Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 25, 2011 at 4:41 PM
    #6321
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Manual ftw^^!!!
    Lol..but yeah the Grabbers are a straight bad ass tire out on the dirt..you'll be surprised the shit you can do with them.
  2. Sep 25, 2011 at 4:51 PM
    #6322
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Yeah i found the same thing with the km2s and my truck. You cant let the bitch upshift like it wants too because it just robs all your power. The supercharger couldnt spool to keep up so i just kept it in 3rd and in between 2.5-4k rpm.
  3. Sep 25, 2011 at 5:09 PM
    #6323
    Ptowntaco
    Ptowntaco Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    Haha i was at 4-5k also burnt a half tank of gas in like 40 mins lol. Tranny fluid and rear diff fluid are getting done this week ASAP!:D
    Yea most i have hit with them was a gravel road by my house :rolleyes: and they are amazing but the sand f no!
  4. Sep 25, 2011 at 6:56 PM
    #6324
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i hear ya man...i'm changing all my fluids this week. they need it anyways, but after this weekend they really need it.
  5. Sep 25, 2011 at 8:25 PM
    #6325
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    So It says it will lift the rear 2" Can I just run spacers in the front until I LT the front...maybe a year? Or what do you guys do when building in stages?
  6. Sep 25, 2011 at 8:27 PM
    #6326
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    wheel spacers or coil spacers?
  7. Sep 25, 2011 at 8:30 PM
    #6327
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    You won't need to run spacers in the rear unless you plan on running a 12" or wider tire or a 3.0" or bigger shocks
  8. Sep 25, 2011 at 8:53 PM
    #6328
    ktmrider
    Junk
    spacers will not perform, yes the rear will hold you back with you have LT in the front but spacers in the front will have you broken if you actually start to use the rear. Get some Replacement UCAs and coilovers and then try.
  9. Sep 25, 2011 at 9:08 PM
    #6329
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ya I'm 4x and mob around in low at 4-5k rpm :D
  10. Sep 25, 2011 at 10:33 PM
    #6330
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    4lo Cory?
  11. Sep 26, 2011 at 6:24 AM
    #6331
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i say dont buy expensive replacement CO's and UCAs cause they will only set you back further when going lt front. i say get some bilstein 5100s just to level it out and it will be better than stock
  12. Sep 26, 2011 at 6:56 AM
    #6332
    Piratefish
    Sebastopol
    Sadly None
    Coil spacers...Cause the Defined rear LT kit will lift the rear of the truck 2". This is just until i LT the front. I will not be doing any serious offroading until the front is done.
    Crap...read further first. 5100s OK thanks!!!!
  13. Sep 26, 2011 at 7:03 AM
    #6333
    97yota4wd
    Eric
    Mesa, AZ
    whats your guys view on welding the rear diff on a 75% off road 25% on road truck?
    and i plan on never getting rid of the truck
  14. Sep 26, 2011 at 7:43 AM
    #6334
    theduck911
    Max
    Locked and Geared!
    Why not just get a spool or locker?!
    Unless you're talking about trussing it?!:confused:
  15. Sep 26, 2011 at 7:45 AM
    #6335
    97yota4wd
    Eric
    Mesa, AZ
    cause its cheaper, a detroit and welding the rear diff does the same thing... so why not save a couple bucks right? or am i missing something
    i dont know much about lockers so any opinions are welcome
  16. Sep 26, 2011 at 7:48 AM
    #6336
    theduck911
    Max
    Locked and Geared!
    I would not weld your gears/diff.
    A locker still has some give with the spring mechanism inside iirc, a spool (which are cheaper) has no give at all (hell on wheels if you plan on driving it on the street)
  17. Sep 26, 2011 at 7:49 AM
    #6337
    97yota4wd
    Eric
    Mesa, AZ
    okay thank you!!
  18. Sep 26, 2011 at 7:57 AM
    #6338
    theduck911
    Max
    Locked and Geared!
    Get a Powertrax Locker (if they have them for your truck) if you don't want to spend the money for a Detroit.
    Honestly, save up for a built 9" or Tundra axle if you plan on keeping the truck for a long time.
  19. Sep 26, 2011 at 8:18 AM
    #6339
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    yep.. agreeing with the duck. do not weld your gears... been there and done that on the last truck... it works yes, but your tires will hate you. just get the powertrax. its like 300 bucks for your truck and they are a cake walk to put in.
  20. Sep 26, 2011 at 8:20 AM
    #6340
    97yota4wd
    Eric
    Mesa, AZ
    and power trax only kicks in when when your on the gas right?
