Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 23, 2014 at 10:22 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    My buddy has 4 HID's mounted on the roof of his buggy, 2 flood 2 spot, he has the spots pointed straight out and the floods turned a little to the side and he's not able to out run them.
  2. Jan 24, 2014 at 12:27 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
  3. Jan 24, 2014 at 6:40 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Im trying to figure out what combo with 5 lights total.
  4. Jan 24, 2014 at 6:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    3 spot. 2 flood. outers are flood.
  5. Jan 24, 2014 at 6:56 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Jeff I don't think you want flood on your roof at all. Just get 3 spot and 3 euro.
  6. Jan 24, 2014 at 6:57 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ^^thats a good idea as well.
  7. Jan 24, 2014 at 6:59 AM
    jeffz0rz
    san diego
    little late. i have a box full of 7" red rings. spot and flood. if they made a euro id be all over it.
  8. Jan 24, 2014 at 7:54 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    arent red rings euro?
    at least mine are
  9. Jan 24, 2014 at 8:29 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Yeah redring's "spot" is way closer to a euro beam than a spot
  10. Jan 24, 2014 at 8:35 AM
    jeffz0rz
    san diego
    dunno. i think my floods are a flat spread beam. would that be considered a euro beam ?
  11. Jan 24, 2014 at 9:10 AM
    Supermoto
    Landon
    Fallbrook
  12. Jan 24, 2014 at 9:26 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    They make a euro and a spot, but I am sure their spot is not as narrowed as others.
    edit: spot is the bottom because the reflector is smooth
  13. Jan 24, 2014 at 9:40 AM
    jeffz0rz
    san diego
    Well ill know more tomorrow night when I bolt em up and kick em on.
  14. Jan 24, 2014 at 10:31 AM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    you might want to run at least one flood up top, when i had 5 spot beam hid's on a roof rack they worked great for distance but left a little to be desired as far as filling in corners and close stuff. however if you also have the 30" then you might as well go all or mostly spot as it will take care of the nearby fill
  15. Jan 24, 2014 at 10:43 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Jeff I thought you had an LED bad for the front bumper also to fill the short range?
  16. Jan 24, 2014 at 11:28 AM
    jeffz0rz
    san diego
    yeah, that 30 is great. i could actually get by with just that, but im a light whore. i cant see for shit at night and need everything i can get.
  17. Jan 24, 2014 at 4:08 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I drilled out the cone shaped hole in the spindle and ran a regular bolt through it.
    That's probably not the right answer but it's worked for me for a while. I was sick and tired of that angled bolt turning, which would throw toe off. With a straight bolt that is not possible.
  18. Jan 24, 2014 at 5:18 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    What size bolt did you use
  19. Jan 24, 2014 at 5:34 PM
    Mxpatriot
    I'll measure for you tomorrow, it's dark out and sub-zero with wind chill right now.
    It's the same diameter as the bolt hole on the outer heim joint on the tie rod. I didn't change anything on that, just drilled out the cone shaped portion in the spindle so I could use a regular straight bolt.
    I use a nylon lock nut and I keep them tight, I can't detect any wiggle in the bolt/spindle joint. I had to hammer the bolts into the hole in the spindle; that's how tight of a fit it was. I forget what size drill bit I used.
  20. Jan 24, 2014 at 5:46 PM
    MonkeyProof
    SoCal- SGV
    Awesome and thanks!
