Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 22, 2015 at 9:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Don't really price out stuff for Icon, but I doubt they are nearly half the price of King shafts.
    No. Just nomenclature/verbiage from one guy to the next. Same shit.
    Emulsion shocks are nitrogen charged too. Emulsions don't have a dividing piston (IFP) to separate the nitrogen cavity from the oil cavity. Bumps for all intensive purposes are emulsion shocks.
    Seal kits are roughly $25-30 each. You'll need about a half gallon of oil. They don't sell half gallons so you're looking at about $35 for oil. Last I checked, King shafts started about $60 each depending on length. And if you don't have a nitrogen setup, plan on $20 per shock to charge, maybe more if they don't already have an Icon hypodermic needle adapter to charge them. So you're looking at least at $250 if you rebuild them yourself. This assumes nothing else is wrong. With as pitted as the shafts look, the likelihood of spherical bearings being worn and/or pitted is high. That's another $15 each (2 per shock). Given at least one is DR, I can only assume the wear bands are toast by now. That's another $15 each. Again given the age, I automatically assume the springs are clapped out, that's another $100 each (springs are consumables). And unless you like shocks that look like shit, plan on the little things like steel wool, wd-40, clear coat, thread locker, etc. And...that's assuming everything else else is fine (seal cap, piston, valve shims, etc).
    You can do the math as well as I can, and that's assuming you do the work yourself. But to put things in perspective, a brand spanking new set of non-resi King shocks are less than $1000.
    Oh and if you're not doing the work yourself and shipping them, don't forget about shipping costs. Coilovers aren't light. Plan on at least $60 each way.
  2. Mar 22, 2015 at 10:20 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Yeah you're right, just checked the invoice. Got priced out at $55 each + labor.
  3. Mar 23, 2015 at 7:56 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    2"over LT kits use the same 8" Coilovers that regular 3.5" over kits use right? I feel like I remember someone on here saying otherwise but I'm not 100% sure
  4. Mar 23, 2015 at 8:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Short body 8s yes. Same shocks.
  5. Mar 25, 2015 at 5:10 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
  6. Mar 25, 2015 at 5:36 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Looks like that's just for the locker
  7. Mar 25, 2015 at 7:42 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    how imperative is it to have the tc rack bushings?
    mine were clapped so i threw the new rack in with the stock bushings
    how shitty is that going to be for it in the dirt? seems like quite a bit more movement in the rack with the stock bushings
  8. Mar 25, 2015 at 7:49 PM
    biggie
    biggie Well-Known Member
    Collin
    Tucson
    02 LT Xtra Cab
    anybody used 16" springs on 8" coilovers?
  9. Mar 25, 2015 at 8:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats the standard size for 8'' coil overs.
  10. Mar 25, 2015 at 8:04 PM
    biggie
    Collin
    Tucson
    02 LT Xtra Cab
    ok thats what i was thinking but was wondering why everyone was looking for 14"
    thanks
  11. Mar 25, 2015 at 9:18 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Take any coilovers travel length and double it, that's the standard coil length
  12. Mar 25, 2015 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    14s go on standard or extended travel coil overs. Not for long travel
  13. Mar 26, 2015 at 2:54 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    I have 14s :notsure:
  14. Mar 26, 2015 at 2:55 PM
    Manwithoutaplan
    ID
    How is the new axle working out for you??
  15. Mar 26, 2015 at 3:12 PM
    JuansTaco
    Juan
    gilbert az
    Saving for a locker for it then going to truss it and install it on the SUA now.
  16. Mar 26, 2015 at 3:14 PM
    Manwithoutaplan
    ID
    ahh ok. what kinda locker you going to install. Lunch box? Detroit ? or ARB ?
  17. Mar 26, 2015 at 3:22 PM
    JuansTaco
    Juan
    gilbert az
    Detroit most likely. And since the third is In pieces that's why I'm going to wait. So I don't have to pay 2 times to get it installed
  18. Mar 26, 2015 at 3:24 PM
    Manwithoutaplan
    ID
    make senses. Good choice on Detroit Tried and true.
  19. Mar 26, 2015 at 3:58 PM
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    Yeah Juan, We have been running Detroit Lockers since early 2000's. Good product, we have never had any issues over the years.
  20. Mar 26, 2015 at 3:59 PM
    Manwithoutaplan
    ID
    What kinda of diff fluid you use in your race truck??
