Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 20, 2014 at 7:02 AM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Im at 1.9 on both sides and the truck tracks straight, just wanders the slightest at 50mph or above.
  2. Feb 20, 2014 at 7:08 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Indeed, It took me a bit to figure out what each is from either user group, lol
  3. Feb 20, 2014 at 7:51 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I love having solid mounted lowers...alignment always the same
  4. Feb 20, 2014 at 7:57 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    I need to crawl under my truck and check what joint it has, if it helps any it is a 2011 double cab 4wd. I did some quick searching online and from my understanding this would be 5.5-6 degrees down? Most information I see is for cars, so it doesn't convince me since our suspension moves much more and don't want to be having problems with the driveshaft slipping out or crushing the transmission down the road. I know Tim told me that I will need to get the shaft shortened but I didn't see any information for pinion angle.
  5. Feb 20, 2014 at 8:02 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    No, that would 5.5-6 degrees UP from the horizontal.
  6. Feb 20, 2014 at 8:20 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Yep... up
  7. Feb 20, 2014 at 8:37 AM
    Supermoto
    Landon
    Fallbrook
    You have to plate in both sides of each mount to no longer have a slotted hole there.
  8. Feb 20, 2014 at 8:56 AM
    Supermoto
    Landon
    Fallbrook
    You have to have heimed uppers.
  9. Feb 20, 2014 at 9:01 AM
    anthony250f
    Anthony
    San Diego, CA
    I got the lsk solid mount kit with Delrin bushings...well worth it and simple to insall.
  10. Feb 20, 2014 at 9:02 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    I did too. Pain in the ass to put in the bushings but I love the kit.
  11. Feb 20, 2014 at 9:14 AM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Anybody know someone that can build a hiemed upper for a allpro lt kit?
  12. Feb 20, 2014 at 9:32 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Just go with the Total Chaos cam gussets.
  13. Feb 20, 2014 at 9:39 AM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    I'm also wondering this... Seems like a huge PITA
  14. Feb 20, 2014 at 9:48 AM
    theduck911
    Max
    Locked and Geared!
    Any reputable fabircator could build you a heimed upper based off the one you have.
    OR if that's not an option, TC sells the heimed upper seperately for their 2"+ LT kit that should work, since as far as I know the geometry of both kits is relatively the same.
  15. Feb 20, 2014 at 10:14 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
  16. Feb 20, 2014 at 10:25 AM
    05TacoRunner
    Peoria, Az
  17. Feb 20, 2014 at 10:39 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    TC Gussets for sure. We have been doing a lot of them recently. THey help so much compared to the thin stock ears
  18. Feb 20, 2014 at 10:43 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
  19. Feb 20, 2014 at 10:46 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
  20. Feb 20, 2014 at 10:59 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
