Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 5, 2014 at 12:08 PM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
  2. Sep 5, 2014 at 2:33 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Is that the same one that was hacked together in its original build that was done in SoCal?
  3. Sep 5, 2014 at 2:36 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Yup!
  4. Sep 5, 2014 at 2:36 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Is the FJ running the stock rack?
  5. Sep 5, 2014 at 2:51 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    I believe so, I got an email back from Jeff Howe today regarding this actually, were kinda SOL when it comes to having someone build us anything stronger. I'm going on #4 in under 100k, all of which have been since I long traveled it.
  6. Sep 5, 2014 at 2:54 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Kinda..It got doctored up a little bit by a local company here. But on Toyota's there is not much to do to them.
  7. Sep 5, 2014 at 4:48 PM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    I plan on designing a swing steering setup at some point using a steering box and ram assist.
  8. Sep 5, 2014 at 5:13 PM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    Need a guinea pig? Lol
  9. Sep 5, 2014 at 5:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id kill for a beefier steering setup.
  10. Sep 5, 2014 at 5:52 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    So my front end lifts up really bad and its hardly drivable. Any suggestions?
  11. Sep 5, 2014 at 6:00 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    more details?
  12. Sep 5, 2014 at 6:18 PM
    JuansTaco
    Juan
    gilbert az
    Well i got it back for allignemnt and tge front just raises to the point it sucks driving. I have alot of preload because it was sitting low at rest
  13. Sep 5, 2014 at 6:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    so...take off a lot of preload?
    or you mean it rises up when you drive?
  14. Sep 5, 2014 at 6:21 PM
    JuansTaco
    Juan
    gilbert az
    It rises up as i drive down the road
  15. Sep 5, 2014 at 6:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ahhh. Interesting. Is that from too much hp? :p haha
    Or no front diff? :D
    jk
    I am going to let someone with more knowledge answer that for you. I think it has to do with spring rate but im not 100% sure..
  16. Sep 5, 2014 at 6:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahh maybe pressure too..or valving for sure.
  17. Sep 5, 2014 at 6:28 PM
    JuansTaco
    Juan
    gilbert az
    Valving isn't the issue. Sdhq said that it isn't valving. Maybe nitrogen. Or a but too much preload.
  18. Sep 5, 2014 at 6:40 PM
    DMCtacoma
    Brian
    Prescott,Az
    Almost everything
    If its lifting when you are just driving around on the street they probably didn't set your alignment right. I'm guessing your toe is off. A arms can do it but I beams are notorious for this
  19. Sep 5, 2014 at 7:09 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    So much this^^^^^^. When you go in reverse it lowers down. Your alignment it off. Take her back.
  20. Sep 5, 2014 at 7:12 PM
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    Since the lowers are not solid did they even touch the upper heims ?
    Also how much caster did you get?
