Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 14, 2016 at 5:48 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
  2. Oct 14, 2016 at 5:56 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    How do you like your camburg kit? I am actually getting an older LT kit from a buddy after Christmas. Was curious if there was anything I need to know about after install.
    Coot
  3. Oct 14, 2016 at 6:10 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Hey anyone able to completely remove the abs module in a second gen? I already have a gear driven speed sensor for my speedo
  4. Oct 14, 2016 at 6:23 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    He's taken everything trac off and has bad mouthed them. I'm letting Andrew design it and planning to keep the ac. His didn't keep the ac.
  5. Oct 14, 2016 at 6:24 PM
    nfs257
    DFW
    She gone
    Just removing the speed sensors turns the abs off. I can lock up all 4 with disc brakes.
  6. Oct 14, 2016 at 6:39 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I've been pulling the fuse when I off-road. I've heard it only works with the Sports though. Pulling the fuse on an OR disables a-trac as well or something like that.
  7. Oct 14, 2016 at 6:40 PM
    Basikbiker
    Trav
    Yea I removed all the wiring for em lol, I want to get rid of the whole module thing with 8 million wires that are hooked to it, but I want my brakes to still work lol
  8. Oct 14, 2016 at 6:44 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Same. I'd like to veto the whole system if possible.
  9. Oct 14, 2016 at 6:54 PM
    Basikbiker
    Trav
    I was wondering if I could swap it with the non vsc equipped trucks? Put their master and booster in?
  10. Oct 14, 2016 at 8:31 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    Does anyone have a discount code for poly performance?
  11. Oct 14, 2016 at 10:04 PM
    Hippiglass
    Hippiglass Well-Known Member
    riverside ca
    2012 tacoma sport DCSB
    DTF race kit, DTF front bumper, king 10"dual rate shocks, URD CAI, total chaos upper control arm brackets, method race wheels, 35/12.5/17 bfg ko2, mcneil TT bedsides, custom SLX Motorsports front fenders, fox bump stops
    oh ya i forgot about that... thats why hes putting that new J arm kit on it huh
  12. Oct 14, 2016 at 10:35 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    When moving the coilover out of the way on the lower control arm, keep in mind the upper control arm that you're going to build. Make sure everything clears nicely. If you're going to play with everything and possibly build new shock mounts as well, you could look into getting a longer rod and which would raise the coil seat out of the way as well which might give you more room. You got options.
  13. Oct 14, 2016 at 10:39 PM
    jeffz0rz
    san diego
    You know, there's going to be a huge demand for the average LT guy to tear apart the front of his truck, shitcan his air conditioning and run a million dollar J arm kits with swing steering.....
    they'll be lucky to sell four, maybe five of those kits ever. Everybody wants bolt on. That's where the money is at and that's where the business is. By all means, let's reinvent the wheel and make a Wazoo front j arm suspension for an underpowered overpriced mid-sized pickup truck. Come on meow...
  14. Oct 14, 2016 at 10:53 PM
    Hippiglass
    riverside ca
    ya i totally agree with that
  15. Oct 14, 2016 at 11:09 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  16. Oct 14, 2016 at 11:41 PM
    VolcomTacoma
    Jeff
    NorCal
    Looks like either different models, or yours was setup for dual shocks whereas his only has single shock tabs. So either way, a CV axle isn't gonna fit on that kit as it sits now with longer shock ends or moved tabs
  17. Oct 15, 2016 at 2:28 AM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Gotta keep it or it will go into limp mode, I tried it unplugged and no bueno. It controls trans/speedo and who knows what else. I just capped mine off and mounted it outa the way
  18. Oct 15, 2016 at 5:29 AM
    Basikbiker
    Trav
    I have a manual tho, soo tranny shifting isn't affected, and my speedo runs off the transfer case. I don't have any wiring hooked up to any of the wheel sensors at all. I can't drive it unplugged cause I tried and lost all brake boost cause the thing is freakin electric not vacuum boosted off the engine. I'm pretty sure the limp thing is for you fancy automatic transmission folks
  19. Oct 15, 2016 at 11:40 AM
    Basikbiker
    Trav
    Work is slow since our fire contract is over for the year, back in the hangar playin with sheet metal
  20. Oct 15, 2016 at 11:57 AM
    chulsey4
    chulsey4 Well-Known Member
    Pikeville, NC
    2010 LT 4x4 DCLB
    Camburg LT - Fox w/ DSC Adjusters DTF Front Bumper Fiberwerx color matched Barcelona Red Method Double Standards - General Grabber AT2 (285/75R/16)
    I absolutely love it and how well built Camburgs stuff is. Can't think of anything really. Keep it lubed up for sure, all the uniballs like to squeak
