Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 11, 2014 at 7:54 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    I swear I'm not trying to stir shit at all, I just want to confirm that even the trusted brands have some fitment issues too?
  2. Jan 11, 2014 at 8:07 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    No, an upper arm flexes a little bit, they are talking about a tight fit to get washers to fit which is fixed by pulling with your hands. One side of a lower arm being too thick to fit into the pocket for the arm is much different and a much bigger headache to solve. Your talking about hours of fab work
  3. Jan 11, 2014 at 8:13 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I would say that the TC arms are so high tolerance and precise that assembly is difficult. There is maybe .015 tolerance, making sliding the inner washers in tough, especially with fat urathane bushings in there. Since I am an expert at hillbilly fabrication I completely fucked up their high tolerance part with a screw jack to make assembly easier. It worked. I also bet if their fabricator saw me do it he would cringe and throw slag hammers at me. :D
  4. Jan 11, 2014 at 8:27 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  5. Jan 11, 2014 at 8:30 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Haha! Ok I was just curious, thanks guys for clearing it up!
  6. Jan 12, 2014 at 3:20 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Factory has tolerances, aftermarket manufacturers have tolerances, welding affects each part differently, even in a fixture. Add all that together, sometimes things are a little off.
  7. Jan 12, 2014 at 3:59 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Foam or no foam in my cell? Doesn't look broke down or anything, im just worried about it messing with my float.
  8. Jan 12, 2014 at 5:31 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Is your float the arm style ? If so it won't work with the foam ....
  9. Jan 12, 2014 at 6:07 PM
    jeffz0rz
    san diego
    It is the arm style, and I can see some of the foam blocks are a little broken up.l on second glance.
  10. Jan 12, 2014 at 8:56 PM
    TC yota
    Tyler
    Escondido
    Ha
    Yeah no go if it's the arm style
  11. Jan 12, 2014 at 9:28 PM
    jeffz0rz
    san diego
    I see the sloshing around beating up the float arm without foam, and impossible to use with foam.
  12. Jan 13, 2014 at 7:50 AM
    Engage Offroad
    Engage Offroad Dezert Lovers Unite Vendor
    Engage Marketing
    Pomona, CA
    Like everyone else we got tired of trying to figure out a way to properly mount and store our jack's, so after testing on the Shop Prerunner and putting thru miles of abuse, we are happy to introduce the NEW Engage Jack Mount System HF68051
    this System utilizes an All Aluminum Skid that bolts directly to the Harbor Freight Jack #68051 and is inserted to an all Metal Mount that is attached to your vehicle, it utilizes a spring loaded pin for ease of removal and to maintain the Jack securely In its place while on the trails/race course. Comes with all hardware and instructions, like always for TW members we will be offering it at a great introductory price. List is $279 and for TW members we will offer it for $223 until Jan.24th 2014. Contact us here on TW, email us at engageoffroad@gmail.com or call the shop 909-238-6788 to place your order and have your jack ready for the 2013 Race Season! See you at the Races!! Engage
  13. Jan 13, 2014 at 8:31 AM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    I'm running stock pump and float in my cell with no foam, works fine other than a bit of noticeable slosh under hard cornering with the tank under 1/6 full, the pump can be starved for fuel. I plan on extending the pump and float brackets lower to get a more true reading on the guage and allow the use of the very last of the fuel.
    I've heard of people putting in wiffle balls or similar things to help with slosh, while not breaking down. I'm not too sure about doing that though...
    I'd just run no foam
  14. Jan 13, 2014 at 9:24 AM
    jeffz0rz
    san diego
    thats what im going to run for now. i to have to lower my pump and pick up tube as well, and move my pump towards the center of the tank more to avoid it sucking air, since my pump is mounted on the side. possibly switch it to a tube style sending unit soon that way i can run foam.
  15. Jan 13, 2014 at 10:01 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  16. Jan 13, 2014 at 10:02 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
  17. Jan 13, 2014 at 10:13 AM
    jeffz0rz
    san diego
    yikes. is that the going rate on 16" doubles ? ooof.
  18. Jan 13, 2014 at 10:19 AM
    TC yota
    Tyler
    Escondido
    Ha
    no foam in a stock gas tank.....
  19. Jan 13, 2014 at 10:29 AM
    jeffz0rz
    san diego
    true, but there is a baffle of sorts in my stock tacoma gas tank. what would be he purpose of that one ? its only about 3" high that is right under the pump.
  20. Jan 13, 2014 at 10:29 AM
    shawnphoto
    MT
    First Gen Tundra
    Let me know how you end up lowering the pump, i was thinking of just chopping it and extending the bracket and wires lower, but I'm not really sure.
