Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 5, 2014 at 12:14 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    You could always try and cram it in the stock spare location. Or recess it into the bed, then you don't really lose any bed space (hypothetically)
  2. Dec 5, 2014 at 12:23 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Yeah those new 5.7 reg cab rams are sick
    Like this GMC ram lol
  3. Dec 5, 2014 at 12:27 PM
    TheStevo
    TheStevo Baja Taco Enthusiast
    Stevo
    Reno, NV
    MAGNETO
    TC +3.5 LT, Fox COs, King Bypasses, DTF SUA w/ 3x18 Quad bypass, Fox Air Bumps, Method 17" NVs, 35s, Relentless Fab custom tube bumper, skids, & sliders, lots of LEDs
    I know that would be ideal, but I think the width between the frame rails is like 32-33", so a 35" wouldn't sit down in between. I may just have to lay it flat, then when I carry my bikes, put it vertically between them. Or get a trailer :confused:
  4. Dec 5, 2014 at 12:28 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
  5. Dec 5, 2014 at 12:40 PM
    shawnphoto
    MT
    First Gen Tundra
    You can always use a joe hauler and throw a bike on the hitch. Maybe notch the rails to fit if you were really committed? Its hard to say... I have a tundra so my bed is wider. Anthony fits 2 bikes in his first gen but im not sure if he takes a spare.
    Wish i could help more
  6. Dec 5, 2014 at 12:40 PM
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    probably right about the trailer...
  7. Dec 5, 2014 at 12:41 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I have a little trailer just for my quad
  8. Dec 5, 2014 at 1:21 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    If it makes u fell better I ordered glass Tuesday from them and got 0% discount.
  9. Dec 5, 2014 at 2:24 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm just gonna go ahead and order some glass at the beginning of the year so that when I start building my new truck at the end of the year...it should probably be there by then.
  10. Dec 5, 2014 at 2:30 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'd actually rather pull my dirt bike with a mini trailer. My truck sways pretty bad when I have the rear loaded up
  11. Dec 5, 2014 at 3:11 PM
    JordanSmith127
    JordanSmith127 Jordemo805@yahoo.com
    JORDAN
    SAN LUIS OBISPO & MARIN
    2017 DCSB 4X4 TRD SPORT
    ICON / LSK
    they'll fit, they fit in the "Kansas prerunner" SMP built and I'm most likely ditching the center console/dash and door skins. but they'll fit without doing that SMP fit 4 of em
  12. Dec 5, 2014 at 3:14 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Any of the half sized rims (16.5, 22.5, etc) have a much higher load rating than a comparable "normal" light truck tire due to the bead angle being more flat. That angle is also why they have gained the reputation of easily popping a bead when ran at trail psi. Beadlocks fix that problem. All heavy duty applications still use half sizes, but as light truck rim diameter has increased and sidewalls decreased load capacity went up, which is why a lot of diesel one tons run 20" rims. The reason all those military tires are so cheap is because they are surplus and you can bid on them by the thousand for pennies on the dollar. My buddy got a train car full of them for $600!
  13. Dec 5, 2014 at 3:26 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    But why do they ditch them new-90% life?
  14. Dec 5, 2014 at 3:35 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Any one heading out to the race in Barstow tomorrow?
  15. Dec 5, 2014 at 4:04 PM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    A 35 just barely fits between the rails. On my truck I will have a full size spare under the bed. I cut out the stock crossmember and built a new one that's higher up so it doesn't hang really low
  16. Dec 5, 2014 at 4:53 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I'm buying all the tube for my cage next week, for it to be score legal does it need to be all chromoly tube? Or is DOM also score legal?
  17. Dec 5, 2014 at 5:03 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    DOM is fine
  18. Dec 5, 2014 at 5:27 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    they ditch them when brand new with tits on them if they have been sitting on shelf too long, one base told me they replace all 5 tires if more than one gets hit in battle then the other 3 go to be auctioned off.
  19. Dec 5, 2014 at 5:28 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Just remember that your over 4000lbs so you need to be at 2" to be legal. 1.75" is up to 4000lbs. If your serious about it being legal pick up the SCORE rule book and follow it to a T otherwise you may pay for a "race legal" cage and not meet your goal.
  20. Dec 5, 2014 at 5:30 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I haven't gotten the truck to a scale but whats the stock weight? I was doing 2'' anyways haha.
