Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 2, 2014 at 10:51 AM
    JordanSmith127
    JordanSmith127 Jordemo805@yahoo.com
    JORDAN
    SAN LUIS OBISPO & MARIN
    2017 DCSB 4X4 TRD SPORT
    ICON / LSK
    Maybe they charged you for the shirt
  2. Oct 2, 2014 at 11:12 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ha yes they did and it came to $14 with the shirt. Then I get it two days later and just looked at invoice out of curiousity and it said $14.something plus $18 shipping.... Just thought that was kinda lame. I shoulda just went with DSM like I usually do. :facepalm:
  3. Oct 2, 2014 at 11:16 AM
    JordanSmith127
    JORDAN
    ICON / LSK
    Oh shit haha i thought 18 was the total thats rediculous!
  4. Oct 2, 2014 at 11:58 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Sounds like you have a cooked ground. Have you checked the ground that comes out of the dash fuse panel ? Have you tested the power that feeds into it?
  5. Oct 2, 2014 at 12:11 PM
    Large
    Large Red
    This is a dumb question but, when you turn the key forward, nothing happens right? No radio, no headlights, no ding ding ding noise?
  6. Oct 2, 2014 at 12:30 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I'm going to test tht after class ^^ nope turn the key and nothing at all happens
  7. Oct 2, 2014 at 12:34 PM
    jeffz0rz
    san diego
    Test your leads going to your ignition for power. A surge can do really funny things to a vehicle.
  8. Oct 2, 2014 at 6:29 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    You guys have any tips installing TC axle shafts? Or know if they even fit Napa CV's? I'm about at the end of my patience.
  9. Oct 2, 2014 at 6:39 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    For a second gen? No, spline count is different from OEM.
  10. Oct 2, 2014 at 6:45 PM
    Kelvin
    Kelvin Wheeeeee
    Everything is all cut up and disassembled. Couldn't even get to a point where I'd need the snap ring.
    Good lord...$400 per CV or go cry myself to sleep
  11. Oct 2, 2014 at 6:51 PM
    MonkeyProof
    SoCal- SGV
    OEM CV's are a lot stronger over aftermarket anyways. And usually aftermarket does not have the degree of motion at the outers when compared to OEM. I don't know how the Napa version compares against stock. But the ones from Autozone and other similar parts stores all suck.
  12. Oct 2, 2014 at 7:27 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    I have 2 extra oem cv's that I pulled from an auto wrecker. $35 each. One is my spare. The other I can sell, but shipping is going to suck.
  13. Oct 2, 2014 at 8:37 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    The Napa remans are supposed to be made from OEM components. So I am told, always have a couple in the toolbox but have not ran them yet.
  14. Oct 2, 2014 at 9:33 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    I tried using aftermarket with my currie shafts, the aftermarkets were completely different sized.. :/ Had to hit a wrecking yard for a spare...
  15. Oct 3, 2014 at 12:13 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    The hard part for me was getting the shaft out of the joints. It was cake from there. Tried Monkeyproofs method of sliding a pipe over the axle and giving it a couple whacks on the ground. Popped off the joint in two tries.
  16. Oct 3, 2014 at 4:05 AM
    Large
    Large Red
    And the battery is good? You have a loose / no connection from your ground or hot to the ignition.
  17. Oct 3, 2014 at 7:02 AM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Did the pipe trick to. 2 hits and the axle came out. Not sure shy people cut, rebuilt 8 shafts so far for friends and every single one popped out with the pipe trick.
  18. Oct 3, 2014 at 7:49 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    to add to this, are you still getting 12v when your turn the key at the battery?
  19. Oct 3, 2014 at 10:00 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ok, am I missing anything?
    Camburg LT
    Camburg Secondary Shock Mount
    King 2.5 8" coilovers with R/R
    King 2.5 8" bypasses with R/R
    TC coil bucket gussets
    TC cam tab gussets
    Just gonna stick with bushing uppers for now, if my alignment just keeps getting fucked I'll look harder into heimed uppers
    Secondary question- can I use maxtrac spindles with this kit? If not I'll just order the camburg spindle, but would like to save a grand lol
    Let's keep it civil please
  20. Oct 3, 2014 at 10:02 AM
    VolcomTacoma
    Jeff
    NorCal
    Also have super bumps...any recommendations on a different bump? Or am I good?
