Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 10, 2016 at 6:15 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Fuel tank? want!
  2. Oct 10, 2016 at 6:30 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I think that's a water tank for the shower system
    Zam15 likes this.
  3. Oct 10, 2016 at 8:39 PM
    TacoAC
    TacoAC Well-Known Member
    Cali
    DCSB In Progress
  4. Oct 10, 2016 at 8:41 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    It was discussed a few pages back in this thread
    mahaloTaco likes this.
  5. Oct 10, 2016 at 8:55 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  6. Oct 10, 2016 at 8:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  7. Oct 10, 2016 at 9:08 PM
    Zam15
    Derek
    San Diego
    Needs power..
    ARMOR
    Still want! I'll take either, I'll have onboard hot water soon enough. Very clean tank install.
    nfs257 and mahaloTaco like this.
  8. Oct 10, 2016 at 9:38 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Does so and Craigslist buy sets a new record at the baja 1k. Maybe we all can learn something from this build. Maybe not.
    mahaloTaco and Dalandser like this.
  9. Oct 10, 2016 at 11:23 PM
    Tacomoto23
    Tacomoto23 Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    I want to see what "20+ inches of clean travel" really looks like in action" :rofl:
  10. Oct 11, 2016 at 2:27 AM
    doyouquaxu
    doyouquaxu Well-Known Member
    ever seen a questionable hooker who says shes clean?
    like that.
    Large, Kerleyfries, Spagget13 and 4 others like this.
  11. Oct 11, 2016 at 7:45 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    short version: new springs cut short now back end of truck sits way too high.
    longer version: F67's broken and sagged out, on bump stops when loaded, rear hitch height 21". Bought used set of 50T's that needed a main leaf, had local shop make 2 new main leafs, ride height back to normal (27"), unbelievable ride off road. BUT, springs too long, shackles were hitting frame. The way the shackle mounts are there is no way to fix or move. Had main leaf shortened 2", they cut the eye off and re-curled the spring. Now 32" ride height and shackle angle what you see here. I hope it settles after running or I'll be screwed. Out of money to make new mains.
  12. Oct 11, 2016 at 8:05 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Drill a new hole in those shackles to make them "shorter" and that should lower your ride ht? About the only free suggestion I can think of.
  13. Oct 11, 2016 at 5:57 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Just asking round here. Anyone have some 3"x16"x600lb coil springs they would like to get rid of?
    Also sub'd for LT shenanigans.
  14. Oct 11, 2016 at 8:38 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes
  15. Oct 11, 2016 at 10:48 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    So I've had this thought before and I'm having it again...
    Putting ORI struts on the front end of my truck.
    I do not do a whole lot of high speed stuff anymore. Occasionally I rip down a whooped out dirt road, and that's about it. I would much prefer to be get some stability on the road back. I already have a nitrogen tank set up.
    Thoughts?
  16. Oct 11, 2016 at 11:37 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I don't see a problem, you'll probably have to F around with pressures for a while to get the right 'spring rate'. Only issue would be blowing a seal and being on bumpstops till you replace/get home.
  17. Oct 12, 2016 at 7:00 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I wouldn't, Just add about 10% more slow speed rebound if you're looking for a more stable on road ride. Don't go too much as it can make the ride feel harsh.
    MadTaco461 likes this.
  18. Oct 12, 2016 at 7:50 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Could you elaborate more on that? My truck runs like a bouncy ball on the highway, off-road it seems fine. Front is a Camburg LT with Camburg spec'd 2.5 SAWs, rear is DMZ SUA with 3.0 SAWs running 12/10 stacks, single full size spare in the bed, 2nd gen. DCSB 4x4.
    I'm trying to daily drive it right now since the temperatures are dropping and my actual DD came with a nice warning from GM and Goodyear to not drive it in low temps unless I buy all season tires. :annoyed:
  19. Oct 12, 2016 at 8:21 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    What's your tire pressure? Are the tires balanced? Bias ply?
    Are your shocks charged? 200psi is the normal charge, but can go up or down 50psi with no issues.
    If your tires and Nitrogen charge are OK I would try going the next thickness up on the largest shim on the rebound on the front coilovers only.
  20. Oct 12, 2016 at 8:41 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id pass. They couldn't hold my dads rig up and failed 4 times on the trail. Luckily he was carrying nitro with him.
    They did ride amazing. But couldn't cope with the weight. Been on a buddies single cab for a few years now and never had an issue.
    They also fluctuate with temperatures a lot. Like 1-2".
    ORIs arent going to give you any more stability then if you revalve your coilovers.
