Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 27, 2016 at 8:41 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    FlapJack935 likes this.
  2. Jan 27, 2016 at 8:46 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Wow, I thought that blue truck was a full back halved build. I never realized that tank was built to be mounted to the OE frame rails. I would love to have even a 30 gal tank...been looking at options that will fit up under the ass end like that.
  3. Jan 27, 2016 at 9:37 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    So I can run a 10 inch shock using stock mounts or a 12 inch shock using the BAMF relocation. How do I know if I have the 12 or 10 inch shock? Looks like it's rebuild from scratch for me!
  4. Jan 27, 2016 at 9:43 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    The shocks you have from your 6" lift kit are an odd dimension specifically made for the drop bracket kit. Those DB rear shocks are usually a 9" stroke shock with an odd sized longer body to reach the axle with the big lift blocks and AAL installed. So, when you lower the truck they will be completely wrong and rob up travel. You need to completely ditch those shocks and buy new regular 10" or 12" depending on wether you go with OE mounts or the BAMF kit you mentioned.
    BohlaaH[QUOTED] likes this.
  5. Jan 27, 2016 at 11:29 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ok guys so what type of dust lights u guys running in back? I had a blitzpro 4"?roundbthat was decent on rojo. Just curious what everyone is running for those that are
  6. Jan 27, 2016 at 11:43 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm just gonna be running some diffused flood pods with amber covers.
  7. Jan 28, 2016 at 2:34 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Baja Designs Squadron Sports with clip on yellow lens.
  8. Jan 28, 2016 at 6:54 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    I have some pods that I could get Amber covers for I guess.
    Those squadrons look pretty nice.
  9. Jan 28, 2016 at 7:16 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Yellow Baja Designs S2 flush mounted underneath my tailgate handle
    DIRT YOTA[QUOTED] and 06HAOLE like this.
  10. Jan 28, 2016 at 9:14 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I have this but not the clip on lenses.
    DIRT YOTA likes this.
  11. Jan 28, 2016 at 9:26 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm going with this. The ambers are on their own circuit so gonna wire them to a flasher.
    http://www.ebay.com/itm/291462198897
    DIRT YOTA[QUOTED] likes this.
  12. Jan 28, 2016 at 9:39 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I want one of these, Aaron has STL lights on his truck and they are insanely bright, come with flasher modules and controllers. They are pretty bad ass. this one is interior so you have to seal it to mount outside the truck
    http://www.speedtechlights.com/deck.../mini-eclipse-tir-interior-led-dash-light-bar
    or just dust lights fully sealed already
    http://www.speedtechlights.com/LED-Grille-Surface-Mount-Lights/striker-tir-led-grille-lights
  13. Jan 28, 2016 at 11:08 AM
    sirhk100
    sirhk100 Well-Known Member
    ToughLight Dually knock off with an amber lens in place of the clear. 5th one up on the right lane. The blue one on the drivers side is the same but just with a blue lens instead of clear.
    2015-mint-400-parade-down-the-las-vegas-_b0e497985d6d1bd8b3616f6b9bfe82145b19c0d0.jpg
    BTW, I have ZERO affiliation with this. I'm just passing on a good deal. These prices are to your door shipped. I bought the 32" one for my Dad for Xmas to put on his Jeep for helping to spot deer on the empty backroads of northern Minnesota in the summer when they're up there and it's pretty damn bright! Probably not the brightest most badass thing on the market but it's good enough that I feel with the pricing it was an absolute smoking deal.
    http://fourwheeldirect.us/collections/all
  14. Jan 28, 2016 at 12:06 PM
    dirt addiction
    Flagstaff
  15. Jan 28, 2016 at 12:43 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    :jellydance:
  16. Jan 28, 2016 at 1:51 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  17. Jan 28, 2016 at 6:36 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Those sealed ones look pretty cool! Ya Aaron's were stupid bright! Wonder how they hold up to the vibes of froading...
  18. Jan 28, 2016 at 6:51 PM
    Kennyperez
    Kennyperez Well-Known Member
    Kenny
    Yucaipa
    Tundra
    Uh oh
    BohlaaH, 06HAOLE and txmxer like this.
  19. Jan 28, 2016 at 7:30 PM
    doyouquaxu
    doyouquaxu Well-Known Member
    Saw an Engage built truck running one of the bars in the top link out at the night race 2 years ago. Really bright, and the take down white lights are great for work lights.
    Personally I'd do led pods, the bar above, or check the RDC classifieds for the ad in the parts section for the rear led bars. Oval trailer lights are complete shit until you're 1 foot off the back bumper directly behind the vehicle. Even harbor freight halogen amber fog lights do a better job than trailer lights.
  20. Jan 28, 2016 at 9:54 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    I have 2 6in bars on the back of my truck with some slag factory mounts. Work perfect
