Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 8, 2017 at 10:07 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    link the bitch already
  2. Feb 8, 2017 at 10:53 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    You'll need a custom tube layout to keep the tubes and resi line on the front and back of the shock or your tires will eat the tubes. IMO a 2.5 smooth body with the compression adjuster will work just a well for the limited travel SOA offers.
  3. Feb 8, 2017 at 10:53 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    What about a short course style setup? Two tubular lower links, one upper link to set the pinion, and a panhard bar running the coil overs where you would of mounted the bypasses if you had stayed with leafs. You are setting the coils as far back as possible and should reduce the leverage effect from being loaded and unloaded. Not sure by how much though compared to leafs. Just my .02 cents, since I hate having leafs and could of done a link setup like this for a lot less than buying the SUA kit and 3.hoe bypasses.
  4. Feb 8, 2017 at 11:06 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I know!
    well yea id do custom tubes. Id want to tune the rebound though as well so just compression adjusters aren't what id want. Probably go with doubles and a resi.
  5. Feb 8, 2017 at 11:07 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    It's possible not practical for most people who just want to go camping all #EAF and shit. A more purpose built prerunner it would definitely work and if Dcab would keep the shocks out of the cab, it's been done a few times.
    I thought about keeping leafs and adding a 2 link set up ahead of the axle to run the shocks off of. I've seen it on older prerunner builds and it would work but not sure if the time involved is worth it.
  6. Feb 8, 2017 at 11:11 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Run a full 8 stack on rebound, DONE! tuned! To do it correct and make it effective you will need a big rebound tube to move enough fluid.
    Giant has King add the 3.0+ sized tubes on his link killer 2.5 shocks.
    http://giantmotorsports.com/index.php/product/link-killer-shocks/
  7. Feb 8, 2017 at 11:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  8. Feb 8, 2017 at 11:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thats a big tube!
    I haven't played with valving enough on my rig to really know what it would benefit from. Just figured having the flexibility would be nice.
  9. Feb 8, 2017 at 11:49 AM
    FlapJack935
    Jack
    Abq New Mexico
    on the topic of short coarse links, anyone ever see a reversed 3 link that the top links mount at the rear of the frame so you dont have to get a fuel cell?
  10. Feb 8, 2017 at 11:51 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    @TRACperformance had one he was designing but not sure what came of it. Maybe @jeffz0rz can chime in.
    jeffz0rz likes this.
  11. Feb 8, 2017 at 11:54 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    14 flutter with 20 for the last 2 shims on comp and 8 on rebound. And that might not be enough compression valving depending on your shock angle and added weight.
    Lowered mini truck stuff mainly.
    That doesn't work well for high travel suspensions, it will bind and have odd pinion angle changes at less travel #'s than a leaf setup.
    a 3 link with a long panhard works way better and easier to setup and build.
    nfs257 and ls1 prerunner like this.
  12. Feb 8, 2017 at 12:03 PM
    FlapJack935
    Jack
    Abq New Mexico
    saw it a couple times on other trucks. i dont want to run a cell but i really wanna do short coarse links with 2.0 coil and 2.5 bypass off the axle. if i could get the brackets from jeff that would be sweet
  13. Feb 8, 2017 at 12:11 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    His daily driver link kit works well for what it is. But those little shocks on the axle takes a beating off road and will need serviced a lot.
    IMO just build it from scratch yourself. And add a sway bar, you'll need it.
  14. Feb 8, 2017 at 12:14 PM
    FlapJack935
    Jack
    Abq New Mexico
    its just a daily, mine is no where near a race truck. 2.5 coil and 2.5 bypass would be more then enough for what i want to do on mine. we dont have a barstow main where i am so its not that big of a deal. i trust his work so id be more then happy to get the brackets and whatnot from him when im ready to pull the trigger
  15. Feb 8, 2017 at 12:14 PM
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    You can do a three link wishbone on the top, but instead of going full width of the frame rails for each side, you can have one go to the frame on the passenger side then straight up the middle for the driver side one. You will need a beefy cross bar setup but it will do the job.
  16. Feb 8, 2017 at 12:14 PM
    ls1 prerunner
    Andy
    El Paso, TX
    Refer to this post
    The one upper link would be on the opposite side of the the OE gas tank and it would control your pinion angle. The panhard bar would locate your differential to eliminate the upper link that usually lands where your gas tank is. The lower links would be open to you imagination as far as if you want but seeing you want coils and bypass, mount the coil on the lower link and bypass on the diff.
  17. Feb 8, 2017 at 12:17 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Then why link it?
    62's and 2.5 shock in the rear will keep up with 'burg kit no problem and easier to prep than links. And kinda DD friendly.
    ls1 prerunner likes this.
  18. Feb 8, 2017 at 12:32 PM
    FlapJack935
    Jack
    Abq New Mexico
    i like links better, ive been in a 62" truck and didnt like it. im more comfortable with link set ups so thats what i want to do. seeing the 3 linked double cabs made up my mind of what i want to do. specially the one jeff did on the silver double cab and then theres the red double cab also with the same set up
  19. Feb 8, 2017 at 12:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    photos?
  20. Feb 8, 2017 at 12:40 PM
    FlapJack935
    Jack
    Abq New Mexico
    i know they have trailing arms but down the road i can always do that. but im talking about the suspension in itself.
    cant remeber the guys name with the red one on DR but he caged his truck after getting a flat.. people that know will figure it out
