Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 7, 2014 at 10:41 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Ya i found mine off DR and arranged for surfermatt to pick em uo since we were meeting already in cali
  2. Aug 7, 2014 at 3:57 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I may roll out Friday afternoon or sat morning
  3. Aug 7, 2014 at 4:06 PM
    JuansTaco
    Juan
    gilbert az
    Makes me wish i had my front kit on :(
  4. Aug 7, 2014 at 6:41 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  5. Aug 7, 2014 at 6:45 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  6. Aug 7, 2014 at 9:05 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
  7. Aug 7, 2014 at 9:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's fucking cool
  8. Aug 7, 2014 at 11:09 PM
    txmxer
    06 dc tacoma
    Lets say hypothetically I was interested in buying coilovers from someone who has no idea what they have but looks like an 8 inch coilover, and the only info I have is that the overall length is 17" (which seems right size for a fox shock), and the coil is 11.5". How would I tell if its an 8 inch coilover or not??
  9. Aug 7, 2014 at 11:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's not. 8" coil over have 16" coils. Unless the preload is insane on them
  10. Aug 7, 2014 at 11:32 PM
    txmxer
    06 dc tacoma
    Thanks, Ill keep looking
  11. Aug 8, 2014 at 10:27 AM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    cant decide on front bypasses before or after cage...
  12. Aug 8, 2014 at 11:45 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    A "standard" 8 inch coilover should be around 24" extended, 16" collapsed. Fox are tad longer
  13. Aug 8, 2014 at 11:46 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Run c/o and get it valved properly
  14. Aug 8, 2014 at 11:47 AM
    Rylee
    Rylee
    Mission Viejo
    07 dcsb long travel
    i have coilovers that are valved pretty well i believe, ive heard adding front bypasses is almost a night and day change
  15. Aug 8, 2014 at 11:53 AM
    TC yota
    Tyler
    Escondido
    Ha
    They are nice but not 100% needed, all depends on what you're doing with your truck. I ran with a c/o only up front for years and it was fine, hit plenty of big jumps and whoops. Do you know what's in your c/o valving right now? The only real need to have bypasses is if you can't get the coil over stiff enough or you are overheating the shock. If you say you think they are valved pretty good right then you might not need to upgrade
  16. Aug 8, 2014 at 12:30 PM
    Rylee
    Rylee
    Mission Viejo
    07 dcsb long travel
    thanks tyler, i believe its at 15/12 now if im not mistaken rides pretty well i think ( im no expert shock tuner) just like doing trial and error. plus it makes me faster at rebuilds and revalves
  17. Aug 8, 2014 at 12:32 PM
    TC yota
    Tyler
    Escondido
    Ha
    That should be close, might have to step up to a 20 on comp if it's not stiff enough. I would cage it first then get a bypass if you feel you need it later
  18. Aug 8, 2014 at 12:32 PM
    Rylee
    Rylee
    Mission Viejo
    07 dcsb long travel
    10-4 thanks man!
  19. Aug 8, 2014 at 12:44 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I need to step my coilover comp to 20 sometime before this season. I'm at a 12 flutter 12 standard stack and its pretty damn soft with my bypass tubes all the way in. Going to do a 12 flutter 20 standard stack, open the tubes up and tune from there. Adding all the 4x4 stuff added quite a bit more weight to the front end.
    I wouldn't imagine you would need 20's in a prerunner.
  20. Aug 8, 2014 at 1:59 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    My front comp on coilovers is a straight 20stack....no flutter no bypasses....way better than it was but might need a tad bit stiffer. We shall see how it is once these bumps get put up front.
    4x adds some weight for sure!
