Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 17, 2014 at 10:59 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i see a front...
  2. Apr 17, 2014 at 11:08 AM
    sirhk100
    sirhk100 Well-Known Member
    It has an engine... Happens to be brand new off the factory floor, not a rebuilt or used dealio. Needs broken in... Has an auto trans with OD built by culhane slapped in behind the engine thingy too with some cool billlet stuff on it as well.
  3. Apr 17, 2014 at 4:37 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Memorial Day weekend
  4. Apr 17, 2014 at 5:42 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    These are my 05+ 4wd spindles with Solo Motorsports gusset kit that I just got in the mail. Its not a compact gusset by any means but they swear by it so we will see how it goes.
  5. Apr 17, 2014 at 6:09 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  6. Apr 17, 2014 at 6:51 PM
    TCprerunner
    TCprerunner Well-Known Member
    What's a good tire y'all recommend for hard packedbdirt and gravel?
  7. Apr 17, 2014 at 7:33 PM
    sirhk100
    Offer it to him and see what he says. It's a good truck. I've got no motivation behind talking good or bad about it at this point cause I don't own it anymore. It's noisy, squeeks, creaks, clanks, clunks, etc... But it works pretty damn good! If he hasn't done anything the front end could use a double stack of 20s on the compression and the rear rebound could be lightened up a tad to allow it to droop out a bit more. The weak link on the truck imo is the front spindles. Build up some using a D35 or D44 hub assembly and it should be a pretty bomb proof setup. It could probably use a full tear down and prep also but really it's good to go as is too. The current owner is daily driving it to give you an idea... It's bare minimum, no creature comforts or anything like that.
  8. Apr 17, 2014 at 7:36 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Depends. What speed? Stock motor? Size tires? What gear ratio? How long do they need to last?
    If money is no object I would say BFG Baja's would be a good off the shelf bet, but would not be competitive against a custom cut short course tires. Problem with those is they don't last long, but they are sticky.
    http://www.race-dezert.com/classifieds/index.php?ct=wheeltire&md=details&id=71521
    If those are out of your price range I have had good luck with Nitto Trail Grapplers, BFG All Terrains, and surplus military tires.
  9. Apr 17, 2014 at 7:53 PM
    TCprerunner
    60mph and under stock motor 285/70/17 30k+ miles would be nice was looking at the trail grapplers did you have any issues with them?
  10. Apr 17, 2014 at 8:48 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Nope, good tires. So good that when they wore out I bought a second set. I run them on a 2500HD and got almost 50K miles out of them. The only minor complaint is that they pick up gravel in the tread, but if you go fast enough they fling out pretty easy. Perform fantastic on gravel/dirt, and do pretty good in the snow.
  11. Apr 17, 2014 at 9:06 PM
    TCprerunner
    Awesome thanks
  12. Apr 17, 2014 at 9:12 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Toyo AT2 are great tires as well
  13. Apr 17, 2014 at 10:11 PM
    Kennyperez
    Kennyperez Well-Known Member
    Kenny
    Yucaipa
    Tundra
  14. Apr 17, 2014 at 10:43 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Offer him 5k, and only if he hucks the front suspension into the ocean. That's a zzr/zip Locke kit. It's like 900 bucks, and complete dog shit. Good looking truck, but 9 grand better get you 2x the truck.
  15. Apr 17, 2014 at 10:44 PM
    Kennyperez
    Kenny
    Yucaipa
    Tundra
    Yea I thought I've recognized the kits..
  16. Apr 18, 2014 at 7:56 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Limit straps for stock leafs
  17. Apr 18, 2014 at 9:01 AM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    :laughing:
  18. Apr 18, 2014 at 3:01 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
  19. Apr 18, 2014 at 3:05 PM
    BradyT88
    BradyT88 Well-Known Member
  20. Apr 18, 2014 at 3:07 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    WOW :eek:
    Lower Ball Joint?
