Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 19, 2014 at 9:56 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Pretty much! Mine works but is weird
  2. Feb 19, 2014 at 9:58 PM
    Supermoto
    Landon
    Fallbrook
    Heims work best in a push/pull force. 4 link let's the work like that. 3 link let's side load to be applied to the heim
  3. Feb 19, 2014 at 9:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea I gottcha now.
    Yea he has a panard style 2 link setup with the air shocks.
    Works no doubt.
    I am gonna do a panard style 3 link I think when I get there..just hadn't seen the wishbone style before.
  4. Feb 19, 2014 at 9:59 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    4 link, and 3 link makes you move lots of shit. Broncos have that goofy rear tank right ?jeeps to, dont they?
  5. Feb 19, 2014 at 10:01 PM
    Supermoto
    Landon
    Fallbrook
    Also keep in mind it's easy to keep a spare upper link on the truck with 4 link... Not so much with a wishbone
  6. Feb 19, 2014 at 10:02 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    Is that a reason why (on an unrelated note) there are more bushing and uniball A-arm setups than heim?
  7. Feb 19, 2014 at 10:02 PM
    Supermoto
    Landon
    Fallbrook
    Your right but I don't even think about those as useable offroad vehicles
  8. Feb 19, 2014 at 10:05 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Except I've seen lots of 4 links rip out frame side mounts, never a 3 link. And I've never seen a heim break from side loads.
  9. Feb 19, 2014 at 10:05 PM
    Supermoto
    Landon
    Fallbrook
    No, long story but it's out of what sells best. For the best strength uppers should be heim and lowers should be uniball
  10. Feb 19, 2014 at 10:08 PM
    Supermoto
    Landon
    Fallbrook
    Read back a few, a stated that I've never seem a heim go from side load... I've seen a few 3 links pull from the frame. There is no less load against the frame side.
  11. Feb 19, 2014 at 10:13 PM
    Supermoto
    Landon
    Fallbrook
    I want to know how a 3 link wishbone could put less load on the frame side mount? Not talking shit just never heard that ever.
  12. Feb 19, 2014 at 10:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wouldn't it be since both frame sides are connected that the stress gets spread better??
  13. Feb 19, 2014 at 10:30 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    4 link uppers still see the same load. If the left link is pulling away from the frame the right link is pushing in to the frame just like a wishbone setup. To me it seems like the wish bone setup would be more stable vs. The 4 link.
  14. Feb 19, 2014 at 11:35 PM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    Bushing uppers:
    - are easier to install and align (and cheaper if you're paying someone else)
    - are quieter and more comfortable
    Heimed uppers:
    - require solid mounting of lowers
    - are more expensive
    - won't deflect and will hold an alignment
  15. Feb 19, 2014 at 11:38 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Congrats on the 1000th post haha. And pardon the noob question but what do you mean by solid mount the lowers? I agree with you on the quieter part for the bushings though
  16. Feb 19, 2014 at 11:40 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You don't have to solid mount the lowers....it's when you use a bolt instead of the factory adjustable cam....aka non adjustable/movable lower control arms.
  17. Feb 19, 2014 at 11:45 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    I would love some hiemed 2+ uppers so I can bump my caster from 1.9 to 4 on both sides.
    Anybody with an allpro lt kit have this problem? Can't get the caster past 2, allpro says 4 is recommended.
  18. Feb 19, 2014 at 11:50 PM
    Bobber Bill
    Los Angeles, CA
    Wow, can't believe I actually have that many posts. Thanks.
    Lower A-arms like those on Tacomas adjust by way of eccentric cams and slotted mounting holes at the frame. This allows the lower arms to move in/out, forward/back for camber/caster/toe adjustments.
    When you heim the uppers, you weld in plates or washers at the lower arm frame pivots. This gives you fixed lower arm pivots and your heimed uppers take over your alignment adjustments. Eccentric cams move/slip and lose their position, heimed uppers and fixed lowers do not unless something else bends or breaks.
  19. Feb 19, 2014 at 11:53 PM
    Bobber Bill
    Los Angeles, CA
    True. You don't HAVE to solid mount them, but it's generally done because that's what they're designed for.
  20. Feb 20, 2014 at 6:52 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Doing an alignment with the upper cam arms only is a pain in the ass and I don't think there is an alignment shop out there that would perform this. I'm talking about having to pull the upper thru bolt, removing the arm, adjusting the heims and reinstall--unless there is another way?
    While on the upper heim arm subject and caster adjustment, is there a "rule of thumb" adjustment for the heims in relation to caster? A post above said he wanted 4* of caster and is in the 1.5 range. I'm in the 1.9-2.2 range and want to increase caster to help the damn thing go straight on the road.
    edit: at my last alignment my caster was 3.4* both sides, camber -0.9 left, -0.8 right and toe at -0.38. It drove straight after that but still has a wander to it. I've had no less that 40 alignments done since I've had the truck.
