Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 20, 2016 at 6:48 AM
    ntydog13
    ntydog13 Well-Known Member
    Alex
    Santa Barbara
    86 4x4 long travel pick up
    Lc engineering power pack, total chaos gen 2 caddy kit, 2.5 race runners, deaver f67, total chaos 12in shackles, king 2.5 double bypasses, corbeau baja ss fixed back seats
    Psh 97? :rolleyes: oh u kids ur new toys
  2. Mar 20, 2016 at 10:11 AM
    doyouquaxu
    doyouquaxu Well-Known Member
    Anyone interested in some 3.hoe 16" 3 tube sway aways? 1,000 firm
    883E8E7A-65CB-462D-B731-80B57C80DE3B_zps_7a8e477219d24f25cff3b5960731a4594733b314.jpg
  3. Mar 20, 2016 at 10:52 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Yeah, im not sure, I bought them for the studs in my spacers so I think they'll be perfect length after running through the spacer, but I havent heard of any stock length strong studs other than cutting down the arp studs like mentioned
  4. Mar 20, 2016 at 3:40 PM
    doyouquaxu
    Is there a stock first gen driveshaft that's longer from the carrier bearing to axle?
  5. Mar 22, 2016 at 3:02 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I ended up cutting down a set of ARPs to fit spacers on. No issues. Just use a fresh cutoff wheel.
  6. Mar 22, 2016 at 7:20 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have a set sitting in my garage but after cutting just one and thinking about doing it 23 more times I realized that I would rather spend $40 on a new set of open ended lugs. Quick search and I found black open ended locking lugs on ebay.
  7. Mar 22, 2016 at 10:44 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
  8. Mar 22, 2016 at 10:53 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    using a tape measure and a hammer handle is a pain?
    Your best bet is to set it like they instruct for kings. When you insert the seal head it will push the IPF into the resi and set it for you.
    I prefer to set the IPF 1/3 of the resi length from the oil inlet end. Be sure to full compress (without a charge and fully assembled) to make sure it doesn't hydrolock.
  9. Mar 22, 2016 at 12:11 PM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    We asked Brett a few years ago at the swapmeet how should we set the IFP. He said to just charge it with air before adding oil to make sure it's at the bottom of the resi just like the link says. It's what I've been doing and haven't had an issue.
    Basikbiker, MadTaco461 and jberry813 like this.
  10. Mar 22, 2016 at 8:18 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Soooooooo brutal! Love these things.
    Blackdawg and Rakso like this.
  11. Mar 22, 2016 at 8:53 PM
    doyouquaxu
  12. Mar 23, 2016 at 7:19 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Should have split the difference in wheelbase from the double cab short bed and the standard and 6 foot bed. Give you a little wiggle room.
  13. Mar 23, 2016 at 7:34 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Mmmmm that axle is damnnnn sexy!
    jeffz0rz likes this.
  14. Mar 23, 2016 at 10:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The wheel base is the same on double cabs and ext cabs on 1st gens. It's the exact same frame just different body mounts.
    j0shu4 and FlapJack935 like this.
  15. Mar 23, 2016 at 10:12 AM
    FlapJack935
    Jack
    Abq New Mexico
    first gens ftw
  16. Mar 23, 2016 at 10:36 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    @jeffz0rz @Blackdawg think he was refer more to just the bed it self. Like if u put a standard bedside on the dbl cab vs put the dbl cab short bed bedside on... Splitting that difference. Am I right Jeff?
  17. Mar 23, 2016 at 10:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why would you increase the wheel base over all then? Plus no bed sides would line up? I don't see the point..
  18. Mar 23, 2016 at 11:17 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    thebeeler and JuansTaco like this.
  19. Mar 23, 2016 at 11:19 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Think he meant like this.
    acc073a1438085534048c1c2e0206dbc_109158ec2a06d363e78a2af2dd38335ca971816e.jpg97d96e45aac4d0bc261f2b43c2009a0c_14ad18e3035e607cf0ca77b4c7382b54cd301646.jpg
    a.smo, BYJOSHCOOK and tubbsisland like this.
  20. Mar 23, 2016 at 11:39 AM
    FlapJack935
    Jack
    Abq New Mexico
    the long weenie. goals
