieces will all get tossed during your build. I wouldn't even be concerned about paint because you will be painting hood, and fenders F/R. All the fab work will destroy a pristine paint job too. The heat, shop dust, and welding slag gets everywhere..
  9. Oct 19, 2013 at 1:42 PM
    jeffz0rz
    san diego
    the only thing I didn't take into account was to be able to get a bolt into those plates for the bypass since there's going to be a tube on either side almost right in line with that hole. Not too worried about it since I can probably sleeve each that tube to get a boat through there, but for you cutting those plates off of a hand sketch and 0 measurements, they are just about perfect lol
  10. Oct 19, 2013 at 2:11 PM
    Flux
    Flux Active Member
    Cody
    Mission Viejo, CA
    Buying 2014 DCLB TRD SPORT 4x4 Soon™
    Long-travel Soon™
    Are there any differences between 2008/09 and 2014? What year did they add the new head unit ?
  11. Oct 19, 2013 at 4:28 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I posted this under long travel suspension by mistake :
    I have a mid travel set up but figured you guys have far more experience with extended brake lines since you must do it for LT. I ordered extended stainless hoses and when I was looking at the set up in the front yesterday I was wondering if the routing and number of connections could be simplified. iE: stock the truck has a hard line to an "L" on top of the frame then hard line from the "L" for 8-10" then goes to rubber hose then back to a short hard line at the caliper. I was wondering if I could eliminate all the crap in the middle and just run a stainless line from the "L" at the top of the frame straight to the caliper ...would eliminate a few connections and look a hell of a lot cleaner. Anyone done this ? Or do you lose too much pressure ?
  12. Oct 19, 2013 at 6:59 PM
    jeffz0rz
    san diego
    Getting there.
    hope to have a few more tubes in tomorrow.
  13. Oct 19, 2013 at 7:55 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  14. Oct 19, 2013 at 8:50 PM
    biggie
    biggie Well-Known Member
    Collin
    Tucson
    02 LT Xtra Cab
    fuck thats a good deal no wonder i cant sell mine
  15. Oct 20, 2013 at 6:05 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Question for you guys...
    With the TC 3.5" kit for 2nd gen, what's a good bumpstop to go with without going hydraulic? I'm going to do King 2.0's down the line, but it's not in the budget with the kit and axles and everything as of right now. Will a solid bumpstop be ok for the time being? I'm just so tired of the stock ones up front with mid travel, and I'd like to do a little upgrade until I can get the Kings.
    Thanks dudes
  16. Oct 20, 2013 at 6:16 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Of course it will fine , tons of people run without hydro bumps
  17. Oct 20, 2013 at 6:28 PM
    The Traveler
    SoCal
    What bump do most go with?
  18. Oct 20, 2013 at 6:45 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Wheelers super bumps are pretty good...what shocks are you gonna run with the kit before you get kings?
  19. Oct 20, 2013 at 6:48 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Can't run hydros with a TC kit. No strike pad.
  20. Oct 20, 2013 at 6:56 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    My buddy's got a camburg kit for sale. It's the older kit without bypass. Boxed lowers.
    2500 obo comes with coilovers and gusseted spindles. Pm me if anyone is interested.
