Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 8, 2014 at 9:37 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Those trucks must look so alien driving around up there in the Midwest.
  2. Sep 9, 2014 at 4:18 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Thing weighs a metric shiz ton with all the crap in the bed.
    Show boating with a limited slip. Went from soft dry sand to wet packed unloaded the outside tire and caught a rut.
    yes they do. You can only have someone tell you that thing must go through alot of mud so many times. Then try explaining to them its 2wd and wait for the blank look. Because of Silver Lake its becoming more common, we are up to more than 20 scattered around.
  3. Sep 9, 2014 at 8:16 AM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    I was talking more about the front end valving but I'm sure the weight in the bed doesn't help.
  4. Sep 9, 2014 at 8:23 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    How big is the Silver Lake Dune area? I always see the same jump/camera angle.
  5. Sep 9, 2014 at 8:27 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
  6. Sep 9, 2014 at 9:15 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    Silver lake is i believe 400 acres. There are three main spots that you usually setup to jump but all the dunes pretty much look the same.
    here are a few vids of us doing laps, gives an idea of the outside loop. Most of the jump spots are in the middle.
    http://youtu.be/MJMcERJxj6o
    http://youtu.be/BM9Z7clY5b0
  7. Sep 9, 2014 at 9:17 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Where's your video so we can critique it.
  8. Sep 9, 2014 at 10:17 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Since desert season is, right around the corner, figure I'd put some time into the truck. I need to figure out my rear spring rates before I touch the valving. 2 35"spares, 22 gallon tank behind cab. I'm 250 over 350 I think now and without spares, 2 people in the truck put it close to the bumps.
  9. Sep 9, 2014 at 11:59 AM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    How much preload do you have on it right now?
  10. Sep 9, 2014 at 12:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Damn I'd have way higher. Least 350/500.
  11. Sep 9, 2014 at 12:42 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Thinking about picking up some maxtrac spindles, are any of you guys running 285/70 with spindles or are most people running 35's when pairing lt with a spindle? I want to stay away from going to 35s.
  12. Sep 9, 2014 at 2:03 PM
    jeffz0rz
    san diego
    2". I think I'm running a 16" lower spring and an 8" upper spring. I'll know for sure in a few hours.
  13. Sep 9, 2014 at 2:04 PM
    jeffz0rz
    san diego
    I just did an install on a customers single cab with 285's. Los good.
  14. Sep 9, 2014 at 3:56 PM
    txmxer
    06 dc tacoma
    Cool thanks, just pulled the trigger. Now I just need to get my rear suspension set up and then I can install the spindles
  15. Sep 9, 2014 at 4:23 PM
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    With my MT kit right now with MaxTrac spindles 285s look super small. Once I get my kit installed I'm going to save up for 315s, with fiberglass and spindles you need 35s
  16. Sep 10, 2014 at 4:01 AM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    You guys would know more than anyone on here I think, could a 14" shock off a second gen work on the rear of a second gen? Assuming I do a bed cage and all to make it fit, would all the valving and what not work?
  17. Sep 10, 2014 at 4:09 AM
    Large
    Large Red
    Might have to make some new mounts but it's definitely possible. Idk how 1st gen rear shocks mount
  18. Sep 10, 2014 at 5:15 AM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    I'll definently be making new mounts, I was more of wondering if the valving and all would be to stiff for a first gen? I'm getting a decent deal on a set of fox 14s off a second gen
  19. Sep 10, 2014 at 6:20 AM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    Yeah, like any shock, every truck is different so I wouldn't expect correct valving the first go around. But if it's a good deal snatch em up
  20. Sep 10, 2014 at 6:41 AM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    $200 for 2 fox 14s sound like a good deal? They are monotube though
