Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 4, 2015 at 7:54 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    The machined blocks are what transfer the force down to the slider. The clevises are how the tie rods attach to the blocks on either end
  2. Mar 4, 2015 at 7:56 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Woop, there it is.
  3. Mar 4, 2015 at 7:59 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    This slider isn't completely done. The center tube needs to be mated to the frame.
    It pulls some of the force off the rack and transfers it to the other end like a swing steering setup. Helps with people who blow seals and break housings
  4. Mar 4, 2015 at 8:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Gotcha. I'm just not seeing how the clevises attach in my head..
  5. Mar 4, 2015 at 9:08 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    Fuck i need to take a few days off of work and do this already
    Would make a huge difference as far as longevity goes if the rack just has to worry about pushing and pulling
  6. Mar 4, 2015 at 9:15 PM
    shawnphoto
    MT
    First Gen Tundra
    Just saw this last page after i last posted... come on guys
    They are normal clevises that thread onto the inner tie rod end, and a bolt goes through the heimed tie rod. Except now there is a block that encloses both sides, with the bolt going through it too, that connects it down to the slider. Stabilizes the ends against sideways forces.
    The picture itself is pretty self explanatory imo, just think about it... its kind of like double shearing stuff i guess if you really had to simplify it
  7. Mar 4, 2015 at 9:50 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    who here has replaced the 1st gren ps pump? mine whines baddd...or is it the rack?
  8. Mar 4, 2015 at 10:05 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    If you hear a whining noise its probably the pump, try adding some more fluid. That solved it for me at least temporarily. If the rack boots are full of fluid or leaking its going out. My new rack from rack doctor gets here tomorrow, my rack is pretty bad!
  9. Mar 4, 2015 at 10:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If there is a clevise through the ITRE..how is it attached to the steering extension?? That where im confused..:eek:
    you sure its not just your belt and its just loose?
  10. Mar 4, 2015 at 10:14 PM
    anthony250f
    Anthony
    San Diego, CA
    the rack doesnt leak at all and feels really good...it whines even at idle and gets really loud going slow and turning...ill check out the belt
    already changed the fluid and made sure its topped off
  11. Mar 4, 2015 at 10:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Mar 5, 2015 at 5:41 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I also had some real bad whine from mine. Especially during the winter. I was thinking about replacing it until I found out how much Toyota wanted for one. I threw in the royal purple stuff and it took away the whine and been working fine since. It's an option.
  13. Mar 5, 2015 at 6:48 AM
    anthony250f
    Anthony
    San Diego, CA
    Royal purple atf ? My pump has 240k on it so maybe it's time haha...found them only ing for about 100$
  14. Mar 5, 2015 at 7:17 AM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    I used amsoil atf for my Chevys pump
  15. Mar 5, 2015 at 7:45 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah I also have over 200,000 on mine as well. It started with a minor whine while turning. Then it just got worse. Every time I turn on the truck it would whine until it warmed up. I figure a bottle fluid was worth a try. It was a while back when I added it but it was just royal purple power steering fluid. If you google it I'm sure you'll find it. About 10.00 a bottle. Worse case it doesn't help and you buy a new pump. Good luck bud.
  16. Mar 5, 2015 at 7:57 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Thank you for this :thumbsup:
  17. Mar 5, 2015 at 8:26 AM
    anthony250f
    Anthony
    San Diego, CA
    I heard it's bad to use ps fluid in our pumps.. I was considering taking the res off and cleaning it out. It wines bad even when idling and revving it...after 35s it's gotten worse. Somedays I hardly hear it though
  18. Mar 5, 2015 at 8:46 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    its probably your pump. mine blew up in moab:)
  19. Mar 5, 2015 at 9:16 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ok :thumbsup: good luck with the fix.
  20. Mar 5, 2015 at 9:16 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you're supposed to use atf in them only
