Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 28, 2011 at 9:43 AM
    #4301
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    thanks for everyones help for guiding me through this project!
    without all you guys i would be royally fucked!
  2. Jul 28, 2011 at 9:45 AM
    #4302
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Change your ball joints or you still will be :p
  3. Jul 28, 2011 at 9:50 AM
    #4303
    97yota4wd
    Eric
    Mesa, AZ
    lol i already did:) check the build!:p
  4. Jul 28, 2011 at 9:58 AM
    #4304
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Good. You're "build" is impossible to follow though....you should have a mod rename the "build" to "bs thread" :D
  5. Jul 28, 2011 at 9:59 AM
    #4305
    97yota4wd
    Eric
    Mesa, AZ
    what about now JD?
  6. Jul 28, 2011 at 10:00 AM
    #4306
    97yota4wd
    Eric
    Mesa, AZ
    lol i know! i bs way to much. i thought about making a new one so theres not like 18 pages of bs and 2 pages of build lol
    or see if a mod is nice enough to go through and delete all useless posts, but mods are way too busy for that
  7. Jul 28, 2011 at 10:15 AM
    #4307
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I can see them but they are tiny lol. Honestly I dont know much about fuel cells. Im not sure if I will ever get one. Would be nice though
  8. Jul 28, 2011 at 10:17 AM
    #4308
    97yota4wd
    Eric
    Mesa, AZ
    okay, well they retail for over 300 it looks like, he said it has never had fuel in it, i think im going to shoot for 200 shipped. lol we will see
  9. Jul 28, 2011 at 12:25 PM
    #4309
    theghost
    theghost Well-Known Member
    white
    looks to me like that is closer to 14" I have personally had the opprotunity to see a 2nd Gen (what I thought we were discussing considering engange doesnt make a 1st gen 4x4 kit) Camburg Kit cycle 15" clean and retain 4wd.... just saying. I already bought what I thought was ideal, now i want something different. I'm far from a noob to this game...
    But to keep things completely fair, the engage kit pulling 16" has their "race spindle" on it, so a 2wd first gen camburg "race kit" will pull 20"
    http://www.camburg.com/toyota/95-04-tacoma/race-series-longtravel-kit/
    Cheers.
    now you get it...... engage does not make a "4x4" kit for anything but the 05+ tacomas, know your shit instead of "assuming" things before you try to debate informed people... good luck with you HREW race cage :lol:
    look, i can copy and paste too!
    The 2005-2010 Toyota Tacoma is a great platform to start with. In this high end Camburg Long Travel kit you will find nothing but the very best in A-Arm performance. Starting with our lower arm, uni-balls in the lower frame pivots, uni-ball lower ball joint replacement, and a stout boxed race arm. The upper arm pivots on urethane bushings with zirk fitting and 1.250″ race uni-balls replace the stock ball joints. We adapt the uni-ball to the spindle with heat treated stainless steel adapters. Utilizing Camburg SPEC 8″ travel 2.5″ reservoir coilovers by Sway-A-Way or FOX there is no need to cut the stock coil-over mounts. The shock design has an external top cap so the shock has a 1.5″ shorter overall extend length then all other off-road race shocks. For the steering we have steering extenders and also offer a heim joint steering upgrade. The steering upgrade includes a Heat treated stainless steel ty-rod and inner clevis which utilizes a 3/4″ rod end / heim joint. This system will yield up to 15″ travel on a 2×4 and 14″ on a 4×4. If desert pre-running / racing is your forte then the by-pass upgrade is for you! This system can be upgraded with our dual shock mount and a 2.5″ 3 tube by-pass shock can be added to the system. So to sum it up this upper and lower uni-ball Long Travel System is for the ultimate in performance so if you are into trail running or desert racing or just exploring Moab you have found the ultimate in performance!
    Upper and lower uni-ball A-arms
    lower Uni-ball spindle adapter
    brake lines
    limit straps
    steering extensions, coilover mounts
    hardware.
    Heim Steering upgrade $495.00
    Heim joint upper arm pivot upgrade $249.00
    I laugh at how "informed" you guys believe you are, high post counts dont mean you know what your talking about. It just means that you would rather sit at you computer and flirt with other truck people than wheel. Have either of you ever been to a race, none the less assisted in the support or a race program, I already know the answer...
    Cheers
  10. Jul 28, 2011 at 12:39 PM
    #4310
    Cr250jumper
    The moon
    50 shades of tan©
    I am informed because I actually own a kit you wish you got the first time. Has nothing to do with my post count. I dont need to race it to cycle the suspension. You go "follow" race teams and keep buying shit you dont want anymore
  11. Jul 28, 2011 at 12:40 PM
    #4311
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
  12. Jul 28, 2011 at 12:42 PM
    #4312
    97yota4wd
    Eric
    Mesa, AZ
    im not sure if you realize what his post said. he said his kit pulls over 13, the internet says 13. so he said the internet isnt always exact. might want to re read.
    the engage with their race spindle pulls 15.75, without it pulls 16inches.
    and my cage will be 1.75 .120 USA DOM
    oh hey you can copy and paste congradufuckinglations.
    i am somewhat informed, i never said i was really smart as i am still learning as well as you and everyone else. i sit on the computer at work and learn, after im usually working on my truck or wheeling, i probably wheel more than you do, i go out 3-4 times a week. have i ever been to a race? yeah i have raced quads when i was a kid, trucks raced at every event i raced at so i watched that for 4 years, i raced dirtbiked this whole year and most of last year, and trucks raced at every one of those events also. i have only helped pit once. you sure act like you know alot about me.
  13. Jul 28, 2011 at 12:42 PM
    #4313
    Cr250jumper
    The moon
    50 shades of tan©
    Funny how you cant even copy and paste correctly.
    And I said my kit pulls OVER 13". You should read more carefully
  14. Jul 28, 2011 at 12:43 PM
    #4314
    97yota4wd
    Eric
    Mesa, AZ
  15. Jul 28, 2011 at 12:45 PM
    #4315
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Don't feed the troll lol. "Theghost" posted on my LED review claiming one brand was better than the other just because the LED's were brighter :rolleyes:. Usually the newbies don't stick around to long.
  16. Jul 28, 2011 at 12:50 PM
    #4316
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    can I use the shock mounts on my axle to put my rear limit strap on or should I do separate tabs? I've seen both
  17. Jul 28, 2011 at 12:51 PM
    #4317
    97yota4wd
    Eric
    Mesa, AZ
    seperate, if im understanding you correctly
  18. Jul 28, 2011 at 12:51 PM
    #4318
    Cr250jumper
    The moon
    50 shades of tan©
    He went to a race before. He is the authority on all things LT (and lighting). You should know that
  19. Jul 28, 2011 at 12:59 PM
    #4319
    rondog
    Ronnie
    Escondido/San Diego
    like this (looking from the back of the truck)
  20. Jul 28, 2011 at 1:03 PM
    #4320
    Cr250jumper
    The moon
    50 shades of tan©
    That should work as long as you use a bungee or something to make the straps "collapse" towards each other so they dont end up tangled in the shock when it compresses
