Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 8, 2014 at 8:54 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    My guess is wheel offset.
  2. Feb 8, 2014 at 10:17 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    DAMN IT!
    Passenger side motor mount caved into the frame.
    Been through this with the driver's side before.
    WTF Toyota!?!?!?!
    Truck hasn't been offroaded (besides forest roads, but you could take a damn civic where I'm going) in months ...
  3. Feb 8, 2014 at 10:49 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Its time for frame plating!
  4. Feb 8, 2014 at 11:19 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Make sure your shock tower isn't pushed in before you plate it! Mine appeared fine and my dumbass gusseted it up and I had to get heimed uppers to unfuck it. You'll know it's jacked if your camber is off / |.
  5. Feb 8, 2014 at 12:40 PM
    Mxpatriot
    I'm sure my shock towers are pushed in a little bit. My alignment tabs are maxed out and I still am a little bit off on camber.
    Any advice on how to correct the shock towers?
    I ordered DMZ's gusset kit. Planning on welding this motor mount back in place next weekend.
  6. Feb 8, 2014 at 12:42 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Have your frame pulled or get the 2" TC uppers with hems
  7. Feb 8, 2014 at 12:55 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Use a jack between the engine and tower? I'm a hillbilly engineer though, like nofords said, take it to a body shop and have them do it the "right way".
  8. Feb 8, 2014 at 4:07 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Won't work. I tried to do that with a porta power. All it did was cause the engine to shift over in the engine bay on the motor mounts.
  9. Feb 8, 2014 at 4:10 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Yes
    Thanks guys. I can't wait to put I on. It's going on the 2014.
    Thinking of going with icon coilovers and a 650# spring
  10. Feb 8, 2014 at 6:46 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    For those that have looked at swapping a 9" rear in, How are you keeping the speedo? Mine is driven off the rear speed sensors. Havent seen that option on a 9"... lol
  11. Feb 8, 2014 at 6:48 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    You talk to awsumdc about the t case speed sensor and wiring harness that he sells. Still loose the abs though which you probably dont care about.
  12. Feb 8, 2014 at 7:09 PM
    jeffz0rz
    san diego
    Dgaf the speedo or get a gps speedo.
  13. Feb 8, 2014 at 7:40 PM
    nfs257
    DFW
    She gone
    I thought I had read it was for 05-08... I love no ABS...
    I want cruise control! lol
  14. Feb 8, 2014 at 7:45 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    My truck is running off of ONE speed sensor in the T-case (I like Cruise too, no ABS, no traction control bs). I'm sure it is possible to run off of one of your front wheel speed sensors if you tied all four together. Try it, might be as easy as that.
  15. Feb 8, 2014 at 7:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ill take two :cool:...haha
  16. Feb 8, 2014 at 7:46 PM
    nfs257
    DFW
    She gone
    Just tie the 2 wires from the rear in with the front? Might work....
  17. Feb 8, 2014 at 7:49 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
  18. Feb 8, 2014 at 7:55 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    They are sitting on a shelf... LOL
  19. Feb 8, 2014 at 7:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know i know!! :eek: :frusty:
  20. Feb 8, 2014 at 11:00 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    Only sucks if you're in shitty ass California, speedo trips smog, I need to bail then it's ls1 and turbo!
