Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 24, 2014 at 10:26 PM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    dunno if your gonna find that anywhere, most of the lt guys run the 4.5" glass
  2. Oct 24, 2014 at 10:54 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah and it seems like anyone that runs the 4.5" or bigger either buy fenders after the suspension or dont post pics till its done atleast. I might settle for a pic of a truck with 4.5's all around with stock suspension since I could atleast get an idea of what it looks like, the closest I have found is the TLT truck with 3.5's all around before the LT kit was on.
  3. Oct 24, 2014 at 10:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have 4.5s up front and no OT. So dose adam and now Paul.
    Jason I believe had 4.5" glass all around on stock width stuff in the beginning too.
  4. Oct 24, 2014 at 11:22 PM
    350TacoZilla
    Hancock MD
    I had actually seen your sig somewhere and figured you had a mid travel setup along with the low BS wheels. I have rust starting in lower corners of bed below tail lights right where the brace meets the bedside, so rather than cut the bottom edge off like some people do or just slapping some bondo over it I'm thinking of going with fiberglass all around for rust fix/prevention, larger wheel wells for larger tires, and wider fenders instead of running $400 flares that wouldnt fix the rust. I have always liked the Icelandic style rigs and have been thinking for a while of doing a truck with low CG/ mild flex (63" chevy swap rear) and the largest tires I can fit and still have tread covered since MD cops can be sticklers for the tires sticking out (which my 265's currently do with no spacers on stock honda rims).
    not sure if you can tell in pic but the tires stick out past fenders by about 1.25" on these 16x7 honda wheels, in this pic truck is wearing worn 285's and 0 lift I ended up lifting front with spacer lift (truck just had new struts put on so didnt want to replace them yet) and building the rear packs up using chevy 52" spring packs under the stock toyota main leaf for trailer pulling duty. I just bought 4 new 265's to run truck through winter but plan to address the body/paint in warmer weather and would like to start gathering parts.
    The 2nd pic is what truck looked like with leveling kit up front and stock springs in rear, hence needing to redo the rear packs.
  5. Oct 24, 2014 at 11:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have wheel spacers to help with 35s. That's why mine stick out so much.
    Mid travel doesn't push out the wheels. The stock width UCA and LCA is still used.
  6. Oct 25, 2014 at 12:34 AM
    350TacoZilla
    Hancock MD
    Yeah I know I just meant that I thought all of the width was from the wheels and was using mid travel for flex. I figured you had 15x8 or 10's with something like 2" BS, I actually checked out your build thread (skimmed it obviously) and saw that you are running something like 2.25" of bs with the spacers factored in. I dont do any high speed jumps or anything just trail running basically and I have looked into both LT and MT setups to see if they would be worth the money or if they wouldnt give much improvement. I'm also not looking to do another sas anytime soon and like the idea of keeping the truck to where I can find replacement parts easily without having to order aftermarket parts everytime.
    Basically I'm trying to build a frankenstein of sorts also,I want to keep a full bed floor(so obviously no cages with super long travel shocks) I would like a bit more flex than stock, a nice ride on road since I will be driving the truck a good bit, and I want the truck to be repairable with off the shelf parts as much as possible. I need to keep the truck street legal in a state where lifts are pretty much out of the question given the height law, tires have to be completely covered. I haven't had a sway bar on this truck in over 10 years so that helps with the flex a bit.
    The build I have running in my head right now is-
    Aftermarket UCA's (not like they go bad often enough to worry about replacements)
    OME springs (thinking 881's but that will depend on weight)
    Probably keep my stock replacement struts since they have less than 500mi on them.
    63" chevy rear leaf setup with custom long shackles from above frame
    plate front/rear bumpers (probably fabbed pieces by a local welder I know)
    Full skid plates, I had bud built ones on one tacoma and wish I kept them.
    35x12.50-36x14.50,maybe 38x15.5 tires on 15x10-14 wheel 2.5-3.5" BS
    6.5" fenders front and 6.5" bedsides rear
    4.56-4.88 gears, locker rear, open front until I can afford a select-able locker front
    treadstone turbo manifold, t3/t4 hybrid set to a low boost level (5-7psi)
    and I might look into a bed rack for a RTT setup for camping since I sold the trailer.
    For those that need a image in their head picture the body of this first truck with the tires and height of the 2nd one.(a very famous toy)
  7. Oct 25, 2014 at 12:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You want mid travel if you want the best all around suspension with no width gains and no major mods.
    Good luck fitting 35s with 881s and screw stock stocks they suck. Get something nicer.
    63s are fine for trail. Check out IDTrucks build
    No way can you fit 14.5" wide tires even with 2" bs that are 36" tall so might as well scrap that.
    I'd also go for 5.29s over 4.88s. Especially cause your a 4banger. Turbo or not And I wouldn't do 6" flares or bed sides. Way to big. Zam15 has 6" flares up front but has long travel up front. It's pretty wide. Would be way too wide without LT IMO.
    But it's your rig. Get to building :cool:
  8. Oct 25, 2014 at 1:32 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have 35s and it doesn't run the fenders at all....after some slight cutting haha
  9. Oct 25, 2014 at 1:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha no kidding. no way would 14'' wide ones fit without LT or SAC. I cut a shit load out as it is to fit mine haha
  10. Oct 25, 2014 at 5:00 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Just did it yesterday. Installing my LT in december. This is 4.5 Glassworks with icon coilover lift. 315/75/16 Goodyear mtrs. 4.5bs with 1.5 spacer
    Still have some sanding to do to make them fit better and also need to paint them.
  11. Oct 25, 2014 at 10:41 AM
    350TacoZilla
    Hancock MD
    blackdawg- yeah I have no problems with cutting as I know its going to happen, how much just depends on tires. I have had 4.56 and 4.88 gears before in 3rz manual trucks with 35's and the 4.88's were about as low as I would go for a street truck but again that depends on tires that I end up with also. As for never fitting 14" wide tires have you looked into the icelandic trucks? I have talked with couple toyota wheelers from over there and most run a 38x15.50 on stock height trucks and 44x18.50 on truck with 4-5" lift, the rest is all cutting and those monster flares (which gave me the glass fneders idea instead of 1 off flares that would need rebuilt from scratch if something bad happened) I dont want to sound like a snob but money isnt the issue with running stock parts vs aftermarket,I am no where near wealthy or anything like that but I just sold my paid for 06 tundra few weeks ago and kept a good chunk to go towards this. I just dont like the idea of being away from home sitting along a trail needing a custom part instead of one I can get a ride to local parts store and replace, yes I know that aftermarket parts are built better usually and they dont go wrong at the drop of a hat but its something I have dealt with before 8 hrs from home.
    Anthony250f- Your truck has long travel done though correct? so what hits for you might not be a problem on a stock width truck if it was running same glass setup you have.
    Thanks for the pics ponethousand, for some reason the 4.5's just dont look that big on these trucks like they do on a 2nd gen. I like they way they look but dont seem to provide much extra coverage vs a set of bushwackers, it looks like your stock rear flares almost cover your tires in those pics.
    I think I will probably just have to go ahead and spend the $$ on fenders then just build truck to suit them, I wouldnt mind 4.5: setup with a 35x12.50 tire on 8" rim under truck but I have had that before with simple lift and warn flares so it wouldnt be something all that new or radical looking. I was just hoping I could find more guys running the 6.5 fenders to get better idea of what they would look like.
    Which brings me back to the question of who to buy the glass from, Mcneil is a bit cheaper on price and I kinda like their front fenders looks a bit more than the glassworks but the whole 2 weeks with no reply bugs me from a customer service outlook. Is there any place else that does a 6.5 set without the whole 05 tacoma conversion or 1st gen tundra conversion clip.
  12. Oct 25, 2014 at 2:00 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    4.5" glassworks. mid travel. 285-70-17. 1" wheel in front.
    IMG_6371_acbf2f0a419b41f3b44990c2ce5a63f05a08dce2.jpgIMG_6370_723d762bfa866597ed11f8c9d34e28f4ac0dc3e1.jpgIMG_6380_1cb8945b8a0a24b88a5ae7f76af042cde2dce765.jpg
    if youre installing a lift kit on your rig, you need at least longer shocks in the rear or you wont have full flex on down travel. 6" fenders IMO look horrible on most trucks. a lot of long travel trucks cant even pull it off.
  13. Oct 25, 2014 at 2:15 PM
    SanClemTaco
    Sean
    San Clemente
    i would do it the other way. build your truck how you want then get glass or flares to fit the build.
    also heads up 35x12.5 rub the frame on first gens (at least mine did even with 1.25" spacers) any larger and you may not be able to turn much
  14. Oct 25, 2014 at 2:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i gotta ask how many of the iceland trucks you see with 15-18'' wide tires are 1st gens though? 2nd gens are different and from what i have seen that is what most of the iceland style trucks are. 2nd gens can fit 35s like 1st gens fit 33s. Just a bit of hammer work and fender cutting. Not rebuilding the whole fire wall. Im telling you, you won't be able to fit a 15'' wide tire on a 1st gen without pushing the tires super far out. I cut part of my door hinges just fitting 12.5s on an 8'' rim. And i still rub on the frame with 2.25'' BS at full steering lock.
    If they do fit, you won't be able to turn very tight at all..
    But for the Glass question, lots of people here are very happy with thier Mcneil glass. Glassworks is still the undisputed best looking glass, but they have a horrible rep for shipping. Some people never even get their fenders after waiting up to a year. And others get it the next week no problem. So kinda a gamble with glassworks. Mcneil is pretty solid all around though.
    Fiberwerx is another company to check out although honestly no idea if they make 6'' glass. But thats what i have up front.
  15. Oct 25, 2014 at 2:56 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    2 more days and he'll be sitting by his own :)
  16. Oct 25, 2014 at 3:04 PM
    SanClemTaco
    Sean
    San Clemente
    PRETTY!
  17. Oct 25, 2014 at 3:20 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Not yet. I found out that I need a new cylinder head. Cylinder #1 has low compression. First new head then I will address the intake.
    Thanks
    Cant wait to put those on the truck. Thanks for giving me such a good deal.
    Thanks Brian. Maybe one day it will keep up with your race truck if you take it easy. Well maybe if I can learn to drive my little reg cab as well:D
    Thanks Micah!
    Haha. I wish but until this rear-end breaks my mod money is needed elsewhere on the truck.
  18. Oct 25, 2014 at 3:47 PM
    350TacoZilla
    Hancock MD
    magikbean- TY for pics it helps to just see different combo's and your truck looks good for the height an tires. I also get the same feeling as before about the 4.5's not being big enough since a 285 is what I ran on this truck with 0 lift 0 spacers and just the stock honda wheels and they just barely poked out, your running stock FJ wheels with 4.75 back spacing and 1" spacers up front right? It looks like your tires are completely covered but thats not a very wide tire or a wide wheel with low back spacing so I dont think you could go to a much wider wheel/tire and still be covered by the 4.5's.
    sanclemtaco- I ran 35x1250x15's for years on my taco's (including this one in a previous build mode) on a old school set of Ar-23 15x8's with 3.75 BS with no frame or body rub after doing the normal pinch weld cut and fold, I know you said about spacers but not sure what your wheels BS is to start to get idea what you overall BS ends up at.
    Blackdawg-Fiberwerxonly has 4.5 for 1st gen and glassworks says their fenders are radius'd for a 37" tire, where Mcneil doesnt say and hasn't responded but I'll try calling again.On the iceland thing I dont think they got the first gen taco in iceland only hilux-4runner then started getting 2nd gens imported with hilux-4runners being available at dealers still.
    I'm not saying that with the glass I can bolt 38x15.50 on 15x14 bart super truckers and have no rub on a stock truck, I'm just trying to see what coverage they really provide and how the fenders look on a few different trucks instead of the stock photo's being the only ones I find. I am prepared to do any mods required to get tires to fit but I'm trying to stay within the law on some things (height goes by frame, tires must be covered etc) I know that many people run 33-37 tires on a LT truck and usually stick to the 12.5 width but that doesnt help get a visual of what a stock track width truck could cover with those same fenders. I would be perfectly happy with a 35x12.50 of 315/75 if they fill the 6.5 fenders but I didnt want to go getting the 4.5's only to find I have to run the cheapie pacer flares on them to remain legal.
    On the 1st gen vs 2nd gen my moms 06 trd 4x4 barely clears 265/75/16 tires on the stock rims... so if they can make room for monster tires I dont see why I can't.
    I hope this can give a bit more insight into the look I'm after and how it isnt completely insane to think I can clear a 35-38 with my current 3" lift and the glass. This is a 1990 4 runner (which have smaller fender openings than a 1st gen taco. He says he has 4" body lift only, 38" dick cepeks on 15x14 wheels.I'm not sure on back spacing though.
    this is same truck with lift and fenders but only 31's on 15x8's to give idea of height truck sits without the tires.
  19. Oct 25, 2014 at 3:54 PM
    350TacoZilla
    Hancock MD
    enigmadsm- I will do firewall mods, move mounts (both body and spring since 63" chevy swap requires it), notch frame, mod the new fenders etc pretty much anything I need to but I can't change how wide the fenders are and how much coverage they actually provide. But I dont think you are getting my thought process and maybe its me that off but... If someone is running a 5" over Lt with 8" wide tires and they are covered perfectly and dont look goofy under 6" glass than why couldnt I run 0 extra arm length and put that 12" total width all into the tires (which a 14.50 tire is usually only a true 12-13 wide) and still not look goofy
    do you have a link to juan's build? maybe he has a pic with just fenders before LT was done?
  20. Oct 25, 2014 at 5:41 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Eh, I could fit 38's on a stock 5 lug with enough sawzall blades. Everyone told me there was no way to fit 37's at full stuff on my truck, but I can. I think I could stuff 40's lock to lock if I redid the firewall or stretched the frame a little. Btw, my 2nd gen is 91" wide in the front. Stupid 3" backspacing. :eek:
