Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 18, 2011 at 8:39 AM
    #4861
    rcfreak201
    rcfreak201 Well-Known Member
    dude yesterday at my work i saw a dude and i couldve sworn it was you he even complimented my truck outside, do you have a twin we dont know about?:anonymous:
  2. Aug 18, 2011 at 8:47 AM
    #4862
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    all good no worries:)
    im getting so impatient without my truck!
    :annoyed:
    i want it back so bad.. im so bored when i have nothing to do for the day.. i dont know what to do since i have a car that has 2 inches of clearance lol
  3. Aug 18, 2011 at 9:03 AM
    #4863
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Lower it.
  4. Aug 18, 2011 at 9:10 AM
    #4864
    97yota4wd
    Eric
    Mesa, AZ
    lol this car has over 300k miles on it im not touching a dam thing. everything is probably so fragile lol
  5. Aug 18, 2011 at 9:11 AM
    #4865
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I say just go through the dez at speed. It will auto clearance anything that hangs too low
  6. Aug 18, 2011 at 9:13 AM
    #4866
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    That sucks. My visors are basically just dust and dirt collectors. :eek:
  7. Aug 18, 2011 at 10:58 AM
    #4867
    bcroach78
    bcroach78 Well-Known Member
    TN
    2010 Crew cab TRD L/B S/C
    Would a set-up like this be considered long travel and would you be able to use your stock fenders with this set-up if you were on stock tires for a 2010 tacoma?
    Fox 2.0 pro serie emulsion coil-over w/ a 5/8 shaft at 8.5" travel
    King springs w/ a 600lb rate
    Bilstein 5150 in the rear w/ 8.5" travel
    Not sure which leafs to go with yet.
  8. Aug 18, 2011 at 10:59 AM
    #4868
    97yota4wd
    Eric
    Mesa, AZ
    you wouldnt need fenders with that because you are not extending your uca and lcas
  9. Aug 18, 2011 at 11:01 AM
    #4869
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    That's not lt...lt is new uppers and lowers
  10. Aug 18, 2011 at 11:04 AM
    #4870
    97yota4wd
    Eric
    Mesa, AZ
    :thumbsup:
  11. Aug 18, 2011 at 11:07 AM
    #4871
    Cr250jumper
    The moon
    50 shades of tan©
    That would just be new shocks. Long travel is a lot more $$$$
  12. Aug 18, 2011 at 11:13 AM
    #4872
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Shock travel and wheel travel are two different things. That would essentially be stock travel numbers but with better shock performance.
  13. Aug 18, 2011 at 11:14 AM
    #4873
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Another stupid question:
    Pros and cons between linking and SUA?
    And yes I have been reading, just a lot of info around.
  14. Aug 18, 2011 at 11:50 AM
    #4874
    Cr250jumper
    The moon
    50 shades of tan©
    Cost of fab on a 4 link is much more. Also 4 link you have to get a fuel cell.
    From what I have read a properly set up SUA with triple bypasses at 18" will outperform a front end with around 13-14" of travel. You have no weight in the rear vs a motor in the front. So unless you are going custom monster in the front you would not be able to see the benefits of 4 link
  15. Aug 18, 2011 at 12:50 PM
    #4875
    97yota4wd
    Eric
    Mesa, AZ
    to add to what jd said..
    your travel numbers are way heigher, have the benefit of running a coil over and a by pass shock
    ground clearance is less because of the links.
  16. Aug 18, 2011 at 12:53 PM
    #4876
    08pretaco
    az
    I bought the truck thinking to myself that its going to not look anything like is did off the showroom.
  17. Aug 18, 2011 at 12:54 PM
    #4877
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    crazy body roll with links, it'll be scary driving on the streets
  18. Aug 18, 2011 at 12:55 PM
    #4878
    97yota4wd
    Eric
    Mesa, AZ
    really? how much more than a SUA?
  19. Aug 18, 2011 at 12:56 PM
    #4879
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Even with a rear sway bar?
  20. Aug 18, 2011 at 12:56 PM
    #4880
    08pretaco
    az
    you will have to run a sway bar for DD
