Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 5, 2015 at 7:37 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I bet there is a reason that airing the tires down voids the warranty.
    http://www.treadwright.com/what-remold/faq#q1
    Any time some company says using their product in a specific way voids your warranty, but then goes on to tell you who has done it and its going to be fine is shady as shit to me.
    Crawling I wouldn't be concern with in the slightest, only trusting my life to a tire that the company won't stand behind aired down. I go too fast to run a tire that may not perform under those conditions.
  2. Oct 5, 2015 at 9:45 AM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    sorry for the mis-info, so are you supposed to pre-heat forged steel before welding?
  3. Oct 5, 2015 at 11:47 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Throw it in an oven or on the grill!
  4. Oct 5, 2015 at 11:54 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    okay next time ill definitely preheat. Thank you.
  5. Oct 5, 2015 at 12:02 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Is it possible to weld spindles with a stick welder and 7018 rod? Or does it have to be mig. Of course with the pre heat.
  6. Oct 5, 2015 at 12:12 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    You don't need to preheat forged steel but it doesn't hurt anything if you do.
  7. Oct 5, 2015 at 12:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You should always preheat super larger chunks of steel before welding small pieces to them. That way the full thing is hot instead of suddenly making part of it very hot and causing warp.
    shawnphoto, jberry813, Canks and 2 others like this.
  8. Oct 5, 2015 at 12:50 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Did anyone see the new commercial for the 2016 tacoma? Its a bunch of dirtbikes and the tacoma goes from the highway to offroad in the desert (looks like barstow or ocotillo), and the trdpro is doing the mid travel thing while a bunch of bikes do wheelies and hit a few jumps.
    With the weather cooling down im getting the itch to get out to the desert
  9. Oct 5, 2015 at 1:44 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    http://toyotanews.pressroom.toyota.com/releases/2016+tacoma+marketing+campaign.htm
    Expect to see more clips of the Tacoma doing Tacoma things. Such dirt, much wow..
    txmxer[QUOTED] likes this.
  10. Oct 5, 2015 at 4:06 PM
    JawKnee
    JawKnee I <3 Pink Tacos
    Ontario Ranch
    2002 Tacoma
    Total Chaos, DMZ, Deaver, Sway-Away, KMC, BFG, Hella, ICOM, BTF, Glassworks, Trac Performance, Lowrance.
    Any pictures of the rear end? Trying to get ideas for my FJ Cruiser.
    nelson18matt likes this.
  11. Oct 5, 2015 at 4:11 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I'll try and find some. It's a 4 link rear.
  12. Oct 5, 2015 at 6:58 PM
    doyouquaxu
    doyouquaxu Well-Known Member
    I bet every other tire mfg has something similar on the books, it's a cover your ass type of deal.
  13. Oct 5, 2015 at 7:16 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    I spent 30 minutes this morning searching BFG, Goodyear and General and didn't find anything on their sites about it. Unless my google kung fu was off.
    I could imagine that Treadwright could tell by tread separation if the tire was aired down.
  14. Oct 5, 2015 at 7:28 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    I deal with retreads daily at work, most rear tires on semitrucks are retreads. The number one cause for tire blowouts on them is running low psi. Not saying that it will happen on a lighter weight truck, but something to be aware of
    BenTheMan and nelson18matt like this.
  15. Oct 5, 2015 at 7:35 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Wait....what? Spend $10,000+ on suspension and then decide on retread tires?
    -40, dakotasyota, DIRT YOTA and 9 others like this.
  16. Oct 5, 2015 at 8:37 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    :confused:
  17. Oct 5, 2015 at 8:44 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    o_O
    Cliff notes:
    Why save a couple hundred bucks on something so crucial after spending so much money...:crazy:
  18. Oct 5, 2015 at 8:53 PM
    VolcomTacoma
    Jeff
    NorCal
    No, i get it, I'm confused as to why someone would do that as well lol
  19. Oct 5, 2015 at 8:54 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    credit cards have limits
    atvlifestyle, weldertaco and 06HAOLE like this.
  20. Oct 5, 2015 at 9:09 PM
    VolcomTacoma
    Jeff
    NorCal
    Oh my. Indeed they do. Weird, I usually just save up the cash for most stuff...
