Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 1, 2014 at 12:14 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Sounds about right to me. Are u redoing the trans mount too? Or using the existing one? If using the existing then put those bolts in just enough so they stay but allow a lil movement the take motor mounts. If u do motor 1st u may never get those to line up with out moving the mount a hair. Just my 2¢ from dealing with a broken perch twice and trans mount... :notsure; but really I don't know shit lol
  2. Jul 1, 2014 at 12:21 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    My motor mounts were fine when I punctured my oil pan. I reused a bolt that came with my old procomp 6" lift and had one too many threads sticking up. When I nose dived in ocotillo a while back, I punctured mine. Luckily it was a small crack and was fixed with some quick steel. It's been holding strong for over a year
  3. Jul 1, 2014 at 1:51 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    Yah that's what I was thinking. Existing crossmember new solid trans mount. Anthony wants to take it to a shop but I'm confident we can do it right if we just take out time and triple check everything.
  4. Jul 1, 2014 at 2:09 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'm too cheap. I've been running atf for the last 3 years. Works great for just doing desert runs.
  5. Jul 1, 2014 at 3:03 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Well that's interesting. I need to find something lighter for the Siberian winters up here, I wonder how ATF would do. When it's -20F my truck rides like a freight train for a few miles. I guess I could put block heaters on the shocks.
    Edit: I learned more than I ever wanted to know about ATF as suspension fluid here, it's geared toward mountain bikes, but interesting none the less- http://www.peterverdone.com/wiki/index.php?title=Suspension_Fluid
  6. Jul 1, 2014 at 3:54 PM
    rcfreak201
    rcfreak201 Well-Known Member
    I have had that SAME noise for a couple months! My carrier bearing is fine and i just had my driveshaft inspected. Are my gears going out? Bearing? I have had 4.88s in there for about 60,000 miles and a good amount of offroading too.
    Heres a video I tried taking..its clearer towards the end but sounds exactly like the video Anthony posted above. Any insight would be helpful! :cheers:
    http://youtu.be/Kw6R5117KkQ
  7. Jul 1, 2014 at 4:52 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Truck is pile now, u should just trade me and I'll deal with the problems ;)
  8. Jul 1, 2014 at 5:16 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I jacked up the rear and all I found was both wheels have lots of side to side play...and the driveshaft spins quite a bit before the gear "engage"
  9. Jul 1, 2014 at 5:38 PM
    MadTaco461
    CA
    Kinda stock
    Poor man's shock oil, you just need to valve for it.
  10. Jul 1, 2014 at 6:15 PM
    Spagget13
    Spagget13 Well-Known Member
    Drew
    Lake Havasu City
    01 TRD off road ext cab
    Mcm Fabrication4x4 long travel kit, ADS coilovers, ADS bumps Deaver h70/e30 Leafs, 2.5x16 king double bypasses, straight pipe after cat, Glassworks Fiberglass front and rear.
    Can I play/bs in here now? :p:D
  11. Jul 1, 2014 at 10:20 PM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    Picked up all this tonight thanks to my buddy Kellan at king. 3.0 triples and 2.5 coil overs
    7FDD9EFF-75C2-4F3E-BD92-9A80AD45A49B-305_456755da4d3d582defcfc80fc080b981bbc2d55b.jpg
  12. Jul 1, 2014 at 10:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'd just leave the diff bolted in while you line stuff up. Just don't drop the motor on it :p
    Then drop the diff to weld them in after you tac them.
    Jesus..3"
    You planning on doing the baja 1000 haha
  13. Jul 1, 2014 at 10:54 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Was hanging out with his brother yesterday
  14. Jul 1, 2014 at 11:13 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Mounted my bedsides
    and got a locker
  15. Jul 1, 2014 at 11:13 PM
    TRACperformance
    TRACperformance Well-Known Member
    First gen 4x4 we finished up last week. Did the kit and bumper. No balljoint.
  16. Jul 1, 2014 at 11:49 PM
    Spagget13
    Drew
    Lake Havasu City
    Kellan hooks it up! Always get the good deals.
  17. Jul 1, 2014 at 11:58 PM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    would that lower uniball be usable on other kits (retrofit) or on stock arms? if so i think you could make some bank selling just that portion
  18. Jul 2, 2014 at 12:14 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    :jawdrop:
  19. Jul 2, 2014 at 6:48 AM
    BradyT88
    BradyT88 Well-Known Member
    Speaking of 2.5" vs 3". How hot is too hot for a shock? I played around at the dunes for a few hours this weekend and my rear 18's got pretty damn hot. Hot as in you could feel the heat just putting your hand within a few inches of them. You could hold your hand on them without getting burnt but it was still hot enough to be uncomfortable to hold your hand on it for very long so getting close to where it would burn you. I'm still MT up front so I'm sure once I go LT I will be pushing them even harder. I have 2.5x18" kings up front. Oh and it wasn't even a hot day out there. It was in the 70's.
    I've seen the video of BJ spitting water on a set of his shocks and it boils instantly off of them but I figure that's too hot and he's just going go rebuild/replace them after that. Haha
  20. Jul 2, 2014 at 7:00 AM
    MadTaco461
    CA
    Kinda stock
    I saw the truck at the meet. Kit looks solid with hiemed uppers. I was staring down the front bumper. I love it.
