Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 27, 2014 at 2:30 PM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    I've read it's good to still run it to the radiator as that helps get the transmission fluid up to operating temperature when cold. Transmission fluid is supposed to be within a certain temp range for everything internally to work smoothly.
    I've also read with cheap non OEM radiators that have a transmission fluid core that there is a danger of an internal rupture between engine coolant and transmission fluid that can mix the fluids and trash your transmission. Supposedly Titans were having this problem.
    Damned if you do, damned if you don't.
  2. Aug 27, 2014 at 2:54 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    #autotrannyproblems
    :D
  3. Aug 27, 2014 at 2:54 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    x2
  4. Aug 27, 2014 at 3:09 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Hmmmm... Well it is a nice all aluminum replacement rad. Wut to do wut to do...
  5. Aug 27, 2014 at 3:10 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Ok I may have to do that. Ya he's cool I talked to him for a minute at superstition. Love his white 1st gen dbl cab!
  6. Aug 27, 2014 at 5:01 PM
    broker
    broker Well-Known Member
    Broker
    Camarillo, CA
    2002 T4R
    Mostly Stock with a Roll Cage
    The 3rd gen 4runners have an issue with the stock radiator/trans cooler and most of the 4runners just run an external trans cooler and bypass the factory cooler. Same trans as the tacomas. I've been using only an aftermarket trans cooler for a few years now.
  7. Aug 27, 2014 at 5:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    ^^This
  8. Aug 27, 2014 at 5:28 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Ok guys I'm knee deep in an SUA setup. When I was removing the front hangers I found a small rust hole behind one of the welds. That got me thinking:
    Why not just cut that out and french in the front hanger like 2 inches. I am trying to think of why that would be a bad idea and the only one I can come up with is that moving it after that would be a ton of work. The real upside would be that it wouldn't be hanging so low when I'm wheeling.
    thought?
  9. Aug 27, 2014 at 8:31 PM
    Happysmiley
    Fabien
    Northern NV
    Obviously gonna be a lot more work than slapping some TC front hangers on and welding them up.
    Might get tricky with leaf to frame clearance at full bump just behind the front hanger, especially that first spring bracket, also with how Deaver does their front eyelet your spring leaves are higher than the pivot at the front of the pack making clearance even tighter...
    If you can pull it off, your springs won't be going into negative arch as much at full bump, and since you got E30's, you could benefit from raising the front hanger int the frame as it will help you lose a little ride height.
    Depending on how you make your bracket and how you notch into the frame it will make getting that front hanger pivot in the sweet spot a little harder though as moving it forward/backward during setup is not going to be like traditional hangers where you can just cut tack welds and slide the hangers along the frame.
    I wouldn't worry about loosing any travel if you do it though, from the amount of free arch in those E30's I see no reason why they wouldn't droop out to 20-21" of travel before leaf separation, if your drive shaft can handle the plunge at droop.
  10. Aug 27, 2014 at 8:38 PM
    Happysmiley
    Fabien
    Northern NV
    If you have a T100/Tundra rear end you could probably mount your springs outboard of the frame rail...
    The more I think about it the more I think it's a can of worms.
    I do like when people try setting things up different but I don't know if you can get the clearance between the frame and leaves just behind the hanger without notching a lot of the frame out.
  11. Aug 27, 2014 at 8:41 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ^It won't. I had to shorten mine and still strapped it short.
  12. Aug 27, 2014 at 9:57 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Exactly with my driveshaft Any more and Id have to shorten it. Plus frenching the mounts in lowers the truck a good amount, which is the whole purpose of the E30. Theres a guy who did the same thing on TTORA. If you want i can send you the link.
  13. Aug 28, 2014 at 3:35 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    Thanks for the input guy. Sounds like its a can of worms thats probably not worth opening. I already have the TC hangers so the frame just needs a little repair and its ready to tack them up and start cycling anyway.
    Please shoot me the link when you have a chance Anthony. I know Ive seen it before but couldn't find it.
  14. Aug 28, 2014 at 6:35 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Are the 2nd Tacoma non-oem radiators prone to tranny cooler issues? I failed pretty bad and hit a jump (without a front bumper/skid plate) too hard bottoming out fully on landing and stuffed the front pushing sand into the my radiator. That bent it and destroyed it along with the fan, shroud, and broke the AC condenser mounts... definitely ran out of talent :itllbuffout:
  15. Aug 28, 2014 at 10:21 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Negative ghost rider. I got mine done before Tim offered them
    Hudson has the whole set and we were checking em out on his truck.
    I'm pretty sure you just gotta call him
  16. Aug 28, 2014 at 4:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    anyone know how to adjust the rear drums? my t100 axle drums are dragging and its very loud and annoying
  17. Aug 28, 2014 at 4:45 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    quick, maxtrac spindles for 2nd Gen Tacomas 2 wheel drive, the 4 inch lift spindle, does it add track width as well
  18. Aug 28, 2014 at 4:50 PM
    anthony250f
    Anthony
    San Diego, CA
    yes 3/4" per side
  19. Aug 28, 2014 at 5:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yeah it's the same as the tacoma. You just need a flat blade screwdriver.
    See attached.
  20. Aug 28, 2014 at 6:38 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
