Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 16, 2011 at 5:09 PM
    #4761
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    could be th bumper moving too. the 3 i have on my bumper (one is the one i bought from you) vibrate, but the ones on my roof don't budge.
  2. Aug 16, 2011 at 5:12 PM
    #4762
    rcfreak201
    rcfreak201 Well-Known Member
    is it possible to make a new mount like the hellas? since they have double bolts and those dont budge!
    btw how do you like it?
  3. Aug 16, 2011 at 5:14 PM
    #4763
    ATriplett513
    ATriplett513 Well-Known Member
    Phoenix, AZ
    2011 Dbl Cb, 4x4, 4.0L, 6-speed
    The driver was KO-ed. I saw that somewhere else and it had the full story attached to it. Blacked out after it rolled and the driver slammed the gas down.
  4. Aug 16, 2011 at 5:17 PM
    #4764
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    What do your tabs look like? I had the same problem on my hellas, Then a shop told me to use a bigger tab like the hella 4000 tabs.
    http://www.kartek.com/product/fabrication/LightTabs.html
    PRM-04152
    The vibrations went away.
  5. Aug 16, 2011 at 5:23 PM
    #4765
    rcfreak201
    lemme go take a pic of one, stand by...
  6. Aug 16, 2011 at 5:28 PM
    #4766
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Question:
    Are any of you 2wd second gen guys, either LT or mid travel running a slip joint in the rear piece of the driveshaft? My center support bearing is pretty much toast. I took it to a shop today and he said that the rear end is trying to pull the first piece of the shaft. Said the slip joint would help. If you have had this done how much did it cost. I have the new carrier bearing. He quoted me $350 to swap the bearings and add the slip. I don't think that had u joints included. Should I get all 3 new anyway? If yes, then greasable splicers?
    I'm hoping this will fix the issue. This is also what I would need to do anyway for a rear spring under setup right?
  7. Aug 16, 2011 at 5:30 PM
    #4767
    jdkeller
    Jonathan
    Inland Empire, Ca
    I have almost 70k miles. And a midtravel setup with spindles. Thanks.
  8. Aug 16, 2011 at 5:31 PM
    #4768
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    You pretty much have to run a slip joint if you're going to run a rear LT Setup as the driveshaft needs someway of shortening up with all the uptravel.
    As for the carrier bearing I'd check this out:
  9. Aug 16, 2011 at 5:36 PM
    #4769
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    wish i could tell you. welded on my center tab, mounted it, and wired it up. unfortunately i didn't have any time to aim it before heading out for wheeling last weekend, so when i got there it was aimed straight down :eek: seemed bright though lol. just got around to reaiming it a couple hours ago so we'll see next time
    looks good at least.
  10. Aug 16, 2011 at 5:38 PM
    #4770
    rcfreak201
    looks good haha thats alot of light!
  11. Aug 16, 2011 at 5:39 PM
    #4771
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    garantees you always get the leader spot on the night runs ;)
  12. Aug 16, 2011 at 5:40 PM
    #4772
    rcfreak201
    hey pho, heres a pic from the side
  13. Aug 16, 2011 at 5:43 PM
    #4773
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    My old tabs looked like those, once I put the other tabs on the vibrations went away. What kind of lights are you running?
    It was Mckenzies who told me to use a tab with some vertical supports.
  14. Aug 16, 2011 at 5:45 PM
    #4774
    rcfreak201
    like nelson said, cheap ass china HIDs
  15. Aug 16, 2011 at 5:48 PM
    #4775
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea I had read that. So as long as I get that slip added I can mount that bearing on? I'll have the driveline shop do it so I don't want to take it to them and tell me it won't work.
  16. Aug 16, 2011 at 5:50 PM
    #4776
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I think its a combination of the lights being plastic and those takes are just flat. My tabs are formed to the bar so its reinforced.
  17. Aug 16, 2011 at 5:51 PM
    #4777
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    I would try the Tabs, I was reading somewhere about people saying those lights have some vibrations to them because of the design for vertical adjustments.
    Tabs Im running.
  18. Aug 16, 2011 at 5:52 PM
    #4778
    rcfreak201
    yeah i figured the plastic mounts played a role in this
  19. Aug 16, 2011 at 5:52 PM
    #4779
    rcfreak201
    ill do that, thanks man
  20. Aug 16, 2011 at 6:00 PM
    #4780
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I made my own, they work just fine!
