Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 31, 2016 at 12:17 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    How are they on the hwy
    Shmellmopwho[QUOTED] likes this.
  2. Jul 31, 2016 at 12:22 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    The C rated ones that I have (because they're a softer compound) will probably wear slightly faster but they're pretty smooth and ride well on the highway. I don't DD my truck but take it to work once or twice per week and the tires are great. I've heard people have a little bit of a tough time balancing them but I haven't had any issues. Some people don't like the noise of the tires but it doesn't bother me at all. I usually have my stereo turned up anyways haha.
    Not only do the tires perform well but they look so sick!!!
  3. Jul 31, 2016 at 12:24 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Absolutely love my MTR's, even thought they are E rated :(
    Y2kbaja and Shmellmopwho like this.
  4. Jul 31, 2016 at 1:34 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That new Nitto Ridge Grappler is my next tire, sits between the AT and the Trail Grappler
  5. Jul 31, 2016 at 1:58 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    MTR's are definitely on the pricey side. I feel like the Trail Grapplers might be a good option, and the Open Country MTR doesnt look half bad from reviews too.
  6. Jul 31, 2016 at 2:15 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Bfg AT's by far best all around tire
  7. Jul 31, 2016 at 2:17 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    until you hit the dirt and they start to chunk...
    Y2kbaja, Jerez, whitetoblack and 3 others like this.
  8. Jul 31, 2016 at 2:19 PM
    tubbsisland
    Cliff
    Arizona
    so its a Toyo RT then with a softer compound and shorter tread life
  9. Jul 31, 2016 at 2:52 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Well someone's a Toyo fan huh. I never believe anything I read around tread wear spec's. I've had tires last significantly longer than expected and wear out stupidly quick as well.
    I've had horrible luck with 35" BFG AT's and MT's wearing in crazy patterns IE: almost as if every 5th lug is twice as hard of a compound and wearing at half the rate of the lugs around it and bad cupping on the outer edges too. The last set were clearly defective and BFG would not stand behind them, sent them off to be shaved so they didn't feel square anymore and they just did the same thing again...and again BFG would not warranty them.
    We've had really good luck with Nitto's on both the truck and our T4R, Terra and Trails. I am going back to a siped AT tire though with the next set because the Trails felt scary in the snow and slush etc.
    ...and most importantly I like the looks of the Nitto vs the Toyo and that's like +5hp right there
    Erock_Reno likes this.
  10. Jul 31, 2016 at 3:07 PM
    tubbsisland
    Cliff
    Arizona
    Well Toyo makes tires for Nitto, using a softer compound and different sidewall designs. Nittos are usually a few $ more per tire too with a lighter load rating.
    nfs257 likes this.
  11. Jul 31, 2016 at 3:25 PM
    Basikbiker
    Trav
    They last longer thru rocks than mtr's, that being said I'd run mtr's again.
    Toyo AT's are junk, had ok luck with the MT tho.... It's all personal opinion and how you drive
  12. Jul 31, 2016 at 3:55 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    That's true of many brands in the tire industry, many are made in the same place. There are significant differences in the tread designs between Toyo and Nitto not just sidewalls. In this case the Ridge Grappler is actually available in a higher load rating than the Toyo with many of the sizes available in a load range F...if you really want to rattle your teeth out.
    I will be curious to compare the actual spec's such as tread depth and weight etc once all of the new Nitto sizes are available over the next couple of months.
    Here is a side by side of the tread and sidewalls :
    Nitto Ridge Toyo RT
  13. Jul 31, 2016 at 5:18 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    dont get KO2s
  14. Jul 31, 2016 at 6:19 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    sorta forgot i owned a truck. so i decided to put in some hours on her.
  15. Jul 31, 2016 at 6:25 PM
    BrownMike
    San Diego
    1999 Taco 4x4
    I definitely dont feel like trying BFG again, ran two sets on the truck (and another on my tahoe) prior to the Red Labels, and they never impressed me. Low traction, bad wear patterns, not even great looks.
    So it sounds like Toyo and Nitto are pretty much the same over all, at a better price point then the Goodyears?
  16. Jul 31, 2016 at 6:28 PM
    Basikbiker
    Trav
    I'll be goin back to toyo mt's or the mtr just on the premise of better sidewalls alone, I've popped my bfgs twice from sidewall scuffin up rocks
  17. Jul 31, 2016 at 6:30 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Ya you won't be popping either of those tires. The MTR is a tad lighter and comes in load D. I'm running 315/75/16's and I love them.
    They'll drag a 5th gen 4Runner no problem
    https://www.youtube.com/watch?v=RHVme386MC8
  18. Jul 31, 2016 at 11:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    MTRs all day for a dedicated rig.
    For a weekend warrior. KM2s. Although softish side walls so idk.
    The hankook rt03 is probably what Id do for a weekend warrior.
  19. Aug 1, 2016 at 8:37 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I've always had my heart set on MT/Rs for my next tires, and never was a fan of the Toyo MT bandwagon that every bro out there has.
    BUT
    The Toyo RT really has me thinking as a nice upgrade from my duratracs...
  20. Aug 1, 2016 at 8:41 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Duratracs have treated me far too well over the years, it's hard to stray away from them. The mt/rs are tempting, but the duratracs just do so good in the winter with the snow. Probably heading to 35's on my next set of tires though, so I'll have some deciding to do then.
