Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 16, 2015 at 9:57 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    I would beat it into submission, as close to normal as you can get it, and then just weld it up.
  2. Nov 16, 2015 at 10:35 AM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    02 Prerunner & 08 Prerunner
    Johnny Branch Fabrication, King, Deaver, Glassworks, Toyo Tire, Alpine, work in progress...
    Anyone coming down to SoCal from Pismo anytime soon? I need some bedsides brought down from there. Willing to pay a good amount
  3. Nov 17, 2015 at 10:10 AM
    89ztrain
    89ztrain Well-Known Member
    North Carolina
    '11 TRD Sport 4x4
    You guys think 55" trailing arms would be a good length for a 2nd gen access cab? Looking at Ruff Stuff's right now.
    Basikbiker likes this.
  4. Nov 17, 2015 at 10:23 AM
    sirhk100
    sirhk100 Well-Known Member
    Late to the game but a few pages back someone mentioned they needed taller stands. I know these won't apply to most but those of you with a fully caged/bumpers tied into the chassis truck... I bought 4 of these a few months back and I'm kicking myself for not buying them years ago! Adjustable from 28"-53" and solid enough to support the trucks weight. I now use my engine hoist, grab the bumper, lift the truck up, slide these under the bumper and set it back down with the suspension at full droop. Front and rear bumpers support the weight of the truck and it gives me clear access not having to work around jack stands under the truck. I love these things and they're one of the best recent additions to my garage for a few hundred bucks total. Like I said, they won't work for all cause your truck needs to be built enough to support itself and lift by the bumpers but if you're there, I don't think you'll regret the purchase. I guess the engine hoist is kinda key too though honestly...
    http://www.globalindustrial.com/p/p...UG5a1C-zNh6zeqTVUyhTPWoxDof-jAmkAhRoCu47w_wcB
    Yes you could make a set but for the price, I didn't bother...
    lembowski and Cr250jumper like this.
  5. Nov 17, 2015 at 10:24 AM
    jeffz0rz
    san diego
    The links I make are 55 inches, works for a extra cab, and a double cab short bed.
  6. Nov 17, 2015 at 10:26 AM
    triple6
    triple6 Well-Known Member
    oli
    Fallbrook, CA
    04 Double Cab Stock ;)
    all beaneer designz
    need some of these for my new truck thanks for the link!
  7. Nov 17, 2015 at 11:30 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Those stands are nice! I bought a set of 12 ton jack stands at harbor freight that have plenty of height adjustment also. I also have 6 ton ones from harbor freight that just barely get the job done.
    Not gonna lie I did use some 3 tons when they were all I had with some blocks of wood, 0/10 would not recommend ever
  8. Nov 17, 2015 at 12:13 PM
    sirhk100
    I don't remember the tonnage but I've got 3 pairs of jack stands from harbor frieght in 3 different sizes from large to small and that's what I've used for literally a decade now and then about 2-3 months ago I got those stands I linked above and well, crap!!! So much regret not having them ages ago! It's nice cause I can have the truck a bit higher off the ground for room to work under. I can actually sit up underneath it depending what I'm working and where I'm sitting under the truck. That and while the jack stands under the truck really aren't that much in the way when working... You don't realize how nice it is until you don't have them there. The stands are far from a necessity as we all get by with regular ones but they are a nice garage luxury if they're in your budget and you're setup to take advantage of them.
    I'd wanted a set forever and finally pulled the trigger on 4 of them and have zero regret on the purchase!
    Here relatively soon I'm going to be starting the restoration of my '67 mustang and I've already been scheming how I can lift it high enough to get these under it and hold it 2-3 feet in the air for the underneath portions of the project! LOL
    txmxer likes this.
  9. Nov 17, 2015 at 2:11 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    have you guys seen these? pretty rad, much cleaner than the standard little weld on tabs. they will do a 2.5 or 3.0 reservoir.
  10. Nov 17, 2015 at 3:56 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Looks bulky, the standard tabs are pretty minimalist and clean looking personally
    Cr250jumper and jeffz0rz like this.
  11. Nov 17, 2015 at 4:17 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    i like those^ mine are a little different, got some flat plate about 2" wide and drilled 2 holes and bolted it to the frame and then welded the little tabs on it, redoing my towers cause they rub like a mother now with the bypasses.
  12. Nov 18, 2015 at 8:38 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    JuansTaco and Cr250jumper like this.
  13. Nov 18, 2015 at 8:42 AM
    Blue_DMZ_Tacoma
    Blue_DMZ_Tacoma Well-Known Member
    Chaz
    Irvine, CA
    Blue DMZ Tacoma
    2006 Speedway Blue Tacoma AC TRD Prerunner Total Chaos LT Fox Coilovers Fox Bypasses King 500 DMZ Bedcage DMZ Deavers Fox 3.0 Triple Bypasses Total Chaos Spindles Glassworks Fenders DMZ Custom Bumper With 4 Vision X HID's 16" MT Classic Blue Locks 315/75/16 BFG All Terrains DMZ FAB 4.88 Gears TC Heimed Uppers
    That's hilarious
  14. Nov 18, 2015 at 8:44 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    txmxer and Cr250jumper like this.
  15. Nov 18, 2015 at 8:45 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    The little tabs are $3, are those really needed? Seem a little over beefy
  16. Nov 18, 2015 at 8:46 AM
    tubbsisland
    Cliff
    Arizona
    pretty easy when they put specs directly on their website, so much for originality I guess
  17. Nov 18, 2015 at 8:48 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I mean, it's not exactly a hard design to create on your own. Make the letter "M" in solid works and extrude by a couple inches. Magic!
  18. Nov 18, 2015 at 9:03 AM
    Lakeside, Ca. 92040
    very similar, but not the same. you should know being in the industry that everything resembles something else. that would be like saying that camburg/icon copied TC tube arms..
    or that everyone copied dirt techs housings or trailing arms that they posted the specs for 9+ year ago before anyone else was building housings and or box style trailing arms..
    http://www.dirt-tech.com/tp_trailing_arms.html
    im sure camburg was not the first to make these and dirt king will not be the last.
    its just another option that may suite someone's build style rather than the standard weld on tab. the camburg ones are cool too, I personally like this style over the little tabs.
    j0shu4 and thekernel114 like this.
  19. Nov 18, 2015 at 9:09 AM
    BrandonTRD
    BrandonTRD Well-Known Member
    2016 TRD Offroad
    Icon Stage 5 Kit
    The more I have been looking I am now debating between a +2 or a +3.5 for when I make the decision. Is the 3.5 more maintenance intensive and is it more meant for a dedicated off roading vehicle than a daily driver? Or are they pretty similar? Hopefully you guys can give me some advice.
  20. Nov 18, 2015 at 9:13 AM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    One is 1.5'' wider per side then the other. That's the only difference.
