Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 10, 2014 at 9:07 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  2. Dec 10, 2014 at 9:09 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    yea just get a 90degree fitting.
    edit: or 45. anything besides straight should do the trick.
  3. Dec 10, 2014 at 9:12 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I need a a fitting that will allow the biggest shock possible, maybe a 3.5
  4. Dec 10, 2014 at 9:19 AM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    then get a 90degree one..
  5. Dec 10, 2014 at 10:05 AM
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    DSM should be able to help you out, they swapped the fittings on my C/O to 90s
  6. Dec 10, 2014 at 10:40 AM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    Good luck getting your tires to clear it when articulated! On mine I had to flip the shocks so the tubes are on the frame side for a little extra clearance
  7. Dec 10, 2014 at 10:49 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I have plenty of room between shocks and tires
  8. Dec 10, 2014 at 10:51 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
  9. Dec 10, 2014 at 11:18 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Thanks man. Should have thought of that.
  10. Dec 10, 2014 at 11:39 AM
    DMCtacoma
    Brian
    Prescott,Az
    Almost everything
    I do too when sitting flat. The bypass will be a lot closer to the tire and when it articulates the top of the tire will go forward and in
  11. Dec 10, 2014 at 12:01 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    How did your 3.0 fit?
  12. Dec 10, 2014 at 12:07 PM
    DMCtacoma
    Brian
    Prescott,Az
    Almost everything
    It's tight. Like I was saying I have to have the tubes on the frame side so the tire won't run them when you get crossed up
  13. Dec 10, 2014 at 12:53 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    A cantilever setup for bypass would be sick
  14. Dec 10, 2014 at 1:16 PM
    BradyT88
    BradyT88 Well-Known Member
    This is part of the reason I ran my shocks inboard of the frame.
  15. Dec 10, 2014 at 1:45 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Me too. When you stuff one tire while the other is drooped there is not enough room outside the frame unless the axle is roughly two feet wider than stock. At least with 37's and 3.0 bypass shocks. Might be able to clear at max articulation with some skinny stockers.
  16. Dec 10, 2014 at 1:50 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    That's the reason I notched into the frame for my bypasses to angle in more to clear 35's at full articulation.
  17. Dec 10, 2014 at 1:57 PM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
  18. Dec 10, 2014 at 1:58 PM
    GoldyLocks
    GoldyLocks Well-Known Member
    Mesa az
    97 caged 4x4 tacoma, SR1 Rhino
    LOL
  19. Dec 10, 2014 at 2:01 PM
    JTS2016TACO
    Jamie
    Chandler, AZ
    :rofl: this is funny because I can actually picture you saying this.
  20. Dec 10, 2014 at 2:09 PM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    I notched my frame too so I could get extra clearance with the 3.0s, at full gnarticulation the tire is barely clear from the tubes and that's with 33s. If I make the jump to 35s I'm almost sure they will rub.
