Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 18, 2016 at 10:58 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You just need to worry about check engine light and the other crap doesn't need to work.
  2. Mar 18, 2016 at 11:24 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    I have an abs kill switch already, I smashed one of the sensors brappin around soo I have that switch basically switched permanent lol, just want to get rid of the lights.... I'll pull the dash I guess, and since I have a manual, speed sensor is on the t case already soo that's cool for axle swappin, would it piss the truck off if I removed the whole abs module and just made it simple with master cylinders n stuff
  3. Mar 18, 2016 at 11:30 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Unsoldering the LED is easy.
  4. Mar 18, 2016 at 11:30 AM
    MadTaco461
    CA
    Kinda stock
    You gotta leave it in there plugged in, but you can bypass all the lines with t's as if you never have abs. Easier to bleed the system too and tighten up your brakes
  5. Mar 18, 2016 at 11:38 AM
    Basikbiker
    Trav
    Yea that's what I was wonderin if I could just remove that crap. want my truck to be as dumb as possible lol
  6. Mar 18, 2016 at 12:10 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    You can pull the abs pump. All the sas guys do it.
  7. Mar 18, 2016 at 12:14 PM
    Basikbiker
    Trav
    Ok and just keep the wire stuff hooked up?
  8. Mar 18, 2016 at 12:18 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Vancity4x just left the plug taped up in the engine bay. The whole abs system (electrical) is seperate from every else in the truck.
    Basikbiker likes this.
  9. Mar 18, 2016 at 12:28 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I removed the whole ABS module when I put a 9" full floater in my old 2006 Tacoma. No issues.
  10. Mar 18, 2016 at 12:59 PM
    Basikbiker
    Trav
    Awesome thanks dudes
  11. Mar 18, 2016 at 6:15 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    What about 1st gens? My new build is an 03' prerunner. I know Jason swapped in all the plumbing and what not from a non abs one. I don't have that find age available yet. So what are the 1st gen prerunners doing to disable the abs? Pull the big abs fuse under hood fuse box? Any tips guys?
  12. Mar 18, 2016 at 6:20 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I know on 2nd gens (09+) that it has 4 speed senors. The front 2 are ABS and Trac control. The rear is the trac control, speedo, and my Transmission... I dont have the choice to change to a gear driven speedometer due to being 2 wheel drive.
  13. Mar 18, 2016 at 6:54 PM
    Basikbiker
    Trav
    yea just the 4wd manuals I believe have the gear driven speedo
    nfs257[QUOTED] likes this.
  14. Mar 18, 2016 at 7:00 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Auto 4wd 2nd gen tacoma's get speedo signal from the rear abs sensors but can be converted. Manual trucks have a gear driven speed sensor in the tcase.
  15. Mar 18, 2016 at 7:01 PM
    nfs257
    DFW
    She gone
    Cant convert mine. There is no cover to remove on my tranny. If there was a way I wouldnt have FJ rear bearings and hubs and would have went full float axle.
  16. Mar 18, 2016 at 7:12 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Sorry I meant manual 4wd 2nd gen tacomas
  17. Mar 18, 2016 at 8:07 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    What about one of those "yellow box" deals that guys use on 1st gens fo speedo correction? @nfs257 :notsure:
  18. Mar 18, 2016 at 8:14 PM
    nfs257
    DFW
    She gone
    Speedo correction isnt the problem... They use the actual sensors to feed the ECU which goes straight to the tranny... The correction box goes right behind the speedo in the dash.
  19. Mar 18, 2016 at 8:16 PM
    nfs257
    DFW
    She gone
    06HAOLE likes this.
  20. Mar 18, 2016 at 10:47 PM
    Basikbiker
    Trav
    Screw it, get a whole custom dash and the gauges n speedo you want lol, gps?
