Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 11, 2014 at 8:24 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    yup only the speedo everything else works
  2. Jun 11, 2014 at 8:27 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Mine has a sensor in the T-case. I have deleted all four wheel speed sensors and my speedo still works. There is your fix, put a transfer case in it. Seriously, chase down the wires and see what's up. It's pretty easy to mess up those sensors too, check your connections, and take them out and clean them.
  3. Jun 11, 2014 at 8:54 PM
    BradyT88
    BradyT88 Well-Known Member
    Yep, those sensors go out fairly often when people do any work that requires unplugging them...
    The manual trans have a tcase sensor. I believe that Rock Solid Toys came up with a conversion for those auto trans guys that are going to 1 ton axles. Get in touch with Wyatt (awsumdc) if you want to go that route.
  4. Jun 11, 2014 at 9:28 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    He has one as long as your tranny has a port on it. (I think) if I remember correctly it wouldn't work on mine...
  5. Jun 11, 2014 at 9:44 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    any ideas how to get this bolt out? was going to try to cut the head off and hammer it out...with much force it would only go a few inches out
  6. Jun 11, 2014 at 9:46 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    The bolt for the rack?
  7. Jun 11, 2014 at 9:47 PM
    anthony250f
    Anthony
    San Diego, CA
  8. Jun 11, 2014 at 9:49 PM
    JuansTaco
    Juan
    gilbert az
    I think i had to get a longer screw driver and hit it out with a hammer if i remember correctly
  9. Jun 11, 2014 at 10:01 PM
    anthony250f
    Anthony
    San Diego, CA
    i was hitting it as hard as i could..only came out enough to fit the back side of the diff...lol
  10. Jun 11, 2014 at 10:02 PM
    JuansTaco
    Juan
    gilbert az
    Oh you have 4wd. Not sure about that
  11. Jun 11, 2014 at 10:20 PM
    anthony250f
    Anthony
    San Diego, CA
    guess its time for some f911 bolts
  12. Jun 11, 2014 at 10:33 PM
    JuansTaco
    Juan
    gilbert az
    Yep.
    what are the specs on the new truck?
  13. Jun 11, 2014 at 10:41 PM
    anthony250f
    Anthony
    San Diego, CA
    97 5 speed 4x4..camburg front with saw bumps coilovers and tripples. Rear is f67 with 3.0 saw tripples (rusted to shit) has a engine cage and a cab cage....it needs a ton of work, so right now im just trying to pull everything off
  14. Jun 11, 2014 at 10:46 PM
    JuansTaco
    Juan
    gilbert az
    Ah that's sick man! Think i saw a pic on your Instagram. Looks good
  15. Jun 11, 2014 at 10:50 PM
    anthony250f
    Anthony
    San Diego, CA
    thanks man, hopefully ill be moving out to az at the end of summer
  16. Jun 11, 2014 at 10:50 PM
    JuansTaco
    Juan
    gilbert az
    Really? What part? Its nice not. Too much rust
  17. Jun 12, 2014 at 8:55 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    So you hit the bolt towards the front of the truck and it will only go as far as the front diff? Am I understanding that correctly? If so...I'm assuming you have a diff drop. You have to remove the diff drop and jack the front diff up all the way in order for the bolt to come out all the way.
  18. Jun 12, 2014 at 9:59 AM
    amaes
    amaes [OP] Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Yup I have ran into that one also haha
  19. Jun 12, 2014 at 11:39 AM
    anthony250f
    Anthony
    San Diego, CA
    Yeah that's what I was going to try...front diff bolts didn't really want to come out either, they slide down with the diff but just the bolt won't slide out...would there be a problem installing a new bolt backwards? That way the diff not be in the way
    It went almost as far as the diff...that was with slamming the bolt with a hammer, I don't think it would go any further. I was planning on cutting the head off and hitting it backwards
  20. Jun 12, 2014 at 12:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Means the front diff bolts that run through the crossmember are bent and likely the holes in the crossmember are ovalled (see below). I had to use an impact and a pry bar to get the front bolts out. From the picture, looks like your rack bolt is bent as well.
    Sounds like your new project has been beat on!
