Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 13, 2014 at 11:15 AM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Just wait on the call from Lsk... Ill let them know. You will be very satisfied.
  2. Dec 13, 2014 at 11:46 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    What are you doing for the rear end?
    The solo kit is a waste of money unless you're going to build the rear end to be able to keep up with it. Which realistically means linking it.
  3. Dec 13, 2014 at 11:57 AM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    if you build your own shock hoops and dont upgrade to the boxed upper arm the solo kit is "only" $5300
    for perspective a camburg kit with axles and parts that are included with the solo kit like heim steering; will set you back about $4400
  4. Dec 13, 2014 at 11:57 AM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Not linking it. Dmz with 16's or 18's
  5. Dec 13, 2014 at 12:04 PM
    dirt addiction
    Flagstaff
    That's what was I was thinking. I feel the extra 1000+ is worth it for those hubs
  6. Dec 13, 2014 at 1:49 PM
    Easy rider
    Easy rider Well-Known Member
    Cali
    18' T4R 4x4 LT TC 3.5 over
    I have the Solo kit and it takes EVERYTHING like a champ with the limiting factor being the rear (DMZ spring under). Both Sully1981 (he has the 4x4 19" kit) and I will be going links in the future just to try to maximize the potential of the front end. Ive heard from numerous people outside of solo about the Solo Tacoma with the satellite phone and links can keep up with about anything.
    I went the Solo route due to the kit and the reputation the shop carries. Its nice having a peace of mind with a company that has been around for 20 years.
  7. Dec 13, 2014 at 2:53 PM
    TheStevo
    TheStevo Baja Taco Enthusiast
    Stevo
    Reno, NV
    MAGNETO
    TC +3.5 LT, Fox COs, King Bypasses, DTF SUA w/ 3x18 Quad bypass, Fox Air Bumps, Method 17" NVs, 35s, Relentless Fab custom tube bumper, skids, & sliders, lots of LEDs
    Opinions please: Which would be better for a rear LT setup? a 2.5" 4-tube bypass, or a 3" 3-tube bypass? Both are nearly exact same price. (King/Fox of course)
  8. Dec 13, 2014 at 2:53 PM
    dirt addiction
    Flagstaff
    Cool man thanks for your insight, it definitely helps hearing from someone running the kit.
  9. Dec 13, 2014 at 2:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    For leaf springs?
    Why not just get 2 tube 2.5's and 2.0 air bumps instead.
  10. Dec 13, 2014 at 2:58 PM
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    Yes for a SUA kit like DMZ. I was planning on having air bumps either way. Aren't more tubes better? Or is that just overkill?
  11. Dec 13, 2014 at 2:59 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    3" gets my vote. The extra oil volume really helps them stay cool, and maintenance intervals are extended quite a bit over 2.5's.
  12. Dec 13, 2014 at 3:10 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I'd say make the call based on the weight you carry (and consequentially how much valving you'll need). Rebound valving is so light on leafs, it's just compression valving. Username is dead on with the rebuild intervals and extra oil, but I guess it will just depend on how hard you plan on beating on it.
    The other thing to keep in mind is the king 3.0 only comes with the pure race viton seals (rather than your choice of buna or viton with the 2.5s). In our climate up here, the viton seals leak in cold weather until the shocks warm up. I rebuilt my rears with viton last January and replaced them all back with buna a month later because of it.
    As for the extra tubes, sure it's nice to have more if you have the coin, but you're still gonna have leaf springs. Rebound tube(s) is going to be opened up all the way no matter what valving you run.
    I will say that I do like the larger tubes the 3.0's come with. But you can do something custom if you want. King will build anything. My rear bypasses are a 2 tube 2.5, but I have the larger pure race series compression bypass tube.
  13. Dec 13, 2014 at 3:15 PM
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    Aaah OK. Good info! Thanks
  14. Dec 13, 2014 at 4:58 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    that's me!
    *edit wait nevermind. I'm 3 tube.
  15. Dec 13, 2014 at 5:02 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    And me haha
  16. Dec 13, 2014 at 6:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This dude ^^^ is right
    You won't want the rear setup of your truck being the limiting factor. Bucking is not good.
    So unless you are gonna 4 link the rear...wouldn't get either "race" kit. The DMZ kit will never keep up with those big travel front kits.
  17. Dec 13, 2014 at 8:14 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    $6800 for front LT. without shocks!? I probably have that much into my front and rear including bed cage/engine cage.
  18. Dec 13, 2014 at 8:47 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    That's more than my truck is worth...
  19. Dec 13, 2014 at 9:09 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    The previous owner of my truck spent $12k on the rear end not including shocks or install lol
  20. Dec 13, 2014 at 9:14 PM
    dirt addiction
    Flagstaff
    Solo Base kit-3800
    Axles-1575
    Steering upgrade-375
    WIY shock hoops-700
    Double sheer kit-130
    Total $6580 + tax
