Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 9, 2015 at 1:05 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I know for sure BlackTacoma (Matt) here in Co has true Method bead locks and hasn't had issues here. So go for it.
  2. Oct 9, 2015 at 2:12 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Does anyone have a lead on a T-100/Tundra axle? I am looking to pick one up in the next few months.
  3. Oct 9, 2015 at 4:33 PM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Do the Enduros clear the front calipers? I know you haven't driven it but I know the DTF team was running them before. I'm running a 5mm spacer and shaved the spacer and still rub on them from time to time when I don't carefully center the wheels since they aren't hub centric. Sometimes I wanna sell them because of that and switch to a hub centric beadlock but I think most are already pre-bored for race hubs.
  4. Oct 9, 2015 at 5:11 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
  5. Oct 9, 2015 at 6:26 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    find a shop with a 20 ton press it will shear the clip. Do not try it with a smaller press it will bend the press
  6. Oct 9, 2015 at 6:46 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    If that doesn't work take it to a machine shop, they can bore the axle out, I had to put mine on my lathe and do it, stubborn
  7. Oct 9, 2015 at 7:35 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Its cool they came to the midwest and filmed. It was a good time, just sucked when Neal rolled. Made for great video and an interesting evening.
  8. Oct 9, 2015 at 9:41 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    X2 on omf. You can pick any wheel and they will hook it up with some rings to go with it. But they are $$$ my 5 rings and rock domes were 750$ but I got them for 300$ shipped cause they already had them made and were sitting forever. Deffenilty different style. But I also x2 on the Walker Evans and xd enduros. If I didn't get the rings I would have gone with either one for my next set
  9. Oct 9, 2015 at 11:11 PM
    Basikbiker
    Trav
    The YouTube way don't work
  10. Oct 9, 2015 at 11:24 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    The pipe method has worked for the 6 axles I have done so far.
    dakotasyota and Ahshiet like this.
  11. Oct 10, 2015 at 12:00 AM
    Basikbiker
    Trav
    Luckyyyy I wish mine did, I mushroomed sum scrap DOM trying
  12. Oct 10, 2015 at 4:46 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Sorry I'm late back to the party. Duty calls sometimes.
    The theory behind it is called off-tracking. The amount of off-tracking is defined as the delta between the inside turning radius of the front tire and the inside turning radius of the rear tire. The sharper the turn and the longer the wheelbase, the larger the off-tracking. Picture the top view of a vehicle turning. The rear wheels do not follow the same path as the front wheels. The rear wheels follow a shorter path because the turning radius on the rear wheels is less than the front. Using a rear axle that is slightly narrower reduces the overall off-tracking without any perceivable wonkey handling differences.
    And comparing a mustang to a long travel truck? While you're checking track width on that mustang, maybe check to see if it has sway bars.
    dakotasyota and thekernel114 like this.
  13. Oct 10, 2015 at 5:54 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Im about to throw my TC UCA together. It says to grease that bushing before inserting the sleeve. I have a moly and non moly grease. Which one should I use. Or does it even matter.
  14. Oct 10, 2015 at 8:30 AM
    jeffz0rz
    san diego
  15. Oct 10, 2015 at 9:51 AM
    triple6
    triple6 Well-Known Member
    oli
    Fallbrook, CA
    04 Double Cab Stock ;)
    all beaneer designz
    sent you a PM
    06HAOLE[QUOTED] likes this.
  16. Oct 10, 2015 at 10:16 AM
    jeffz0rz
    san diego
  17. Oct 10, 2015 at 10:48 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lithium based moly. Anything else increases deterioration of poly bushings.
    SilverGhost[QUOTED] likes this.
  18. Oct 10, 2015 at 12:18 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Hey if I add the other washer in there it leaves a decent size gap between the gusset and the tower. But if it set it up like this it sits pretty flush. Is there going to be any issues setting it up like this?
  19. Oct 10, 2015 at 12:33 PM
    Basikbiker
    Trav
    It's supposed to be ran without the outside washer, says so in the instructions too BTW
  20. Oct 10, 2015 at 12:38 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Think of it this way. The gusset is now your washer.
