Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 30, 2014 at 7:21 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    You too man, thanks for all the stuff. I will for sure be hitting you up about that sway bar
  2. Jun 30, 2014 at 7:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How close does the front diff sit to the oil pan? Making new mounts and im worried the diff won't fit
  3. Jun 30, 2014 at 8:05 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Making new perches? Measure off Jordan's. You should just order those dmz ones and call it a day.
  4. Jun 30, 2014 at 8:32 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Technically yes, but i doubt you will notice it on a play truck, nobody here is boiling their shocks running barstow for 4 hours straight
  5. Jun 30, 2014 at 8:51 PM
    anthony250f
    Anthony
    San Diego, CA
    im just worried that the dmz ones wont work (thinking my frame is bowed in) and now i forgot how close the diff is the the oil pan
  6. Jun 30, 2014 at 8:53 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It's close. Real close.
  7. Jun 30, 2014 at 8:56 PM
    anthony250f
    Anthony
    San Diego, CA
    well in that case...im gonna see about trailering it to a shop...
    is it close on the side of the diff...or on the top?
  8. Jun 30, 2014 at 9:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Kinda both. It's sorta wraps around it..
  9. Jun 30, 2014 at 9:05 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    mine went bad :(
  10. Jul 1, 2014 at 6:34 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Not sure how you mean that but there may be a Customer Support Program ELT on the ECU to 15 years / 150k. I would call Toyota CEC and play dumb, 800-331-4331.
  11. Jul 1, 2014 at 6:46 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Agreed. All it takes is one little caved in motor mount for the oil pan to start knocking a hole in itself.
  12. Jul 1, 2014 at 7:22 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    I agree that not many are running Barstow main for hours, and that in some cases it may not matter, but an hour down a graded road will kill a shock, especially if it can not breath.
    a piston living in a 1-2" area of a shock body creates a ton of friction and heat, bowling and breaking down the oil causing the shock to fade..
    If you are going to paint/powder or dip a shock, I would recommend that you put the best fluid possible in it, something that will keep the heat down.
  13. Jul 1, 2014 at 10:28 AM
    anthony250f
    Anthony
    San Diego, CA
  14. Jul 1, 2014 at 10:56 AM
    Supermoto
    Landon
    Fallbrook
  15. Jul 1, 2014 at 11:05 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I cant play the video at work but my carrier just went out a few weeks ago, it sounded like a squealing belt but louder and coming from directly under the cab
  16. Jul 1, 2014 at 11:06 AM
    anthony250f
    Anthony
    San Diego, CA
    the carrier bearing doesnt look great either..also noticed when i push the wheel in toward the 3rd theres a lot of play side to side
  17. Jul 1, 2014 at 11:07 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Just tagged you in jds carrier vid on iG
  18. Jul 1, 2014 at 11:09 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Just out of curiosity, I imagine that King and Sway-A-Way are running premium fluids on their black bodied shocks?
  19. Jul 1, 2014 at 11:20 AM
    Lakeside, Ca. 92040
    those shocks are anodized not powder/ paint coated. all shocks are anodized, they just change the color from clear to black or what ever color you choose.
    Like what was stated above.. It may not matter in most applications, but if you are going to do it, you should run the best oil to try and combat the heat trap that you will see. whether it be a little or big gain in temps.
  20. Jul 1, 2014 at 11:30 AM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    if we were to chop the old perches off and buy the dmz ones, bolt them to the engine side w/ solid mounts, snug down solid trans mount and position engine (or should we position the engine first and base the trans mount off of that location?), possibly tack the mounts to keep them from shifting, then bolt up the diff and check for clearance, we should be able to get everything set up right?
    we think the frame is bowed a little bit because the engine wont seat on the driver side perch correctly, and when he got the truck a broken stock mount was kind of haphazardly welded straight to the perch.
    i don't think that it will be too hard to do as long as we get the positioning right, but the gap between the pan and diff scares me a bit
