Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 27, 2011 at 11:08 AM
    #4261
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    to get a 4wd axel to pull over 13 inches of travel and not bind is alot of work....
  2. Jul 27, 2011 at 11:08 AM
    #4262
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Now who made that rule. I think its just a scam if an 8" fits but they are also selling 4.5" why wouldn't you go with 8" in the first place so you don't have to buy coilovers twice if you decide to go lt.
  3. Jul 27, 2011 at 11:10 AM
    #4263
    97yota4wd
    Eric
    Mesa, AZ
    :popcorn:
  4. Jul 27, 2011 at 11:22 AM
    #4264
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    most people want to have a direct bolt on part with nothing to worry about. most will not want to have to add limit straps to protect uniballs, balljoints, CVs, etc.
  5. Jul 27, 2011 at 11:23 AM
    #4265
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Please read on and realize that the collapsed and extended lenghts are different. So you can wedge the wrong shock if you want but you will lose travel. They make 2 different kinds for a reason. One fits OE apllication. One fits LT. Some people dont like shoving whatever can fit into the hole and calling it a day
  6. Jul 27, 2011 at 12:33 PM
    #4266
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Yes kinda, but like CR250Jumper said thats NOT whats supposed to be there at all. they were just testing.
    Actually my 2.0 Sway Aways are the same collapsed size as the 2.5x8" , go figure. :eek: . haha.
  7. Jul 27, 2011 at 12:36 PM
    #4267
    Anthony250
    Anthony
    Rialto CA
    Now its not a scam, they are valved differently and run different springs, Plus is you run a 2.5x8" on a stock lower arm and uniball upper arm and not limit it with a strap your gonna mess up the L. Ball joint and possibly the upper, which your not supposed to do anyways.
  8. Jul 27, 2011 at 12:57 PM
    #4268
    97yota4wd
    Eric
    Mesa, AZ
    ^^^yeah the burg kit pulls 13 inches of travel:D
    engage pulls 16 iirc, which is why its hard to get a axel to work.
  9. Jul 27, 2011 at 5:45 PM
    #4269
    theghost
    theghost Well-Known Member
    white
    the Engage kit will pull 16" in theory but until there is an axel in there it doesnt really count becuase its just 2wd LT kit. Camburg 2WD kit will pull 15 maybe a little more if you work it right and has better ground clearance and a narrower track width.
  10. Jul 27, 2011 at 10:33 PM
    #4270
    rcfreak201
    rcfreak201 Well-Known Member
    anybody need spares? i got two of these, 75each or 120 for both, theyre 16s
  11. Jul 27, 2011 at 10:50 PM
    #4271
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    Can someone explain to me the advantages/disadvantages to a SUA setup?
  12. Jul 27, 2011 at 10:52 PM
    #4272
    97yota4wd
    Eric
    Mesa, AZ
    where are you getting these numbers?
  13. Jul 27, 2011 at 10:53 PM
    #4273
    97yota4wd
    Eric
    Mesa, AZ
    PROS: more up travel, cant be a true lt without it
    cons: less clearance because the springs go under the axel.
    thats all i know
  14. Jul 27, 2011 at 10:55 PM
    #4274
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    Beat me to it haha^^^
  15. Jul 27, 2011 at 10:58 PM
    #4275
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Prevents springs from going into negative arch
  16. Jul 27, 2011 at 11:18 PM
    #4276
    kite
    Squamish, BC
    Red Truck
    How do you get more up travel with less clearance?
  17. Jul 27, 2011 at 11:22 PM
    #4277
    theghost
    white
    its called the internet, should I walk you through how to find it
    vvv Direct from Camburgs WebSite vvvv
    "This system will yield up to 15″ travel on a 2×4 and 14″ on a 4×4"
    So I ask YOU now, where are you getting your numbers? I dont see 13" on there anywhere... nor do i see a functional 4x4 Engage kit thats pulling 16".... Have you ever seen a Camburg kit in person? Have you had the pleasure of watching it cycle? I doubt it.
  18. Jul 27, 2011 at 11:33 PM
    #4278
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  19. Jul 27, 2011 at 11:35 PM
    #4279
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    The Camburg 2wd is 15in of travel. The 4x4 is 14. Im pretty sure both of those are strapped an inch to two inches as to not bottom out the shock. Yes the Camburg Kit has a narrower track width.
    I like the width and the height of my truck. Took one trip to Barstow and one trip on the Lucerne Course to find out why.
  20. Jul 27, 2011 at 11:35 PM
    #4280
    rcfreak201
    thats what i think when i see your username pic thingy:laugh:
