Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 15, 2014 at 10:55 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    What shackle are you running? How much weight are you carrying in the rear? What PSI are you running in your bumps?
  2. Dec 15, 2014 at 11:02 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Get a good video running through the whoops for them to watch. Or its just a guessing game.
  3. Dec 15, 2014 at 11:39 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Anyone know whats this box on the roof? And how can I remove the grey hooks?
  4. Dec 15, 2014 at 11:50 AM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    That's for your tire pressure sensors. The grey hooks just turn the 90* and pull them out
  5. Dec 15, 2014 at 12:05 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    Anyome have an axle for a 2wd first gen tundra laying around? Think I bent mine. I just need the axle with flange, driver side
  6. Dec 15, 2014 at 10:05 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    Dude...it's been so long! It took a very stupid long time to catch up from page 2897, but I'm back and starting to work on the beast again. I missed tw
  7. Dec 15, 2014 at 10:08 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    I'm sorry, 2397 lol
  8. Dec 16, 2014 at 10:30 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Found another box under the dash that says computer tire pressure monitor, so the roof one should be something else?
    Anything I should do while the dash is out?
  9. Dec 16, 2014 at 11:08 AM
    DMCtacoma
    Brian
    Prescott,Az
    Almost everything
    Nope. On is the computer and one is the actual sensor. If you look at the box on the roof it tells you that too
  10. Dec 16, 2014 at 11:10 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Got it, so it need to be there or can it be relocated? Maybe behind rear seats?
  11. Dec 16, 2014 at 11:12 AM
    DMCtacoma
    Brian
    Prescott,Az
    Almost everything
    I'm sure you can relocate it. But if you aren't using the sensors in your wheels anymore then it can go in the trash
  12. Dec 16, 2014 at 12:13 PM
    Easy rider
    Easy rider Well-Known Member
    Cali
    18' T4R 4x4 LT TC 3.5 over
    I am currently shopping for a 9" so I've been reading up on track widths and I have been seeing a lot of different answers on both racecar/off road forums. It looks like as long as I am +/- 1" front to rear I will be good to go. On my last desert truck I noticed a noticeable improvement in handling when I went with the exact same width in the rear. Anyone wider in the rear that has an opinion? I guess the biggest problem I will have is the lack of 6-7" rear fenders for our trucks.
  13. Dec 16, 2014 at 12:43 PM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    go an inch or two narrower in the rear than the front, as the front cycles it becomes narrower. your looking for the average width of the front out back, but measuring for that takes a while and it will never be perfect
  14. Dec 16, 2014 at 12:47 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    My old 9" axle was 69" , 4.0" bs wheels running 35"s and at full bump they barely kissed the Glassworks fenders I was running. However they stuck out past the fenders a few inches. Wider glass would be a good idea.
  15. Dec 16, 2014 at 2:23 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    I think I'm going to be about 2 inches narrower in the rear then I am in the front, giggity. do you plan on running bumps? If so, you need to locate those bumps as far out on the axle as possible, taking into account clearance issues at full articulation. You want the bump to bump as far out on the axle as possible to aid in less of a chance of finding the housing. I've seen where the narrow framed Ford Rangers are bumped inside the frames with an Econoline housing. That's recipe for a bent housing.
  16. Dec 16, 2014 at 3:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    What's this tire pressure monitoring thingy?
    What's traction control?
    Just unplug all the nannies and drive.
  17. Dec 16, 2014 at 4:11 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Same with ABS, I ripped that whole module out
  18. Dec 16, 2014 at 4:12 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Thats what I want to do, that shit is just taking up space.
  19. Dec 16, 2014 at 4:13 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Oh...you mean this thing?
  20. Dec 16, 2014 at 4:17 PM
    Supermoto
    Landon
    Fallbrook
    Yep just threw a control valve where that was to control front to rear bias
