Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 10, 2014 at 7:35 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Does anyone have pictures of a fabricated rear cross member? I figured I'd check in the LT thread since you guys tend to hack things up more than others.
    I'm planning a flat bed build and want to remove the rear cross member so I can bring the CG down a little bit. I'll be placing a jobox and auxiliary fuel and water tanks under the deck and the center cross member sits too high. Any pictures of custom cross braces will be appreciated. Just trying to get some ideas.
  2. Jul 10, 2014 at 8:11 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    I have all of it in stock! Just shoot me a PM with the length's you need and ill price you out.
    F'n A Cotton!
  3. Jul 10, 2014 at 9:07 AM
    BradyT88
    BradyT88 Well-Known Member
    I just cut it out and put a piece of 2"x3" tubing at the back of my towers. Then just plated and boxed in the frame. My bumper is sturdy enough it should hold the rear just fine.
  4. Jul 10, 2014 at 9:21 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I will let other post their custom crossmembers but I will share that you need to tack weld a tube, keep your frame towing hitch on or do something to stabilize your rear frame section as you build your new crossmember.
    When we did a custom crossmember on my old truck we could move the ends of the frame with out hands. That's how flimsy the stock frame is.
    Box the frame and build your crossmember at the same time and you should be set.
  5. Jul 10, 2014 at 10:27 AM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    :woot:thanks matt. with no notching of the frame im fitting 35x12.5 grabber in there. lol
  6. Jul 10, 2014 at 10:51 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks for the picture Brady. I don't think I've seen your towers before, damn!
    Good advice. I am planning on building the rear bumper/receiver/recovery point before I cut out the stock cross member. I'll be sure to tack in a few retainers before I hack it out.
  7. Jul 10, 2014 at 11:02 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Can you send me prices and availability on these FK heims shipped to 91016?
    (2) JMXL12T
    (2) CMX12-8T
  8. Jul 10, 2014 at 11:21 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    I don't carry the CMX's. Only the JMX's in 3/4.
    But I have plenty of the Left hand and right hand in stock. PM coming on pricing
  9. Jul 10, 2014 at 11:25 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Got some sweet new shirts in!
    In Black and Grey
    In a few different colored Logo's and Black and Grey Shirts
  10. Jul 10, 2014 at 11:53 AM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I have 600lb 16 " coils on my 8" SAWs and like3.25" of preload but my front end still sits to low. SHould I step up to 18" 600lb or go 650lb?
  11. Jul 10, 2014 at 12:00 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Longer spring won't do much but give you more preload, Need to step up in rate.
  12. Jul 10, 2014 at 12:40 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    ^^^^this. Longer spring will compress the same, potentially causing coil bind.
  13. Jul 10, 2014 at 1:07 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    The coils are supposed to touch right? That's what makes you jump higher! :eek:
    LOL
  14. Jul 10, 2014 at 1:15 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    See what I do is put a little bend in the coilover, then you dont have to worry about all that stupid travel
  15. Jul 10, 2014 at 1:26 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Yup!!! That's a good space saving method!
    But with this set-up kings work better
  16. Jul 10, 2014 at 5:38 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    how much for them tshirts?
  17. Jul 10, 2014 at 9:05 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    So I've been chasing a sound for a while now. I guess its time to share with the class:
    //www.youtube.com/embed/0LEcjzKqbFM
    Listen for the bassy twaing like a bow string half way thru. This only happens on slow almost full lock turns either forward or backward but more often backward. I can feel the pop thru my firewall on the dead pedal. It resonates thru the whole cage as Ive seen on other videos.
    I have footage of all four corners and nothing is moving enough to make that much noise. I have footage of the whole rear suspension, top and bottom of the front suspension and nothing is physically moving incorrectly when the noise is heard. I have shots of my transmission and that looks correct. Steering is solid, UCA has a little heim wobble but not when that particular pop occurs.
    If its not the suspension what else should I look for?
    Thank you in advance.
    (Yes i know my heims are worn, replacements are coming asap.)
  18. Jul 10, 2014 at 9:15 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Trac Performance
  19. Jul 10, 2014 at 10:43 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    My DMZ kit arrived into the shop today. Apparently the price went up.
  20. Jul 10, 2014 at 10:49 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    x2.
    been considering the kit myself.
