Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 9, 2015 at 10:28 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    You're literally two days too late, we took 285/70/17s off our other truck and I offered up the old ones for spares on this thread.
    I'll have 2 285/75/16s I could hold onto as spares if anyone needs them but they pretty worn. Better than no spare though
  2. Nov 9, 2015 at 10:34 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yes, the way the outer tie rod bends it will hit the bypass mounts when you turn full lock. When you swap them it bends outwards and gives just enough clearance. Camburg flips them too
    SilverGhost[QUOTED] likes this.
  3. Nov 9, 2015 at 11:03 AM
    Motomon
    Motomon Woof
    Central Coast, CA
    stuff and things
    Dang - I get so behind on this thread since I don't check it very often.
  4. Nov 9, 2015 at 11:09 AM
    txmxer
    06 dc tacoma
    Sorry! If you want a 285 75 16 ill tell the tire shop to hold onto one or two tires and you could have it for free. Discount tire charged me/sent me two extra 285 70 17 nitto all terrains. I was going to return them but if for some reason they dont return or something like that, ill let you know.
  5. Nov 9, 2015 at 11:49 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    From what I read 60-65" is about the longest you can go with a one piece, right?
  6. Nov 9, 2015 at 12:11 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    70"
    Kerleyfries[QUOTED] likes this.
  7. Nov 9, 2015 at 12:15 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    But just be aware it is much larger diameter than the OE shaft which creates more fun with clearance issues at the carrier bearing cross member and the other odds n ends I mentioned....ask me how I know
  8. Nov 9, 2015 at 12:19 PM
    Motomon
    Motomon Woof
    Central Coast, CA
    stuff and things
    Where are you located? Maybe I can ask my local shops for takeoffs?
  9. Nov 9, 2015 at 12:27 PM
    Kerleyfries
    Zack
    Lebanon
    This is my concern with it being too long. But I also question if our little our trucks will put enough strain on a DS to warrant that increase in thickness?
  10. Nov 9, 2015 at 1:24 PM
    Basikbiker
    Trav
    They can mess driveshafts upp, especially in 4lo... @Evenflow what did you do to get the brake cables out of the way? Crossmember I plan on making a new one? Out of 1.25" DOM? What leafs you running?
  11. Nov 9, 2015 at 1:28 PM
    txmxer
    06 dc tacoma
    I live in Riverside
  12. Nov 9, 2015 at 3:01 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have a 3 link rear but regardless of leaves or links I think everyone's goal is to bump as close to the frame as possible and a one piece drive shaft is not going to let you do that w/o completely removing that cross member. When they make a one piece they use 4" vs the OE 3" ...it's huge. With a one piece there is no way you could build a new crossmember out of 1.25" the drive shaft would hit it while your axle was still a long way from bumping as high as you would want it too. From my experience I would suggest just sticking with a two piece.
    I am still working on the cables, the brake cables seem like they can easily just be clamped out of the way but the shift cable is going to have to be relocated because it comes through the floor too close to the drive shaft.
  13. Nov 9, 2015 at 3:10 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    The way the guys at Tom Woods explained it to me is that it is a simple matter of how stable the tubing is a what length and RPM's. So as the shaft gets longer it must be larger to remain steady at higher RPM's. You should call Tom Woods, they are very well known and are great about taking time with you over the phone to ensure that you are getting the right thing. I went with a one piece when I had a taller lift and was sick of dealing with carrier bearing issues and vibes. From what I have run into lately going to a long travel set up I would have been better off keeping the two piece.
  14. Nov 9, 2015 at 3:49 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Can you put a one piece on a 2wd with the slip yoke on the diff end? That's double slip yokin' it. I have the slip yoke on the diff end with a CB. Replaced the CB twice now only because I've failed to lube the slip yoke.
  15. Nov 9, 2015 at 3:55 PM
    Kerleyfries
    Zack
    Lebanon
    I gotcha. I'll give them a shout or might try to get ahold of a shop that specializes in LT and see what they recommend. I'm not going to be LT for a year or two, but I don't want to have to redo my driveshaft twice. Haha.
  16. Nov 9, 2015 at 6:01 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You don't do your driveshaft until you already have your long travel on so you only do it once
  17. Nov 9, 2015 at 6:56 PM
    Kerleyfries
    Zack
    Lebanon
    Well I need a new carrier bearing and if Toyota is gonna charge me $200 for one plus new ujoints, then I might as well do the whole thing right the first time. lmao
  18. Nov 9, 2015 at 7:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you won't be doing it right if you have to redo the drive shaft after LT...that's his point.
  19. Nov 9, 2015 at 7:17 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    you wont have to re do it...if you do it now youre fine for now....and with lt
  20. Nov 9, 2015 at 8:24 PM
    Kerleyfries
    Zack
    Lebanon
    Sorry, I misunderstood. I was reading through this while studying and guess I was still in calculus mode. lmao
