Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 11, 2014 at 2:27 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Any advice on removing the upper spindle bolts?? It wasn't this hard with my midtravel upper arms. I've soaked in pb blaster for a bit and even my impact driver isn't getting it off. Should I get a nut splitter? I tried heating the bottom nut a bit
    EDIT: more heat finally did the trick
  2. Aug 11, 2014 at 3:23 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    yea mine was leaking again then i caught a rock cresting over a hill and kaboom it was broke as a joke.
  3. Aug 11, 2014 at 3:36 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    If any of you have ever re-valved dirt bike suspension you will understand that our truck shocks are a piece of cake compared to dirt bikes. The overall diameter is much smaller but holy shims! My forks base valving will have:
    (7) .15 x 30
    (2) .10 x 28
    (2) .10 x 26
    (2) .10 x 24
    (2) .10 x 22
    (2) .10 x 20
    (2) .10 x 18
    (2) .10 x 16
    Modern twin chamber forks have a damper rod assembly that holds a valve stack (mid valve) and when the load gets to a certain point it forces the dampening to the base valve which has a separate high and low speed. And it also has compression and rebound adjusters that control bypass through the hollow center of the damper rod. Pretty neat, but not easy to tune lol :)
  4. Aug 11, 2014 at 6:23 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Wonder if PSC makes anything you can use on a 2nd gen. I'll call them up tomorrow to hear their 2 cents on the subject.
    EDIT: Is it possible to take a ram and mount it where the rack goes, and just custom fab some tie rod ends with heim joints? You'd also need a higher volume pump and a bigger reservoir. A hydraulic assist ram steering setup would be sweet.
  5. Aug 11, 2014 at 6:29 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Dude Pm me if you can , Im going to through my crf250r my rear shock revalve My god never have i seen so many shims lol.
  6. Aug 11, 2014 at 7:08 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Does anyone have any Deaver F67s in good shape that they are looking to sell?
  7. Aug 11, 2014 at 7:28 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Feed back would be non existent, as well as self centering steering among many other things.
  8. Aug 11, 2014 at 7:36 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Hydraulic is kind of old fashioned. Electronic Power Steering is the future, but short of hacking apart a new Chevy pickup I don't know how to source the parts. The buggy dorks are converting to EPS and there is some aftermarket support there, but it's all centermount. I did notice that the new Tundra rack looks very similar to the Tacoma rack (just beefier). It might be a tad wide, but with different tie rods may be just the ticket for an easy upgrade. Anyone have access to a tundy to take some width measurements? Center of bolt hole to center of bolt hole, body width, arm length etc?
  9. Aug 11, 2014 at 7:48 PM
    The Traveler
    SoCal
    This is 100% true on full ram steering. But we routinely install ram ASSISTED steering kits on solid axle vehicles like Jeeps and Super Duty's, and they drive very nicely. Less feedback for sure, but steering returns to center every time and it definitely helps when you're locked in the front, aired down, on 37's or bigger tires.
    Next time I get a 2014 Tundra in the shop, I'll do some snooping around. I get one or two in every month or so.
  10. Aug 11, 2014 at 8:10 PM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    Chaos has been using the new tundra rack on the mini (shop race truck) with pretty good results. They have only had 1 go out to my knowledge. Also solo did the tundra rack swap on the silver tacoma that's running there frontend. I haven't heard how its working though. I believe they had to shorten it to make it work though
  11. Aug 11, 2014 at 8:16 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I'm also on my 2nd rack..
  12. Aug 11, 2014 at 9:20 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have f55 fs
  13. Aug 11, 2014 at 11:08 PM
    BBMOffroad
    BBMOffroad BBM Offroad
    Brea
    2001 prerunner
    We can sell you new ones
    I think there was a set for sale on dezertrangers
  14. Aug 12, 2014 at 5:30 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Thanks for the offer. Pat at TC suggested F67s so I'm trying to go with that right now.
  15. Aug 12, 2014 at 11:59 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Does anyone have an 33x10R15 tires that they would trade for some 33x12.5R15 BFG all terrains? Mine are 90% and looking for the same. I will pay to swap tires.
  16. Aug 12, 2014 at 2:02 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I have some. They are about 95% lol
  17. Aug 12, 2014 at 3:01 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Sent PM
  18. Aug 12, 2014 at 4:21 PM
    anthony250f
    Anthony
    San Diego, CA
    Yeah f67 should be perfect. I have tc 9" shakles to incase you were looking
  19. Aug 12, 2014 at 6:45 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    What shackles are you running if you have those 9" shackles available? I was planning on running those F67s with a 12" shackle.
  20. Aug 12, 2014 at 6:49 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    I would so the e30 pack and 12s. Instead of f67s
