Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 24, 2014 at 4:26 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Has anyone experimented with vinyl wrapping fenders instead of getting them painted? seems like it could possibly be cheaper, or no? I imagine it would be difficult with all the curves in the glass.
  2. Jul 24, 2014 at 4:39 PM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    The Traveler has his truck wrapped with glass, looks....... good.:boom:
  3. Jul 24, 2014 at 4:56 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    it looks pretty good if it doesnt have any deep spots in it like louvers. It tends to peel up in those little spots along with the underside of the fiberglass where it gets cut.. Other than that its suppper easy to clean but you do get tears and rock chips in it pretty easily.
  4. Jul 24, 2014 at 6:07 PM
    txmxer
    06 dc tacoma
    Sweet, I want to get some fenders but I dont want to run around with the mismatched fender look and I also dont want to spend that much on fenders that will get torn up, my next truck will be white for this reason haha
  5. Jul 24, 2014 at 6:21 PM
    Large
    Large Red
  6. Jul 24, 2014 at 7:07 PM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    Cut out my inner fenders and now that i have lots of room I think I'm gonna make a lil wider/higher travel kit for my 4runner so seeing if anyone is interested in my current kit.
    Will fit 2nd Gen Tacomas
    Hiem uppers, lowers, 3" lift spindles, steering, 8" coilovers with 600lb springs w/top mounts, bolt on resi mounts and 4 limit straps.
    13" travel. Set up to run single shock plus airbump.
    keeping the air bumps
    $2500 + your stock lowers and spindles.
    Also have a set of 4 17" wheels with 285/70r/17 goodyears, about 3/8 tread left. Nice even tread, well rotated tires. $500
    Hit me up if youre interested
    nine fore 9 - three tharee 8 - ate ate ate 4.
    More Pics in my Build Blog, link in sig.
  7. Jul 24, 2014 at 7:15 PM
    Happysmiley
    Fabien
    Northern NV
    Also have a gutted 89 single cab and doors. Pretty good shape, I'd give it a 7+ out of 10
    Cab $100, doors $50 each, Together $150?
    Sorry for slangin in the BS thread.
  8. Jul 24, 2014 at 8:05 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    If only it would work for a 1st gen double cab :( How does someone drop off their springs and drive away with a 4-link? Unless the install is done at engage. My springs on on my truck
  9. Jul 24, 2014 at 10:09 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Congrats man glad to here your on to bigger and better things :D
    Hit me up if you need anything
  10. Jul 25, 2014 at 12:08 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Not cheap, but it looks good IMO. My truck was silver streak mica before the wrap.
    Thanks pal :rolleyes:
  11. Jul 25, 2014 at 10:53 AM
    JawKnee
    JawKnee I <3 Pink Tacos
    Ontario Ranch
    2002 Tacoma
    Total Chaos, DMZ, Deaver, Sway-Away, KMC, BFG, Hella, ICOM, BTF, Glassworks, Trac Performance, Lowrance.
    I always wondered how much over per side your kit was?
  12. Jul 25, 2014 at 11:44 AM
    Happysmiley
    Fabien
    Northern NV
    3 1/2 over per side, plus 7/8 each side for the lift spindles.
    Anthony I might want a set of spindle blocks if you can still do that, or I may just use some stock spindles again and cut them up, ha.
  13. Jul 25, 2014 at 12:35 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Yeah I still get them milled. It's waaay easier than cutting that shit out of the stock spindle and easy to integrate into your design
  14. Jul 25, 2014 at 12:48 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
  15. Jul 25, 2014 at 1:25 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    what do you guys think of this shackle angle? 56" hanger to hanger 9" shackle through the frame....about to install 50t's
    dark picture i know....its bright out
  16. Jul 25, 2014 at 1:25 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Full droop?
  17. Jul 25, 2014 at 1:27 PM
    anthony250f
    Anthony
    San Diego, CA
    yes.. straps arent holding it either lol..full droop they are loose...at ride height they were about a 45* angle.
  18. Jul 25, 2014 at 1:37 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    So your straps still have slack? I say strap it maybe an inch higher because your leafs are starting to separate and the straps will stretch. How do your shocks look?
  19. Jul 25, 2014 at 1:38 PM
    txmxer
    06 dc tacoma
    Yeah man your wrap looks awesome! I know full wraps get kind of pricey, Im going to contact some people and see if they can wrap just my front glass and get anywhere close to my radiant red.
  20. Jul 25, 2014 at 1:45 PM
    anthony250f
    Anthony
    San Diego, CA
    shocks arent installed right now..im putting in 50ts and t100 axle this weekend....just wanted to make sure i dont have to move the shackle hangers
