Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 21, 2016 at 5:17 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    jelly of the rear set up
  2. Jun 21, 2016 at 5:21 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Let's talk rear sway bars - I could not afford to do it at the same time @jeffz0rz built my links but it's time to get rid of the 72' Caddy with blown struts cornering I have. Anyone have experience with the Currie universal " antirock " kits or any other universal kits ?
    $495
    http://currieenterprises5.reachlocal.net/universal-antirock-sway-bars
    They sell a bracket that you simply bolt to the bottom of your frame, it is intended for a Jeep but looks just like every other brands universal add on bracket :
    $85
    http://currieenterprises5.reachlocal.net/CE-9900XJBR
    Seems pretty straight forward and simple ? Would just need the tabs welded to the top of my axle for the other end of the link. I did some research on the install and the positioning etc...all seems pretty simple, plenty of charts available to figure out the length of the arms and links etc .
    Am I missing anything ? Any advice ?
  3. Jun 21, 2016 at 5:22 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    You live in San Marcos now ? I'm in San Elijo Hills just over the hill from Cal State
    anthony250f[QUOTED] likes this.
  4. Jun 21, 2016 at 5:28 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    The +2 kit is 11.5" of travel and +3.5 is 13" of travel so I don't think its "useless" unless im missing something? Only 1.5" less of travel...
  5. Jun 21, 2016 at 5:28 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I'm in Encinitas right now but moving to San Marcos this Friday. I'm egr across the street from csusm
  6. Jun 21, 2016 at 5:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    An inch is a mile for travel and ground clearance.
    But again, for your uses. +2 will be good
  7. Jun 21, 2016 at 5:51 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I wouldn't count on those full #'s with a 4wd because your droop is limited by the CV's. My CV's bind at droop a couple of inches before the uniballs and CO
  8. Jun 21, 2016 at 6:00 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Hmm...
  9. Jun 21, 2016 at 7:18 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Ruff stuff sells swaybar stuff too
  10. Jun 21, 2016 at 7:22 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    They want $550 just for the bar :eek:
  11. Jun 21, 2016 at 7:22 PM
    Basikbiker
    Trav
    I actually have a buddy who used d44 snouts, machined a sleeve to fit the bearings, made a shackle for leafs out of it and used the splined bits off an old axle welded to sum .25" wall dom for the bar, and it ran thru the snout pivots, worked really well, kinda random but it's swaybar related lol
  12. Jun 21, 2016 at 7:27 PM
    Basikbiker
    Trav
    Yea it's expensive, heat treated chromo rod, then splines broached and retreated...isn't that cheap to do yourself...I've tried doing splines at home and it's a bitch kinda
  13. Jun 21, 2016 at 7:30 PM
    Basikbiker
    Trav
    You could maybe make your own using some old torsion bars?
  14. Jun 21, 2016 at 7:36 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I'm not bothered by the Currie pricing so I will probably go that route but I was just laying under my truck looking at it and I will be lucky to be able to make it work. A short bed with OE frame, links and CO's, bed cage mounts, pan hard mounts, bump cans etc etc I will be lucky if there is space for it. I'm going to mock it up tomorrow with a 1" dowel and make cardboard arms to mock cycle it and see if the arms will actually clear everything. Looks like the arms will have to pass outside the bump cans so the 50" bar may be my only option. It is 48" outside to outside of my bump cans but the width of the arms will probably mean the 50" bar has a 48" inside edge to inside edge clearance ? ...need to call Currie in the morning to find out for sure...
  15. Jun 21, 2016 at 8:00 PM
    Basikbiker
    Trav
    Run it thru the frame maybe?
  16. Jun 21, 2016 at 8:06 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have zero room to do it that way, between everything g i already described and a boxed, plated frame with a new X memember there is no room to do it that way. My only hope is to use the brackets to mount it on the bottom of the frame.
    Basikbiker[QUOTED] likes this.
  17. Jun 21, 2016 at 9:29 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    An idea. Run it across the axle and bolt to the frame. Just like how modern trucks do. I gotta draw that up to see if that is even possible with huge travel. I'm just speaking off the top of my head right now.
    Basikbiker likes this.
  18. Jun 22, 2016 at 5:50 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Aren't some of the McNeil trucks running the sway bar on the axle? I know I have seen some LT trucks with 4 link and on axle sway bar just don't recall whom's.
  19. Jun 22, 2016 at 8:05 AM
    MadTaco461
    CA
    Kinda stock
    Maybe. I don't recall if I've seen it. Definitely be a bit of a pain to set up
  20. Jun 22, 2016 at 8:18 AM
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    Generally trucks built for the dirt that have this set up run it above and behind the axle, but you get the idea:
    MadTaco461 likes this.
